Question about SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive
I accidently deleteed the sandisk cruzer 1gigs folders with the formatting software in it it now only holds about 157mb of useable memory space how can i reformat it?
  • 734 Answers
Hi There,
I recommend you insert the SanDisk and go ahead with the OS Disc as though you were going to reformat again. When you get to the opportunity to manage drives, choose the SanDisk and reformat it as FAT32. This shold return it to normal.
Or, after inserting the drive to USB, enter Administrative Tools through Accessories>System Tools from the start menu, choose Disk Management from the menu you will see and reformat from there.
Best Regards,
Selk
Posted on Nov 12, 2010
My sandisk cruzer 4 GB pendrive ws working fine but now whenever i try to format\copy\cut it shows location 0 with used space 0 free space 0 what should i do
Your flashdrive usually shows 2 drives when inserted to your computer, one is the U3 drive and the other one is the removable disk drives. U3 drive is your separate partition for the U3 system and in order for you to store, copy, format your flashdrive, you should be selecting the removable disk drive, not the U3 drive. U3 is a read only memory drive that is responsible for your U3 to work (just like portable applications). Hope this helps.
Jul 04, 2011 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
SanDisk 2GB Cruzer USB Flash Drive has 163 documents on it and they're pretty long. I tried to put more on but it say that it cannot be put on, and that it is and error, nothing's wrong with my PC. I'm...
There isnt really a limit of the number of files, but there is a limit on space.
If you go into "my computer"(windows xp) or "computer" (windows vista/7)
and right click on the icon for your SanDisk. Choose properties, and it should give you a nice pie graph to show your free space.
If there is free space left, then it is safe to say that there is something else going on.
If not, you are out of space!
Cheers!
Feb 23, 2011 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
I'm unable to find some important data stored in my Sandisk micro cruzer. I'm not sure if I accidently deleted it or if it is corrupted. Please suggest if there is a way to recover the files.
If the pen drive is working, the data is there and can be recovered. I think it could be due to virus activity. Some virus make the contents of the drive hidden, thats why user can't see the files and the space available for use is less than the capacity.
It is suggested that go to FOLDER OPTIONS - and select SHOW HIDDEN FILES. It may show the hidden files. Otherwise, you can use any data recovery program to recover the data. Please not that you should not sav/write any data to avoid overwriting the existing data.
Hope this helps!
CreativeTECH
Feb 14, 2011 | SanDisk Cruzer Micro 2GB USB 2.0 Flash...
I can't remove U3 launchpad
I have had a similar problem to this one. It is relatively easy to fix. Step 1 - Backup any files that you want to keep from your SanDisk. Do this by going into my computer and clicking on the SanDisk removable hard drive. Drag and drop the files you want onto a folder on your computer. Remember - If you back up everything BE SURE YOU DO NOT BACKUP THE U3 LAUNCHPAD SOFTWARE. Step 2 - Get into your My Computer folder and right click on your SanDisk removable storage device and select format. After you format everything should be removed from the memory stick. Step 3 - Drag and drop the files you backed up back onto your memory stick. Done! Hope that helps.
Mar 16, 2010 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Sandisk cruzer 2gb flash drive
Reset the whole memory stick via the PC should jog the memory and make it work.
Jul 07, 2009 | SanDisk Cruzer Micro 2GB USB 2.0 Flash...
I have the exact same problem.
Fat32 File system is limited to just under 4 GB. I've tried to format using a different file system but no success.
This isn't really a solution but at least it explains what's happening.
Jun 07, 2009 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
I have a SanDisk Cruzer USB 8GB that is only allowing me 1.33 GB of space - says 6.594 GB used and there's nothing on here - how do I gain that storage space back? tx
There might be a hidden file(s) on the drive that are taking up that space. Open the drive in My Computer, click Tools > Folder Options... On the View tab, click Show hidden files and folders. Then check the drive to see if any hidden files or folders are present.
You can also try formatting the drive. Right click the drive in My Computer and click Format...
Mar 23, 2009 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
Sandisk Cruzer Micro U3 memory problem
did you try uninstalling the U3 software?  when the u3 launchpad comes up, there should be an options link, look in there for the uninstal button.  Once you take off U3, you can't put it back on.
if you want even more space, AFTER UNINSTALLING U3, take everything you want to keep off of the drive, and put it on your computer.  make sure you remember where it is.  then, in My Computer, right-click the drive, and click Format.  for the File System box, select FAT32, make sure Quick Format is checked, then click the format button.  Make sure before clicking that button, EVEERYTHING YOU WANT TO KEEP IS OFF OF THE DRIVE!  YOU WILL BE UNABLE TO RECOVER YOUR DATA ONCE YOU FORMAT THE DRIVE!
Hope these tips help
Oct 18, 2008 | SanDisk Cruzer Micro MP3 Player
SanDisk Cruzer storage
Check the format. Make sure it's compatable with the operating system. Also check the size of your documents folder. If they are compatable, maybe there is something wrong with the flash drive.
Aug 22, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Mac user with sandisk cruzer, no room & no way to format.
you guys have to empty the trash can or
1. open applications
2. open utilities
3. click on disk utility
4. locate the drive, left hand side
5. select the drive
6. click on erase
7. select file system, either MS-DOS or Mac OS extended.
have fun =D.
Jul 24, 2008 | SanDisk Cruzer Titanium 2GB USB 2.0 Flash...
SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive Logo
63 people viewed this question
Top SanDisk Computers & Internet Experts
Sandy Moore
Sandy Moore
Cleverer2
Are you a SanDisk Computer and Internet Expert? Answer questions, earn points and help others
