Question about GE Interlogix Dvmre Pro 10 Channel Triplex Dvr with Cdrw
No video feed. just a blinking DVR on all screens
  • Kristian Thompson Nov 12, 2010
    i made a typo on my question. VDL is blinking not DVR. i also just change all cameras. was working fine. while i was outside changing cameras out customer was messing with the playback, search. now im getting nothing. i am using rg59 cable with rca to bnc.
  • Kristian Thompson Nov 18, 2010
    the problem was that the terminating loop was not in the circuit (ground).
    Thanks anyway, Professional
  • 15,935 Answers
What type of cable(s) are you using for the video signal?
Thanks!
Posted on Nov 12, 2010
  • GE Master
  • 12,061 Answers
Hi, well if there is NO video displayed on any screen, on any input, then it must be something common to all.
The only? thing that is common will be the Switch Mode Power Supply, I would suspect a fault within the SMPSU. This will most likely need to be attended to by a professional.
reliablecctv.com/alt_pdfs/GE_Manual_DVMRe_Pro.pdf
Above is your user manual. below is a reference guide.
www.gesecurity.com/.../images/.../0150-0264A%20VDR_quickref.pdf
Below is your contact weblink, for anything you require, contact them and ask for it, if you wish to DIY, then ask them for your service manual. or if you don't wish to DIY, then ask them for an authorised service agent, in your area. When here ensure you obtain a 'Quote" for the repair before allowing any repair work to be undertaken.
http://www.gesecurity.com/portal/site/GESecurity/menuitem.c355c8d5843c156ba4ee0629140041ca/?vgnextoid=a8906a75b2653010VgnVCM100000410014acRCRD
Posted on Nov 15, 2010
I have a H show up and blinking why?
The hard drive which saves/stores the recorded video is either full or it has died. Try deleting some of the older saved video to gain more space. If that doesn't work you may need to replace the hard drive.
Nov 04, 2014 | SWANN H264 4 Channel Dvr W500 Gb Hard...
I need to know what model of a Motorola DVR is compatible with my receiver. What model can connect DIRECTLY from it's audio output to the audio input of my STA-795 Optimus Digital receiver (not through the...
Do you really have TV Audio OUT to a DVD (last sentence)?
Most DVR's have digital and analog audio outputs. Since every device they are intended to feed would have its own volume control a DVR output volume control might be redundant. Treat a DVR like any other audio device. Connect it to any available input on the receiver EXCEPT PHONO.
If you run the audio from the DVR (and EVERY video source) directly to the STA-795 you can bypass the TV and its questionable audio electronics (yuk). You can split the analog output of the DVR with y-cables and run it from the DVR to TO the TV for casual viewing and listening through the TV sound system (news, Oprah, etc).
Apr 21, 2011 | Optimus STA-795 Receiver
Dish HD-DVR connected to a Denon 3808ci via an HDMI cable. Problem is periodically, the screen goes black for a split second and then comes back. Rewind and play again the blackout doesn't repeat. When...
Your'e losing digital data from Dish or the DVR. Since even live TV is through the DVR it is always a potential problem when anything glitches. That it doesn't repeat on immediate rewind/playback says the data made it to the hard drive ok.
The Denon is only defaulting back to an analog audio feed upon loss of the digital (preferred) one.
If it affects the video AND audio simultaneously the cause is something common to them.
I'd look at HDMI cabling into the Denon from the DVR.
Don't blame the Denon just yet.
My $.02:
I'd skip the video right past the Denon to the TV/Monitor even if it means using component cables instead of HDMI, but keep digital audio coming in from the DVR. Added cabling and connections never improve anything. Plus, HDMI cables are expensive.
It would be interesting to see if the problem comes back and affects only the audio or the video.
If you use optical cable make sure it has smooth flowing curves and no small-radius bends that would lose light power.
http://www.retrevo.com/support/Denon-AVR-3808CI-Receivers-manual/id/3124dj391/t/2/
Feb 06, 2011 | Denon AVR 3808Ci Receiver
Directv dvr will not power on. The record light
Unplug the DVR for about 20 minutes and then plug it back in. If that doesn't work its probably time to contact DTV for a replacement.
Mar 23, 2009 | Directv Plus DVR DTV Receiver / 100-Hours...
Have just purchased DVR-LX60D. Owning a DVD-696, am familiar with the setup of activating the HDMI output and the front panel of the DVR is showing that HDMI output is active. Fine so far. However, there...
sometimes with certain sets you have too on remote use the input for video 1 video 2 video 3
with hdmi certain tvs require one of the videos to be on to watch in high quality
May 28, 2008 | Pioneer Televison & Video
Direct TV/Olevia 247 audio skipping
I have the same problem with comcast HD, completly useless talking to them, they do nothing to assist
Mar 26, 2008 | Televison & Video
NO VIDEO!!
cheak the out put on the cable box setting hdtv out put is it at 1080 i try 720 p ok
Jan 19, 2008 | Yamaha RX-V661 Receiver
Screen goes blank
This set has a factory upgrade for HDMI problems like yours and it also fixes another problem for intermitent sound in the HDMI mode. This model is still under warranty. Call: 1-800-SAMSUNG To find a local servicer in your area.
Jul 02, 2007 | Samsung LN-T4665F 46 in. LCD Television
GE Interlogix Dvmre Pro 10 Channel Triplex Dvr with Cdrw Logo
246 people viewed this question
Top GE Home Security Experts
Sean
Grantec 2000
Level 1 Expert
Are you a GE Home Security Expert? Answer questions, earn points and help others
