Question about Refrigerators
GE ESS22XGMCWW side by side, water line broken and leaking, need to replace hose. Looking for detailed schematics for water system and parts information.
  • jaking Jun 17, 2008
    That showed the general schematics, but what I really need is detail on part number 800 show on the schematics and how the hoses connect, not the water hose in, but the 2 hoses that hang off the bottom
    That showed the general schematics (closed system and motherboard link), but what I really need is detail on part number 800 show on the schematics and how the hoses connect, not the water hose in, but the 2 hoses that hang off the bottom of the part.
    What I really need is an understanding of how to remove the existing hose which is cracked, shorten the hose, and reattach it.
    Master:
  • 638 Answers
Want a technician at your place we can provide it for you.or call the technician by yourself the perfect solution.it does not seem you could repair this problem without the help of a technician at your place.
Posted on Jun 18, 2008
  • hemant somaiya
    hemant somaiya Jun 18, 2008
    rate the solution as fixya if this helped youany way.
    Sniper:
  • 114 Answers
The broken line more than likely has a band clamp keeping the hose from coming off. if you remove the band clamp on the broken hose, you will need to go to the hardware store and look for a small screw clamp to replace it. there may or may not be enough slack in the hose to pull it to where the leak was, check to see, if not, then the hardware store might also sell a hose that could work, but in that case, you will need two screw clamps to hold the hose down on both sides.
Posted on Jun 17, 2008
  • 2,071 Answers
Jaking i only get you a site where you download about the GEESS22XGM www.fixitnow.com
    Genius:
  • 3,422 Answers
Please CLICK HERE and browse the sub components and you'll see the diagrams.You can also order for a service manual if you wish to.
Goodluck..
GE side by side leaks water from underneath when you use the water from front door
you need to remove the toe kick panel grille below the front doors on the refrigerator behind this grille there is a connector and it can come loose,also possibly the water valve in the lower rear behind the back panel can leak,have a helper press the door paddle for water and check all these areas for leaks,if it leaks from the door stem where the water line goes up the door to the dispenser,then you will need to pull new hose up to the dispenser from the collar mentioned at first,some refrigerators can not have new hose installed due to the door has been foamed internally at the factory and cant be dis-assembled,then you would need a new door with the hose installed
Apr 08, 2013 | GE (PSS26MSRSS) Side by Side Refrigerator
Water leaks from underneath my washing machine. how do I fix it? the hose is connected properly, too
Water leakage
1. Inlet hose loosely connected to valve---tighten hose connection
2. Drain hoses not tight on pump----tighten hose clamps
3. Broken hose---replace hose
4. Leaky gasket---replace gasket
5. Cracked housing---replace part
Sep 22, 2011 | GE Washing Machines
Failed the emissions test (Il..) code came up P1441. After researching code translatons it means: evaporative emission system flow during non- purge. I called advanced auto parts( because that or any code...
ok looking for evap leaks are sometimes hard a vary small leak will cause you grief you can try to pressure up your fuel system with air hose to fuel filler opening 3 psi max , don't blow your self up , get a garden sprayer and dish soap with water and start spraying down the evap system look for bubbles and fix the leak
Mar 27, 2011 | Buick Park Avenue Cars & Trucks
I have a ge Profile side by side refrig model TPX24PR or BR or BI or SI. When we call for water or the ice maker calls for water, I can hear a hissing sound coming from the front right corner and then...
That hose actually ran Through the floor of your refrigerator on your model. so the leak is most likely under the floor of the fridge in the line coming from the water reseviour to the outlet.
Jun 10, 2010 | Refrigerators
GE Profile Arctica refrigerator - water is leaking from the bottom of the solenoid where the plastic hose goes up to the water filter (on the outside of the refrigerator.
Turn off the water supply and check for cracked or broken water tubing/line. Make certain that there is teflon (white) tape on threads connecting water inlet hose from shut off valve at wall to water valve at refrigerator. If there is no apparent damage to tubing or hose, then your problem may be with a water valve solenoid that is not seating/closing tightly. Replace the water valve assembly, if necessary.
Note: If plastic tubing is damaged, etc., you can splice the tubing with a "coupler" and/or more tubing purchased from Home Depot or Lowe's.
Feb 19, 2010 | GE Profile Arctica 25.4 Cubic Feet...
A hose is leaking on G.E. fridge - to water dispenser, I think
It sounds like someone has repaired this hose , due to the connectors . There should be no connectors except for 1 , below the freezer door . This hose can get hot from the compressor heat , and break .
My suggestion , would be to replace the water resivoir in the refrig section , behind the bottom crispers . This resevoir has a hose that goes completely to the water valve , without any connectors , and a hose that goes to the coupling under the freezer door , for the water dispensor . If you remove the bottom kick plate , the hose from the door , goes about 8 " to the coupling which connects to the line from the resevoir .
Sep 28, 2009 | GE Refrigerators
Found a leak behind fridge,plastic hose is seperated
There is no connector . The plastic line pushes into the valve . If enough line is there , remove the short piece from the valve by pushing in on the white ring while pulling out on the broken line , and insert the main line into the valve with a little force . Check for leak by using water dispensor.
Aug 11, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Water line leaking
unscrew the back panel and look if the plastic hose for the water (on the left side, goes to the blue/red valve block) is broken. If it is then you can buy a silicon tube or hose in a hardware store which fits on both ends (measure the diameter) you also need to buy two metal rings with a screw (don't know the name of these) which you can put over the connection to tighten it. The old hose has become very brittle in my case and this solved the issue
Feb 09, 2009 | GE GSS25LGM Side by Side Refrigerator
Refrigerators Logo
62 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
