Question about Kenmore Elite Oasis 27052 Top Load Washer
Kenmore Oasis HE / Top Loading Washing Machine the machine shows error code dU, the lock is "clicking" and the machine bleeps but it cannot do anything else. Has to be unplugged for it to stop bleeping. Lid is currently unlocked. Lock is retracted and I cannot pull it out very far with my fingers. Please help
  • 1 more comment
  • notaney Nov 12, 2010
    yes, thank you. This is the same comment I saw when I first searched the site.
    What do I do to fix this?
    please can you give me step-by-step instruction on how to replace the lid lock assembly?
    or do I have to call a technician, which is what I was trying to avoid by using this service?
  • notaney Nov 16, 2010
    hi there
    I think you must be talking about another machine -- this one doesn't have any rubber band or screws -- nothing to be able to take off the boot
    this is a picture of the locking mechanism
    do you have any more advice?
    any other suggestion?
  • 2,382 Answers
Hi, dU error code means Door unlock failure and it means:
Excessive force on door lid is preventing lock bolt from
retracting.
Wash media buildup is preventing lock bolt from retracting.
Machine/motor control cannot determine if door lid is in an
unlocked state.
Posted on Nov 12, 2010
  • Tunde Autos
    Tunde Autos Nov 12, 2010
    The problem may be that:
    • Door Lock Mechanism broken.
    • Check Door Lock/Switch Assembly for foreign objects
    • Check Wire Harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU)
    • Door Lock/Switch Assembly
    You can only fix it by replacing the Door Lock/Switch Assembly
  • Tunde Autos
    Hi, this should be a easy repair, simply open the door, and look behind the rubber boot, you will see a metal band holding it to the front of the machine( spring loaded at very bottom) roll the "clamp"wire off and remove the right hand side of the boot, you will need to unscrew the 2 phillips screws holding the latch assy on and it will slide right put, probably 3 connectors( you will have enough wire to almost pull all the way out.. Replace with the new latch(wires only plug into correct spots, you can't do it wrong). re-secure the latch and roll the rubber boot back over the front lip. rescuring the metal clamp may take a little patience, but get a third hand if available.. starting at top strecth over both sides and snap spring over the bottom. easy repair take your time you will be fine!!
Ld code. It won't drain. Not the drain pump (I changed) and not clogged pipe.
Slow drain code. How high is the outlet pipe ABOVE the machine?
Jan 05, 2016 | Washing Machines
My Kenmore Elite Oasis washing machine has error code "UL" while in rising cycle and stop. Can you tell me what is the problem and how to solve it.
My Kenmore Elite Oasis washing machine will drain but not spin and it keeps jumping back and forth to different time cycles. It continually reads "UL" and I keep trying to adjust and balance the load but it does not help.
Jun 25, 2011 | Kenmore Elite Oasis 27052 Top Load Washer
Error code " du "
DU = Door Unlock code
Washing machine displays error code F/DU after six attempts to unlock.
-Door lock assembly failed.
-Test door lock switch
-Visually inspect wire harness connection on CCU, Door lock assembly, replace door lock assembly.
The door lock assemble on this washing machine can be replaced from either the top of the front. The door boot can be removed or the top of the washer can be removed.
Hope this helps.
Jun 22, 2011 | Washing Machines
Du error code on a kenmore elite oasis he what does it mean and what can i di to fix the problem
Door unlock failure
retracting.
unlocked state. See TEST #8, page 14
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jun 11, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
DU error code
The Kenmore Oasis and Whirlpool Cabrio washers are essentially the same. Following is the Whirlpool Installation and service manual for their Cabrio washers.
The DU indicates a problem with the door Un-lock mechanism. See the section on troubleshooting2.gif and display codes.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/409753510a90c8be852571e90073421b/$FILE/8178583.pdf
Oct 13, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore front loading washer
brand new and you changed the latch mech.? door latch or lock asm.? DU is door unlock error, it tried to unlock and cant. usually replace lock asm (inside machine) for this problem. may have latch out of alignment.
Dec 01, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore elite HE 3t - error code F dU and door is locked
Just in case there is a pull string with a loop, all plastic under the latch, need to pull the toe panel off and reach up inside the right, unplugged of course until you feel the switch. a pull latch is below the switch incase this happens and hats off to all star/ a serial error or a faulty switch is most of what causes this to start.
Jul 29, 2008 | Kenmore Elite 45986 Front Load Washer
Washer keeps reading Du
sounds like lid lock failure clips each side just below top eadge of washer about 3-4 insches from outside edge use stiff putty knife to push clips in and release top should be able to acess switch from there swtich will need replacing
Apr 29, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore Elite Oasis 27052 Top Load Washer Logo
314 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
