Question about IBM ThinkCentre A50p PC Desktop
Hi! Please help? I have a desktop IBM ThinkCentre 1) I formatted my harddrive in another computer, using via Windows Disk Management option. 2) Replaced the HDD, and wanted to run new Windows XP Prof setup. 3) Made CD/DVD ROM first booting device. (ROM is working fine) 4) My computer reads "NTLDR missing. Press Ctrl+Alt+Del" Any other advice/assistance to resolve the setup, please? Thanking you in advance, Manny
    President:
  • 1,812 Answers
Download the Spotmau PowerSuite to solve he problem go for this link http://www.tech-pro.net/howto-fix-ntldr-is-missing.html do step by step .try it afer some time i will give another solution.
Posted on Nov 12, 2010
AFTER RUNNING A REPAIR ON A IBM PRELOADED WINDOWS XP PROFFESSIONAL SYSTEM, MICROSOFT WINDOWS COULD NOT INSTALL A DEVICE NAMED WPM...AFTER REPAIR WAS COMPLETE, I COULD NOT ACCESS INTERNET & WAS TOLD...
hi my name is rui it means microsoft detected that you have a non license software installed the only way to fix this is that you format your HD and install your OS newly then you must need to turn of the automatic update of your windows OS too. turn it of go to start>control panel>windows update.
Jul 21, 2011 | IBM ThinkCentre S50 8183 Intel Refurbished...
I want to formate my system how can i do it instruct me...and will my genune copy of windows be tutelly removed
First of all, no your windows operating system key would not be removed because your hardware is already register to your computer. Yes by formatting your computer, you will loose everything and every single files, including the o.s. If you want to format and You want to restore your computer to factory setting, you will need to make a restore/recovery disk provide in the acer management program. You will see a option for making a backup disk in the acer management software in the start menua via all programs. After making this disc, save all the files that you want like pic,music,video,doc to an external harddrive. Insert disc or simply leave disc, Turn of you computer, setup your bios to boot from cd/dvd-disc in the bios boot menu. (should see this option when starting up the first few second, maybe a F key or DEl key to get you into the bios menu or A key saying boot option) Set your boot prority to cd/dvd. The Acer recovery program will come on and follow direction. If you just want to format everything and not making a recovery/restore disk (which I would not recommend unless you bought another windows operating system disc). Then just click my computer and locate your harddrive, Right click, format, you should be good to go. You will loose everything.
Jan 27, 2011 | Acer Aspire 5742Z-4200 Notebook
Replaced HD and CD Rom drive, PC will not boot to disk, Do I need to format HD 1st. before loading OS?
Hi Get to the bios screen using F8 or F9, change the first boot device to CD ROM/DVD, then insert a bootable disk into the CD drive and try installing the OS first by completely formatting the HD during installation Win XP and higher OS editions give you the option to partition the HDD Hope this resolves
Nov 05, 2009 | IBM ThinkCentre S50 8183 - P4 3 GHz...
I have a Lacie 320gb external harddrive which was connected to an eMac and is now connected to an Acer laptop. I've reformatted it as NTFS and it shows up in disk management as healthy but does not appear...
you need to give it a drive letter
A more reliable way to do this is via the computer management console
Start / Control Panel / Administrative Tools / Computer management / Disk Management.
Your drive should show up in here.
if it says Healthy and just above that gives the file system eg. NTFS or FAT32 etc it should be fine but may just need a drive letter.
If it does dot say any of those then right click on it and use the format option. Select how you want to format it (NTFS for XP is preffered)
and then tell it to do a FULL format. and also give it a drive letter !
It may take a while but I find it more reliable overall.
If it didn't have a drive letter then right click and use the Change Drive Letter and Paths option, then add a drive letter and use the one it offers.
I like to re-boot just to be sure windows sees it properly
Aug 28, 2009 | LaCie Hard Disk 320GB with Hi-Speed USB2.0...
Getting problem in formatting the IBM PC
check if the cable from the cd rom connected to your ibm pc if its ok , also check the master, slave configuration pins into the back of your cdrom. make sure that theres no conflict between the hard disk and the cdrom. Your cd rom may probably cannot be detected. make sure that it is working first. then install the hard disk. The hard disk must be in primary master and the cd rom must be in primary slave. then try booting it to your cd rom. also, try checking if your windows xp setup disk is bootable, it means that it can boot from cd rom. PM me if you have other experiences after doing what i adviced. Thank You.. heres my email. jmizpahadonai777@gmail.com
Aug 07, 2009 | IBM Thinkcentre 8185 PC Desktop
Extra cd drive has come after operating system installation which does not exist only. my computer is showing as DVD-RAM drive and CD Drive. Earlier it was just DVD-RAM. kindly help me resolve it. kindly...
Please try go to control panel and then administrative tools, computer management. click drive management then delete the excess drive which is unknown to you.
else if this not resolve you can maybe its a network drive. If you are sure that this not annoy to you then you can ignore, However if is bad to you then you can eliminate that by clean format and re installation of windows again.
may this help,
melnavz
Feb 13, 2009 | IBM ThinkCentre A50p PC Desktop
Steps to configure system boot sequence
try to slave your hardisk to another computer, perform a scandisk with it, and if the scandisk completes then your hardisk is just ok, format it using windows xp bootable disk
Jan 14, 2009 | IBM Lenovo ThinkCentre M55e PC Desktop
How to change the boot option in IBM 6578-PBU desktop
I searched for hours for a solution to this. Here it is:
1). Restart your computer, NOT using ctrl - alt - del
2). Press F1 when guided to.
3). When you get into the config menu, select Start Options, then hit enter twice.
There are all the options you need! Cool, huh?
Aug 26, 2007 | IBM NetVista A40 PC Desktop
New harddrive not working
The drive probably needs to be formatted.
Aug 20, 2006 | IBM "Portable (22P7196) 40 GB Hard Drive
IBM ThinkCentre A50p PC Desktop Logo
165 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
