Question about Perception Digital PD-2000 (20 GB) MP3 Player
No sound through headphones. Volume turned up completely, but no sound. Can and have transfered music to and from player and works fine.
  • lowlycook1 Nov 12, 2010
    It isn't the headphones. I think I mat have accidentally erased the programming for that part of the player. Do you know where to redownlaod the drivers or firmware for this unit?
  • 17,130 Answers
If you are sure that there is output from the player to the PC for transferring and receiving music through the same headphone socket then the headphone must be checked with the PC for good performance. If the headphone seems good then the possible output from the player is well below the level needed to drive the headphone. Increase the volume to the highest, reset the player and if there is no result the low power amplifier output IC is faulty. Since this is within the unit it becomes difficult to remove/replace except with good tools/desoldering stations.
Posted on Nov 12, 2010
Sound works for radio not for music volume is up music is playing no sound from any headphones
Did you try plugging in a different set of headphones? If other headphones work, maybe you need new headphones.
Try playing music from your Sansa through the computer, while it is tethered. If you can do this, it may mean that the audio amplifier part of the Sansa is broken-- Usually this means, 'get another Sansa.'
Also, try gently wiggling the headphone plug to the left and right, while it is plugged in. If you get music on and off, its possible that the headphone connector on your Sansa has a broken connection. This is a VERY difficult problem to fix (without breaking or melting something else inside the case) and also usually means it is time to get another MP3 player.
Nov 07, 2011 | SanDisk Sansa Clip MP3 Player
When i play music there's no sounds the media volume is in max and it is not in silent mode.. but when i connect a headset the sounds works fine... Whenever I try playing music on my LG Optimus S Sprint...
check the settings of the player of your.the output must have been muted.so just unmute.if that is not it goto www.mobango.com to download mp3 and mp4 player install it and use it
Feb 03, 2011 | Cell Phones
I transferred music to my mp4, however I cannot hear it when it plays. I know it was transferred correctly, but the music bar moves/plays but no sound is heard. My headphones are new.
Try a different set of headphones, if there is still no sound, check the volume limit on the iPod: http://support.apple.com/kb/TA38403?viewlocale=en_US
if that still does not help try resetting it by pressing the MENU and PLAY buttons simultaneously for a couple of seconds, I hope that did work. But, if it didn't, try doing the diagnostic in it to find out if it is a faulty jack: http://www.wikihow.com/Hack-an-iPod-Nano-3G Hope it is just headphones!
Jan 19, 2011 | Apple iPod nano
2nd gen touch (model mb528ll)internal speaker stopped after OS upgrade to v3.1.1. Headphones plugged in work fine, butwhen they are removed silence reigns. How do I get back the internal speaker after the...
My guess is it's a faulty upgrade, unless you aren't adjusting the volume after you take the headphones out (when you take headphones out, music stops, and the volume changes).
Try restoring it. If it still isn't working after that, try re-downloading the os 3.1.1 update. It could just be a corrupted file, and it does sound like it.
Sep 28, 2009 | Apple iPod touch
Ipod touch music wont play, built in speaker works fine
Restart your ipod by holding the home and power button at the same time, this will restart it and should fix it.
Aug 12, 2009 | Apple iPod touch
I recorded analog music on md.now how can i transfer analog music to pc and chanege it to digital music on memory of pc.
Your analogue music will have been recorded digitally by your machine.
Digital transfers are only possible from the host pc/Mac to the player and not the other way around.
But you can transfer the audio signal by connecting the headphone output to the Mac audio input; look into the Minidisc player menu and you can set the headphone socket to "line" which bypasses the volume control circuits for better quality, your computer will then re-convert the analogue input into a digital signal with a small loss of quality.
May 04, 2009 | Sony Net MD Walkman MZ-N510 MiniDisc...
Headphones don't work right.
It might be that the contacts for the headphone jack is very dirty. Try using a cotton swab with a wd-40 on it to clean the inside contacts on the jack.
Jan 03, 2009 | Music
Sound Problem with Headphone
First try the headphones in a different machine, such as an mp3 player or cd player to make sure the headphones still work.
Try going to the start button, then settings and control panel. Then select "Sounds and Audio devices" Down at the bottom you should see "Speaker settings." Click the "Advanced" button and then select stereo headphones.
Then, place the headphones into the green audio jack (or the headphone jack up front if you have them), play some music, and then gently wiggle the jack to see if some of the sound makes it into the headphones. If not, try slowly pulling the headphones out of the jack while the music is plaaying. you might find that the jack has slipped a little and may play only if your connector is slightly pulled out or more firmly pushed in. If his helps, then your audio connector is loose and you should replce the sound card. If the card is on the motherboard, you can disabled it when you put a new card in.
Jul 09, 2008 | Compaq Presario 700 470024-192 Notebook
NO sound??
Make sure the volume is turned up sufficiently. If it is, then get it exchanged if still in warranty.
Apr 03, 2008 | Philips GoGear HDD1850 MP3 Player
Zen stone mp3player....works but wont let me play music..
Here are a couple suggestions. Did you load music on? Do you have headphones in? Tried turning up the volume?
Feb 18, 2008 | Creative Labs Zen Stone Plus MP3 Player
Perception Digital PD-2000 (20 GB) MP3 Player Logo
21 people viewed this question
Top Perception Digital Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Perception Digital Audio Player and Recorder Expert? Answer questions, earn points and help others
