Question about Harley Davidson Harley-Davidson Motorcycle Desktop Telephone
Harley Davidson not starting
I bought a HD 1990 883 Sportster and it won't start, no juice to the bike, but the battery is new, the ignition switch is new...
    Problem Solver:
  • 4 Answers
There is a main fuse under the seat if it is blown you will not get any juice to the bike
Posted on Apr 12, 2013
    Scholar:
  • 29 Answers
Disconnect the battery positive cable and yank straight up on it. If it seperates in two see a dealer. This was a recall so it will be repaired for free - no time limit, you don't have to be the original owner. If not, check the wire from the starter solenoid to the ignition switch. Also check the heavy ground cable from the battery to the frame, and the 10mm battery connections.
Posted on Jan 01, 2009
883 sportster 2007, bike will start on compression but will not start with switch, speedometer needle is stuck and flashers does not work.
Hi, Sylvain before testing any electrical component in the Starting System it is "IMPERATIVE" that you have a fully charged battery of 12.5 volts or more and be able to pass a proper "LOAD" test if necessary, you may have a preliminary reading of 12.5 volts or more but little or zero amperage, the battery is faulty and must be replaced. AGM type batteries fall into this scenario more so than lead acid batteries.
1. Ignition Switch not in the "ON" position.
2. Engine Run Switch in the "OFF" position.
3. Check the battery terminals for damage or corrosion check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter.
4. Bank angle sensor needs a reset or is faulty.
5. FOB battery low or dead.
6. Faulty ignition switch.
7. Faulty starter button.
8. Faulty kickstand, clutch, neutral safety switch.
9. Security alarm needs a reset.
10. Starter relay, solenoid, starter motor or circuit wiring faulty.
11. Starter armature or field coils have failed.
12. Main fuse or circuit breaker may be blown or faulty.
13. Faulty ignition relay.
14. The electric starter is working but starter clutch has failed.
15. Check for engine trouble codes.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below and for more specific information or questions at no charge please feel free to contact me at xlch@mail.com. Good luck and have a wonderful day.
07 883 Sportster Won Start
Harley Davidson Sportster Workshop Service Repair Manual 2007 $8 very cheap includes a $60 electrical diagnostic manual
http://partsfinder.onlinemicrofiche.com/ronnies/showmodel.asp?make=hdmc
http://mybikemanuals.com/harley-davidson/007-harley-davidson-owners-manuals
Instant Tech Relief To speak to me personally absolutely "FREE"
Jul 30, 2017 | 2007 Harley Davidson XL 883 Sportster
2006 1200 portster new battery new starter wont start or turn over
Hi Anonymous, and the usual suspects are:
1.Ignition/Light Key Switch not in IGNITION position.
2.Engine Stop switch in the OFF position.
3.Discharged battery, loose or corroded connections (solenoid chatters).
4. Bank Angle Sensor tripped and Ignition/Light Key Switch not cycled to Off and then back to Ignition
5. Starter control circuit, relay or solenoid faulty.
6. Electric starter shaft pinion gear not engaging or over-running clutch slipping.
For a prime suspect please visit website below and good Luck.
Harley Davidson Sportster error codes and how to access them
Jan 06, 2014 | 2000 Harley Davidson FLSTC Heritage...
Bike won't start. No voltage to fuel pump fuse on 2008 Ultra Classic Electra Glide. Have power on all other fuses. Any suggestions?
Get some good electrical cleaner spray displays that connection scrubber with alcohol, make sure the fuses good and try again pulled a plug-in out, even though you charge the battery make sure the battery has 12.67 V of starting juice. How was your battery may be needed. New battery
Sep 29, 2012 | 2008 Harley Davidson FLHTCU Ultra Classic...
My bike won't turn over
Hi Ron, and the usual suspects are:
3.Discharged battery, loose or corroded connections check negative cable at both ends. (solenoid chatters).
7. Security alarm not disarming
Sep 20, 2012 | 2000 Harley Davidson XL 1200 C Sportster...
1998 833 sportster- cAN'T START AFTER RIDE
Hi Linda, and the usual suspects are:
For a prime suspect please visit website below:
Good luck
Jun 25, 2012 | Harley Davidson XLH Sportster 883 Hugger...
Harley sportster won't start has no power
Hi S Steger, and the usual suspects are:
Have nice Harley day.
May 16, 2012 | Harley Davidson XLH 883 Sportster...
I took my 2009 HD sportster to the HD dealer to get a new tire installed. When I went to pick it up they told me it would not start and that they had charged the battery and installed a new relay and the...
Starter could be jammed have you tried to pop start it? Are you getting power to the starter? Kill switch isnt on is it? Never should have left the dealer it was running when you took it there.
May 14, 2011 | 2000 Harley Davidson XL 1200 C Sportster...
2006 Street Glide. After riding all morning I parked it. went to turn it back on and the bike make a click noise as I pushed the start button. At that point it lost all juice. No lights, no nothing. I went...
If nothing, and I do mean nothing on your bike is working (you said "no juice") I'd suspect the main fuse or breaker has tripped. Look under the seat or behind one of the side covers for the fuse panel.
Good Luck
Steve
Jan 06, 2011 | 2000 Harley Davidson FLHR-FLHRI Road king
Breakers keep kicking off when starting 2000 Harley Sport XLHC
Battery connections have been the leading cause of what you've described. Turn the key, everythings in order, then contact! Instead of potato potato, it's just "click" and lights out. If this sounds familiar, check that battery is tight. Grounds are netorius for coming loose due to sporty vibrations.
Feb 01, 2009 | 2000 Harley Davidson XL 1200 C Sportster...
Lands Phones Logo
321 people viewed this question
Top Harley Davidson Lands Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
ted dux
Are you a Harley Davidson Lands Phone Expert? Answer questions, earn points and help others
