Question about Cuisinart SPB-7 SmartPower Work Top Blender
WHEN I USE MY CUISINART BLENDER, THERE IS LIQUID COMING OUT OF THE BASE OF THE JAR.
barbara46219
SOURCE: replacement jar for hamilton beach wave 50754 blender
Check out the www.goodmans.com. The company is out of Florida and they do not charge sales tax outside of Florida. They have a variety of blenders for sale as well as blender parts. I hope this will help you.
Posted on Mar 13, 2009
SOURCE: parts for cuisinart blender trio model bc-56
GO TO:
http://www.smallappliance.com/department.asp?cur=USD&sid=18954&mid=8&shopBy=Brand&cam=cuisinart_parts&gclid=CJTy7Om5qZoCFRk_awod9Gjw1Q
FOR CREDITS MAIL BACK TO: NEFIUINC@MSN.COM
Posted on May 07, 2009
co7196
  • 3433 Answers
SOURCE: blender leaks
Well, that's not good. Call the manufacturer and they should be willing to dend you one. Good luck.
Posted on Jul 21, 2009
SOURCE: GE Blender Jar loose rotator
Remove the bottom clean the unit fully. Add the bottom blad assebly and this will fix your problem. The "sooty" is plastic shavings. Take note that the fitting were the "jar" connects to the motor that this is not wearing away. The unit i have broke and i am unable to find a replacement blade assembly.
Posted on Aug 13, 2009
  • 7 Answers
SOURCE: Plastic pieces on glass jar and base are worn out and shaved down
I did the same thing. Order parts at thegourmetdepotco.com -- This problem is caused when you put the rubber gasket underneath the blade instead of above it. This causes two problems: 1. It lifts the teeth on the jar away from the teeth on the drive gear, which can grind down and break off the teeth, and 2. If the drive gear contacts the rubber gasket, it will melt the rim of the drive gear. In the future, to reassemble the jar after cleaning, first put the rubber gasket on the jar, then the blade, lastly screw on the base ring.
Posted on Jan 26, 2010
How do I remove old blade?
Hi Paul,
There is a collar on the base of the jar that screws onto the jar. You will need to unscrew the collar and fit a replacement blade. make sure the seal is replaced with the blade and the collar is screwed back securely.
See this link for the parts of the blender.
CUISINART CANADA SmartPower Premier 600 Watt Blender CBT 500C
Also see the product description for the blade.
https://www.youtube.com/watch?v=rdBxUAsT_TQ
Mar 04, 2015 | Cuisinart Replacement Cbt-Bg-1 Blender...
Blender Base is stuck and won't budge
Please use the WD-40 and let by 1 hours, and ready.
God bless you
Nov 06, 2013 | Cuisinart SPB-7CH-LR Blender Jar Base
Why does my blender leak?
hi,
sounds like the bearing assembly went, right where the motor connects to the blade, you can get a replacement base from them, have to find the model number and go to their website. doubt you burnt it up. cuisinarts supposedly are commercial quality.
jm
Jul 20, 2017 | Cuisinart SPB-7CH SmartPower 40-Ounce...
Misplaced manual. How to assemble Cuisinart Smartpower 7 speed electronic blender- Specifically need to know where to place the gasket.
Hello, W/D here.
You can download your manual here:
http://www.cuisinart.com/manuals.html
It is at the bottom of the page.
On page 4 of the manual is the instructions for assembly of the jar. With the jar upside down, lay the gasket on the threaded area, insert the blade/plate, and screw on the base. Nothing to it.
Best regards, --W/D--
Jan 30, 2011 | Cuisinart CBT-500 SmartPower Premier Work...
My Cuisinart blender start leaking after a few months of use.
Here is a list of things to check for:
1. Make sure the blender base (black plastic) is tight to the jar.
2. Make sure you have installed the rubber washer between the blender blade assembly and the jar.
3. Make sure your rubber washer is free from any crud that may have accumulated and dried on. You may have to soak the washer and gently scrub with a scrubber sponge. If it's really cruddy you may have to repeat as necessary.
4. Make sure you have not caught any water (or other liquid) when filling it between the base and the jar. When you pour out the contents it will appear as if it is leaking.
Mar 22, 2010 | Cuisinart BFP-703 SmartPower Work Top...
Blender container leaks even though gasket is in place
Hey, I know this is an old thread but just had the same problem and solved it. With the blender container upside down, place the gasket on the jar hole, put the blade through the hole on top of the gasket, then screw the plastic base on top of that.
The way I had done it before was to pop the blade into the bottom of the plastic base first then screw it onto the gasket and jar but it goes on the gasket, not under the bottom of the base. Hope that helps anyone else in the future.
Also just read the manual instructions like I didn't, clear as day right there but I never bothered to read them ha
Oct 18, 2009 | Cuisinart CB-600 Blender
Clutch on the jar of my cbt500 cuisinart blender is broken.
The clutch assembly is for the teeth on the base itself. If your problem is with the teeth that are connected to the bottom of the blade that sits in the jar, you want to order a blade assembly instead.
-Tha Mp3 Doctor (also loves Cuisinart)
Mar 21, 2009 | Cuisinart Blenders
Cuisinart bc56 blender
how to get the base off the glass container. turn in what directionss it seems stuck
Feb 27, 2008 | Cuisinart CBT-500 SmartPower Premier Work...
Broken gear on BFP-703 base
The drive is replacable and available from Cuisinart, you will have to sign a waver to get the part. the drive is screwed onto the motor shaft with reverse threads. the plastic drive will have to be completely broken off of the unit to expose a brass"nut" which was internal to the drive. depending upon your model you may have to remove the lower half of the base unit to access the lower part of the motor shaft. there will be a slot in the end of the shaft for a large flat blade screwdriver. this is used to hold the shaft still while turning the drive "nut" with a vice grip pliar or similar. the new drive is just threaded onto the shaft and normal operation tightens it.
Feb 14, 2007 | Cuisinart BFP-703 Blender
Cuisinart SPB-7 SmartPower Work Top Blender Logo
251 people viewed this question
Top Cuisinart Blenders Experts
Hjalmer Lamminen
Hjalmer Lamminen
Oloyede Monsuru
eyecam
Are you a Cuisinart Blender Expert? Answer questions, earn points and help others
