Question about GE JGRP17 Gas Single Oven
My oven keeps shutting off what i am doing and beeping f7
  • 2,382 Answers
Hi, Error F7 on your oven means that the keypad is shorted or stuck and to resolve this issue you'll have to replace the Electronic Range control (ERC).
Posted on Nov 12, 2010
What do I do about oven beeping?
Could be control module, but not sure. I had issues with a code a long time ago, and the broiler kept coming on and wouldn't shut off, so finally had to shut it off at the breaker. Turns out the control module is fried. But just a thought.
Apr 28, 2015 | Kenmore Double 27" Electric Built-in Wall...
F7 and beeping
oven starts to beep and shuts off. I shut the circuit breaker off and it re sets itself and hopefully when I power it up it will start to work. We have replaced the front panel and all th PC boards and reset the reset button behind the panel. If there was a was that I could disconnect the shut off that's built in I would keep the oven.
When this oven work, it's great however at this time i am losing patience and maybe I should toss it out and get a new oven which I really don't want to do!
I am very capable of taking it out and opening up the panel an re setting all the boards once again if that would help? Thermador has had a recall on this unit as some people claim it will overheat and go on fire? The stove has little mileage on it and we would like to keep it but if you have a way of fixing it or if not we would love to hear from you! .
Mar 20, 2011 | Thermador C302U Electric Double Oven
JKP15 Electric Single Oven: Oven keeps beeping with F7 error...
F5 Loss of relay drive circuit If this fault code cannot be cancelled, replace the oven control (also called clock or ERC).
May 07, 2010 | GE JKP15 Electric Single Oven
The F7 code appears with a beeping noise. How do I turn off the beep for good.... selecting clear/off only works for a few seconds
Well, F7 error code occures due to
A = Function pad button stuck or
B = Bad clock Unstick button or
Replace Electronic Range Control (ERC)
Replace the ERC there are ten screws 3 on each side and 4 on the control leave the hex screws alone all you need is a phillip screwdriver.
REMEMBER TO SHUT OFF THE POWER FIRST lift and fold out the control panel remove the ribbon cable and remove the four screws that hold the control board . replace control panel in reverse order.
Thanks
May 27, 2009 | GE Built-In 24" Double Electric Wall Oven
Double GE wall oven - F7 code
from repairclinic.com:
F7 A = Function pad button stuck or
It looks like you have a function button pad stuck or a bad clock.
Unstick button or replace electronic range control.
Apr 27, 2009 | GE Ovens
F7 beeping an cannot stop it... any solutions?
HI, if this error code cannot be canceled, this will confirm a touch pad issue. the membrane is damaged and, this will require you to replace the ERC.
Replacing the Electronic oven control will fix this issue.
Mar 29, 2009 | GE JKS05 Electric Single Oven
GE JKP15 Electric Single Oven - Code F7
If possible i will need the letter that come next after the JKP15.
Aug 19, 2008 | GE JKP15 Electric Single Oven
GE Profile Stove
I used what Charlie recommended ...” post-it” as insulation
And works PERFECTLY….
I have a Kenmore oven Clock…( built in the wall)
Thanks Charlie…you are a Genius!!!!
Jul 15, 2008 | GE JKP15 Electric Single Oven
F7 Error on the above range
There is a fix for the F7 error. Search for Powerman + GE + F7
Apr 27, 2008 | GE Profile JT910SASS Electric Single Oven
F7 error code
f-7 means either the touch pad is stuck or a relay on the control board is stuck. if the code came up while the oven was not being used then the touch pad is shorted. if it came up while in use then the controlboard is bad
Nov 22, 2007 | GE JGRP17 Gas Single Oven
GE JGRP17 Gas Single Oven Logo
140 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
Are you a GE Oven Expert? Answer questions, earn points and help others
