Question about Navico Simrad Tillerpilot TP20 ()
Hi - I have a Simrad Navico tp20 and used for the first time today the tack function, it worked fine for a couple of times then on one tack, pushed the tiller hard over (as expected) but then 'stuck' into that position. I tried switching the instrument on and off as well as manually setting the position without success. I switched the TP20 off again and tried pushing the rod back in gently, again without luck - it seems to be stuck pretty well. Also, when I tried manually adjusting course I could hear the usual kind of noise coming from inside the TP20 , just without the movement of the rod.
  • Peter Ljungdahl Aug 03, 2013
    The above happened to me, today :-(. Any solution?
Turn on normally, go to press auto.... nothing
Hi Ty
This sounds to me like a cabling problem. There is enough "horsepower" to turn the unit on, but the increased current required to actually run the thing isn't as robust as it needs to be.
I would start by checking the connections at the panel or battery. Make sure these are absolutely pristine. (i.e. Clean and tight) Pay particular attention to the terminals and/or crimp connectors, whichever are used. It doesn't take much corrosion here to render the autopilot inoperable. Let me know how you make out.
-Steve
Apr 14, 2015 | Navico Simrad AP16 Autopilot for Inboard...
My Ap16 Simrad control head died. Any idea of as to 1) where I might get it repaired and/or 2) where I might find a replacement?
Hi John
Boy, you're up against it on this one. The AP16 is a pretty old unit for sure. Here's the link to your owners manual.
I've come across one instance in my experience where although there was enough power showing to the control head, because of corrosion and broken wire strands, there simply was too much voltage drop and not enough current flow for the unit to function when it was turned on. After cutting back/fixing the soldered connections and reconnecting the cable, the unit was good to go.
I hope this information is able to help you out.
Good luck.
-Steve
http://www.simrad-yachting.com/Root/Operator%20Manual/SimradYachting/English/AP16_OM_EN_20221560F.pdf
You MIGHT get some joy contacting Simrad tech. at 1 800 628 4487
if you're in the US. If not, here's the link to their support page.
http://www.simrad-yachting.com/en-US/Contact-Us/
Dec 08, 2014 | Navico Simrad AP16 Autopilot for Inboard...
I recently bought a Navico AxisRT1400 VHF but need a operaters manual .
This is the link where you can be able to view the manual I hope this works http://www.busse-yachtshop.de/pdf/simrad-dsc1400. Let me know if you have any problems downloading it.
Aug 13, 2011 | Cell Phones
Pressing the button to position the tiller to connect to the helm, the reaction is a little bit ahead or back pushin the button. Before it continued to go forward or backwards by simple pushing until the...
you need a trained repairman to check it out for you. Likely it may cost a few dollars, but steering is too important to mess around with amateur fixings attempts.
Mar 08, 2018 | Navico Simrad Tillerpilot TP20 ()
Need a service manual for a Navico 8000 auto pilot where can I download same thanks
Hi, I have found this link, its american, let me know how you get on!
http://www.marineelectronicshoppe.com/Manuals/Simrad/Autopilots.htm
Jul 26, 2010 | Boating
Does anyone know where I can get a unit repaired?
Were you able to get your TP20 repaired? I service these units in addition to the Navico Corus instruments and pilots. I also buy and sell units to help owners keeps their systems functional.
Tom LaMers
tlam45387@aol.com
Jun 05, 2010 | Navico Simrad Tillerpilot TP20 ()
Simrad Autopilot won't turn on
Try and turn on the unit at the J300-40 pcb by using a test light one end to gnd and going to the ap35 interconnect and touch the test light to each pin or until you hear the unit start up.
Dec 19, 2008 | Simrad AP35 GPS Receiver
I purchased a second hand Miranda TP20 tripod from a charity sale for a few pounds. The screw plate mounting is missing fromn the top of the tripod - where can I purchase the part from?
the giottos 6E01 quick release plate will fit snug. i bought one for my miranda tp20 today. you can get them from harrison cameras or warehouse express.
Nov 06, 2008 | Vivitar Pink Vivicam 3188 Camera Great...
Navico Simrad Tillerpilot TP20 () Logo
112 people viewed this question
Top Navico Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Navico Boating Expert? Answer questions, earn points and help others
