Question about Arrilite 650 Watt Open Face Tungsten (571065) Light
We have a Arri 650 plus and 10 - 30 minutes after its powered up it goes off and does this consistently. i don't believe heat is an issue because it went off after 5 minutes today after powering up.
  • 3 Answers
Visit http://www.filmandvideolighting.com to find out how to replace the bulb
Posted on Jan 22, 2014
Bryant 330JAV won't restart after power outage. Very tight space. Need to know what to do before we try to get in. Happened before. Believe tech flipped a switch. Any suggestions appreciated.
Sometimes killing the power to the furnace by flipping the breaker off for 30 minutes and then back on will let them reset and start. don-ohio
Jan 21, 2017 | Bryant Heating & Cooling
Pacemaster Pro Plus treadmill popping fuse
You need to replace the walking belt. Don't use the machine until you've replaced that.
May 22, 2017 | Exercise & Fitness
Pentair MiniMax Plus 250 Off and On
To answer your question....... ensure all flow is good, cleaning the filter, and correct speed if you have a variable speed pump (typically 2500rpm)
If the flow is good and this is happening then it could be the thermal regulator which is on the header of the heater where the water goes in and out. They can get a build up of scale and or corrosion which causes an internal flow issue and can overheat the heater.
The heater also has high limit sensors which will shut the heater off when it gets too hot.
You will want to make sure to get this fixed to avoid melting of the plumbing or internal damage of the heater.
Mar 29, 2017 | Pentair Minimax NT Heater
Sound keeps turning off after ten muients
I've had this problem with other sound equipment. For me, it was a heat issue and there was an auto shut off feature to save the unit from over heating. I would especially think this is the case if it turns back on without problem after another 10 minutes of being off.
You could try turning off phantom power if it isn't needed to run your mics. Or making sure it is in a spot that allows maximum air flow through the head.
Hope this helps! Don't forget to rate!
Jun 26, 2012 | Phonic Powerpod 740 Plus S715 PA System
I have a Sanyo DP46849. The screen goes black and then the sound and picture comes back on after one or two seconds. This happens every three to four minutes. What is failing?
I see so many here with no sound/nopicture issues:
ISSUES:
1. IF sound main fuse/s are good.
2. If no power or standby check main fuse, standby power supply and any signsof damage you can see---burnt parts etc.
3. almost all these sets the troubleshooting involves checking voltages on the main power board to narrow down theproblem.
4. Be safe and if you do not know what you are doing don't open the set.
Answers to issues:
1. RE:fuses---if a blown fuse is found get a good replacement(not the genericones like Radio Shack). Many fuses are special even aside from amperage--Don'tput a higher rated amperage fuse in the set for any reason.
2. RE: power supply in set: if total dead aside from main fuse the set uses astandby power supply that runs 7/24 and a main supply (some are combined andsome not.
Here aside from checking fuses you want to examine all the filter caps on thepower/standby to see if any are puffed up or buldged up in some fashion--Iattach a photo of a good one---top should be silver metal and PERFECTLY flatand have no brown material coming out on top or bottom.
What happens in the standby area is they use caps with too low a voltage rating(saves money) which causes them to fail in a year or two---the standby runs7/24 and the heat dries out the caps and they fail.
3. Trouble shooting consists of the above and then at some point you have to buyand try a board to see if it fixes it or not.
4. Safety first--no TV set is worth getting injured or even killed over.If set is opened at least look for puffed up and bad caps like in thisphoto.4_23_2012_4_23_50_pm.jpg
Apr 22, 2012 | Sanyo 42 in. LCD TV
My lcd 1080 proscan tv shuts off after a minute
ISSUES:
Answers to issues:
3. Trouble shooting consists of the above and then at some point you have tobuy and try a board to see if it fixes it or not.
4. Safety first--no TV set is worth getting injured or even killed over.4_2_2012_6_14_05_pm.jpg
Apr 02, 2012 | Proscan 40LD45Q TV
How to replace a lamp in Arri 650?
Visit http://www.filmandvideolighting.com where you can find help on the replacement!!
Oct 18, 2010 | Arrilite 650 Watt Open Face Tungsten...
Starts and ticks over fine for about 1 min then cuts out
I believe you are stating when you start the vehicle you hear a ticking sound from the motor. After a few minutes it goes away. I ahve 2 grand vitara's. A 2001 and 2002. Both had this issue. On the 2002 it was a faulty cam belt tightener that was taking too long to tighten. This was replaced under warranty as it worsened over time. The 2001 still has the issue but goes away. Some times this is also and can be a sign of oil not getting circulated quick enough once you start your engine. I believe this is the problem with the 2001. It now has 300000 plus kms on it and still does it. No long term issues with this vehicle. I would suggest you have someone look at it regardless of comment I have posted.
May 26, 2010 | 1999 Suzuki Grand Vitara
Omron model 650 not inflating and measuring
Lucky! Wrist BP monitors never provide accurate consistent measurements.
Mar 13, 2009 | Health & Beauty
Arrilite 650 Watt Open Face Tungsten (571065) Light Logo
76 people viewed this question
Top Arri Cameras Experts
Are you an Arri Camera Expert? Answer questions, earn points and help others
