Question about Philips 50P8341 50" Rear Projection Television
Picture looks like a double screen - Philips 50P8341 50" Rear Projection Television
  • Philips Master
  • 1,210 Answers
You have a convergence board that is bad. The board you will be looking for has your RCA jacks and RF connectors. If you can remove this board,,there are two large ICs connected to a pair of large aluminum heatsinks. Remove the straps on the ICs. They should be STK 392-110. Replace these, and be sure to use heatsink grease between the ICs and the heatsinks. This will help keep the ICs cool. Also the low ohm, one watt resistors should also be replaced. These are located at R 3069,R3070, R3071, R3072, R3073, R3074, R3075,R3076, R3077, R3078, R3079, and R3080. All of these resistors are 6.8 ohms at 1watt. Thats fine if you think you can repair this. Now, before you start let me give you the best advice ever. Call Union Electronics at 1 800 648 6657 and aske for a refurbished convergence board. The price is reasonable and you get an exchange fee for you old board. The repair in this manner is very, very successful. And is done right the first time. You will be glad you did. Have the model# of your TV when calling. Thanks for asking and show a few hands of support!
Posted on Nov 12, 2010
Doubled colors, fuzzy
Dull Video...
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
Convergence
* Screen Looks 3D, Warped, Distorted, etc
* Colors do not line up
* TV may shut off - and make a chirping sound.
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jun 01, 2010 | Philips 60PP9202 60" Rear Projection...
My 65'' Has a red double screen.
These sets have several common problems which are listed below.
Problem #1) Convergence
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Another common problem is dull or washed out video.
Your TV may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find the fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 31, 2010 | Hitachi 65F59 65" HDTV
Picture has ''double vision'' with red.
This is a common problem. Its called a convergence failure.
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • TV shutdown - does not display video
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Red/Orange looking video
You can see some examples and find a fix here...
Feb 20, 2010 | Televison & Video
DOUBLE IMAGE ON SCREEN. tOP OF PICTURE LOOK LIKE A
That symptoms are due to failure of convergence out ICs in your TV that will be replaced to get correct converge picture on front screen.
There are 2 big black IC mounted on big aluminum heat sink and number would be written on as STKxxx, these 2 ICs will be replaced.
If you want to repair TV by yourself then confirm model number of TV to provide you more info or call local tech to replace said ICs.
Thanks.
Dec 21, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
Samsung HCN4727W Rear Projection TV, green screen, audio works
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai2_bing.gif,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Jul 10, 2009 | Samsung HL-R4667W Rear Projection...
I HAVE DOUBLE COLORS ON SCREEN THE RED AND THE BLEU AT ONCE ON AND I DON'T KNOW HOW TO ADJUST .
Projection TV sets have two very common problems listed below.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
*Screen Looks 3-D
*Colors wont align
May 24, 2009 | Hitachi 53UDX10B 53" Rear Projection...
Double picture & color problem
*Screen Looks 3-D
*Colors wont align
Jan 22, 2009 | Sony KP-53XBR45 53" Rear Projection...
Double picture on left side with red projector on Hitachi 55UX58B
*Screen Looks 3-D
*Colors wont align
Oct 20, 2008 | Hitachi 55UX58B 55" Rear Projection...
Double picture
*Screen Looks 3-D
*Colors wont align
Aug 31, 2008 | JVC AV-48WP74 48" Rear Projection...
Picture Problem!! and its not convergence (Double vision except for middle of screen)
Could be pin correction circuit or your picture tubes could be worn out . Sometimes when the crt's get weak the edges seem not as clear as the center of the screen . Give model number if you think the pin correction may be your problem but, the tv is pretty old and avg. life for them is 12 to 15 years when the picture tubes start to degrade . Good luck
Mar 01, 2008 | Sony KP-61S65 61" Rear Projection...
Philips 50P8341 50" Rear Projection Television Logo
20 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
