Question about Amcor AF 12000E Portable Air Conditioner
Get cool at the beginning but then it starts blowing hot air. Is the a way to recharge the AC or what can i do to get it cool again
  • 51 Answers
Check the thermostat. That could be the whole problem. Otherwise, you may need to have it recharged or serviced.
Posted on Nov 12, 2010
  • Grace Dorsey Jun 13, 2013
    How do you get it recharged?
My AC worked great until last year and then after a power steering hose leak was discovered, the ac until stopped blowing cold air. I took it and paid 75.00 to have it recharged with coolant and it worked...
My air conditioner started blowing hot air last summer. I put coolant in it and didn't run it until the beginning of summer this year (2011). All of a sudden it started working again. Sometimes it blows hot but if I keep it running full blast the coolness comes back. I don't know why this happened.
Jun 26, 2011 | 2004 Kia Optima
Ac started blowing hot air on my 2005 chevy z71 half ton crew cab ac blower was working fine just started blowing hot air
The seal package in your unit leaked out the freaon. It will have to be resealed again and recharged.
Jul 27, 2010 | 2005 Chevrolet Silverado 1500 2WD
AC ran for a couple of hours and started blowing
If it is icing over, it is low on freon. You might have a freon leak if the system is relatively new. It will take a licensed tech to check, fix leak and recharge.
Aug 25, 2009 | Fedders AEQ07FBG Air Conditioner
AC blows hot air when i stop at an intersection or slow down.
Try cleaning the condenser located in front of the radiator , with either a garden hose or compressed air. If this doesn't cure the problem then have your a/c system checked for leaks and recharged.
Aug 17, 2009 | 1993 Pontiac Grand Am
Heat comes on with ac cooling
what type of unit do you have fleet wood monaco ? useually this is a bad ground problem in a trailor motor home useually low voltage dc problem
Jul 21, 2009 | Dometic Rooftop RV Air Conditioner
Ac not working, blows hot air only. Recharged
Check the evaporator coil by sniffing the vents,floor is best, with your tester.
Jul 15, 2009 | 2005 Dodge Ram 1500
My 2000xk8 Jag air conditon is blowing hot air . I had it
Most probably you have a leak some where.
What you can do is have it checked proffessionally , or if you like to do it your self :
Pressure fill the AC with AIR and you can use any air pump that will fit the lines. After filling the air (up to 300, not more han that) you can get some water with soap , and put soap over the AC lines and seals and corners in the engine compartment. if any leak you will see soap bubles. If nothing shows there then you have a problem with the cooling tank , radiator inside the dash and you need to check that.
Jun 24, 2009 | 2007 Jaguar XK8
1999 Chevy Cavalier A/C blows hot air
More likely the recharge blew a o-ring and you have a leak. When your Cavalier was blowing hot air and a recharge fixed it that means it was low on freon which lets o-rings dry out, go back to the shop and have them leak test it. They use a pressurized dye to find the problem. If it's blowing it's not the cooling fan relay, they may have meant compressor relay but I'd have a leak test done first it's not expensive and easier that chasing unknown possibilities.
Jun 03, 2009 | 1999 Chevrolet Cavalier
Ac compressor does not turn on when car has been sitting & it's hot outside. Works fine in the morning.
either the freon charge is about 1/3 low, or the expansion valve needs to be replaced. Freon is getting into the evaporator, but not in great enough volume to cool the air unless it is coming in cool to start with. check your ac charge, and if it is full, then have it emptied, change out the expansion valve, and recharge it
May 14, 2009 | 2002 Jaguar S-Type
Amcor AF 12000E Portable Air Conditioner Logo
295 people viewed this question
Top Amcor Heating & Cooling Experts
AJMAL KHAN
Donni Steen
Bill Long
Are you an Amcor Heating and Cooling Expert? Answer questions, earn points and help others
