I have a toshiba 3511 and its calling for service. What does this mean is it gonna need drum blade developer, is there a way to reset that. What can I do to fix this, the machine also wont print . thanks
  • 10,515 Answers
Press ' clear ' + 8 when ' call for service ' appear. It would give you a number code. Kindly revert with that number so that we could check what's wrong with the machine.
Thanks!!
Posted on Nov 12, 2010
Mintenance call m2
M2 means Time to replace your consumables (drum,developer,cleaning blade,drum charge assy & cleaning pad) after replacement reset it to Tech rep mode.
Oct 28, 2014 | Konica Minolta Office Equipment & Supplies
How clear Maintenance m2 call service this konica 164
M2 means maintenace time you have to replace 1) developer 2) drum 3) cleaning blade 4) drum charge unit and reset the maintenance counter / calibrate the ATDC. After you than that READY TO COPY will appear ;-)
Oct 17, 2014 | Konica Minolta Office Equipment & Supplies
CAUTION MAINTENANCE CALL (M2) CALL SERVICE
Replace the developer and drum/cleaning blade. Also reset the counters after replacing parts then run F8. resetting the counter with out replacing the above items cause image problems. The copier uses the counters to determine voltages on the drum you tell the copier drum is new and it is still old will cause problems.
Sep 18, 2013 | Minolta bizhub 180 Black and White Copier
The developer box does'nt keeps toner in it, is it probably because of already 'old developer' or do i need to add some developer...how much is developer? Mine is toshiba e45. Thanks a lot.
Hi
The developer life span is about 150.000 copies, then it should be replaced.
If the developer has not done 150.000 copies then there could be another problem.
The cost of the developer is about R1000.00. {in South Africa}
Please remember that the life span of the drum and drum cleaning blade is also 150.00 copies, so the developer, drum and cleaning blade should be replaced at the same time.
Regards
Apr 12, 2011 | Toshiba e-Studio 45 Black and White Copier
E-Studio 3511 Color Copier written in the screen call for service total counter 372278, how can i solve this problem?
hello
we have like that message before in our copier also but the only thing i did is shutdown and start again and i reset the counter and it goes fine.
make hard reset remove all the power cable and plug again.
thanks
Mar 15, 2011 | Toshiba E-Studio 3511 Color Copier
Toshiba estudio 167 - time for maintanence appear so what can i do??
hi
you need to replace some parts on the copier (consumables)
KIT - 2340 Developer Maintenance Kit - Kit Includes: Drum Blade, Recovery Blade, ( 2 ) Drum Picker Finger, Main Charge Grid, Main Charge, ( 2 ) Transfer Separation Wire, Developer - Genuine Toshiba Part -- resells for about $240 , youc an buy this at any online store .. example , http://www.precisionroller.com/maintenance-kits-for-toshiba-e-studio-166/details_57969.html please rate me 4 thumbs up
Dec 29, 2010 | Toshiba E-Studio167 Copier
En toshiba e-3511 sale codido de error CEE0
CEE0: Transfer belt position detection abnormality (normal speed):
The home position of the transfer belt cannot be detected.
This likely means that your transfer belt has gotten ripped. There are reflective strips on the transfer belt that tell the copier what position the entire belt is in before copying, and when the transfer belt gets ripped it causes the machine to not be able to find these strips.
You will need to replace the transfer belt and it would be a good idea to change the belt cleaning blade as well.
Aug 30, 2010 | Toshiba E-Studio 3511 Color Copier
Estudio 3511 in storage for 6 months
hi do u have try to refix your developer unit i mean just remove and re fix it again thanks
May 11, 2010 | Toshiba E-Studio 3511 Color Copier
My e-studio 45 has 260,000 copies and says it needs maintenance. It works well. Do I just replace the drum or does it need other parts like a fuser too?
Hello sir; When it said need maintenance, it means need PM( periodical maintenance) that including drum, drum blade ,developer, corona wire, etc. the fuser and pressure roller depend on condition.
Feb 01, 2010 | Toshiba e-Studio 45 Black and White Copier
Toshiba e-studio161 Developer
Technical Service Procedure
Correct procedure for service of TOSHIBA e-Studio 161
When the spanner light and the developer (sun) light are illuminated it is time for a service.
* Try and run the PM Service and drum life counters together.
* Part that are required for a 50,000 copy service (OD 1620 DRUM, D1620 DEVELOPER, BL1620D DRUM BLADE)
* Clean and inspect drum unit.
* Clean all optics and glass.
* Clean and rewire transfer corona.
* Clean and check main charge needle electrode [saw tooth]
* Clean and check fuser units including blades, rollers and scraper fingers.
* Clean erase lamps and ozone filters.
* Clean and check all feed rollers.
* Clean machine inside and out.
* Replace the required parts.
* Reset mini maintenance counters:
* [CLEAR] > [EXPOSURE] > [CLEAR ]> [EXPOSURE] and the machine will die.
* Input [20] [START] [01] [START]“000””000” will flash on the display.
* Reset the drum life counter:
* Input [24] [START] [07] [START] "000"000" will flash on the display
* Reset developer life counter:
* Input [42] [START] [01] [START] “000””000” will flash on the display.
* Once all the part have been replaced and the counters been reset, check the copy quality.
* Notes: Application of the patting powder is for reducing the friction between the drum and cleaning blade. If the application of
patting powder is neglected, the drum and cleaning blade may be damaged. Please clean off the patting powder before putting the
cleaner unit into the machine.
Developing doctor gap adjustment
1) Loosen the developing doctor fixing screw A.
2) Insert a thickness gauge of 1.5mm to the three positions at 20mm and 130mm from the both ends of the developing
doctor as shown.
3) Push the developing doctor in the arrow direction, and tighten the developing doctor fixing screw. (Perform the same
procedure for the front and the rear frames.)
4) Check the clearance of the developing doctor. If it is within the specified range, then fix the doctor fixing screw with
screw lock.
* When inserting a thickness gauge, be careful not to scratch the developing doctor and the MG roller.
CHANGING A TRAY’S PAPER SIZE SETTING
Follow these steps to change a tray’s paper size setting.
* The paper size setting cannot be changed when the machine has stopped temporarily due to running out of
paper or a misfeed, or during interrupt copying.
* During printing (even in copy mode), the paper size setting cannot be changed.
* A5 (ST) size paper can only be selected in upper paper tray.
* Do not load paper that is a different size than the paper size setting. Copying will not be possible.
Hold down the [PAPER SIZE ENTER]
key for more than 5 seconds to
set the selected paper size.
The currently selected
paper feed location
indicator will blink and
the corresponding paper
size (which is currently
set) indicator will light
steadily. All other
indicators will go out.
If the machine has two paper trays,
use the [TRAY SELECT] key to
select the paper tray for which you
wish to change the paper size setting.
Each time the [TRAY
SELECT] key is
pressed, a paper tray will
be indicated with a
blinking paper feed
location indicator.
Use the [ORIGINAL SIZE ENTER] key
to select the paper size.
The indicator of the
selected paper size lights
up.
Apr 11, 2008 | Toshiba e-Studio 161 Copier Copier
26 people viewed this question
k24674
