Question about Dryers
My kenmore electric dryer 70 series wont turn. it turns on and heats up but it doesnt spin. what can i do to fix it? i have aparts dryer to use. just need to know what to do. thank you very much
  • 134 Answers
You mayu have a broken belt if you take the cover off you should be able to see if the belt is still on there if not you can get a new one should be pretty cheap.
Posted on Nov 12, 2010
  • jnkemerson08 Nov 12, 2010
    do i take the top off or do i take the face of the dryer off to find the belt
  • par sims Nov 12, 2010
    You should be able to tell from the top but you may have to take off both it kinda depends it will be easier to take both off so you have more room. You may be able just to do it from the toop but may be more trouble that its worth. I would have to say its in your hands you should be able to make a desicion once you get in there see how much room you have. Thank you sorry it toook so long to respond i did not see your commet till today.
Kenmore 70 series dryer squeaked, heated, drum turned, then turned off and won't come back on--is it toast or worth fixing?
It all depends on how you look at things.
Comparatively speaking, dryers are a piece of cake.
However, with out mechanical ability and tools, it could be over your head.
You decide.
If you choose to fix it yourself, it could be done for a few dozen dollars.
Hiring a repair man could make it cheaper to buy a new one.
New parts are available through "Sears parts" on the internet.
Someone will need to take it all apart to see why it stopped on you. To do it yourself, you may also need an electrical testing meter.
Be blessed.
Mar 20, 2013 | Kenmore Dryers
Dryer heats up wont turn belt is fine
if you can't turn shaft by hand, motor sized or bearings(on both ends of shaft) shot.
Jul 08, 2012 | Kenmore Series 70 80 90 PN281798 Dryer...
I have a Electric Kenmore Dryer 70 series. No heat and timer doesnt work.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Mar 28, 2011 | Kenmore 700 6972 Dryer
Just purchased a kenmore 70 series gas dryer turns on but wont heat up
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Sep 19, 2010 | Kenmore 73952 Gas Dryer
Kenmore Dryer 70 series electric-quit heating and timer wont shut
https://www.repairclinic.com/RepairHelp/Dryer-Repair-Help
This link will help you in diagnosis/disassembly/parts.
Possibly a faulty heat element is most common failure. Fix the no heat problem and the dryer should shut off ok.
Make sure you have correct voltage to the unit before tearing apart. Again visit the link above
Nov 24, 2017 | Kenmore Dryers
Kenmore 70 dryer smells burnt
There could be dust settled on the motor inside from the few years in storage. Unplug and remove back, with a hoover brush **** off all dust but do this lightly as to not disturb any connections.
Jan 04, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
Dryer wont start.
can you hear the motor or does the unit humm or vibrate when it is turned on
if yes then have a look at the belt
if not it's time sor a service call
Aug 04, 2009 | Kenmore 700 6972 Dryer
Kenmore 70 series electric dryer
do you get any heat at all? is the drum turning? if yes and yes you need to check the dryer hose all wall hole to see if it is clogged,clean both out and see if this helps,if no heat the main heater fuse might be bad,check that also,hope this helps you-mike
Oct 26, 2008 | Dryers
Dryers Logo
160 people viewed this question
Top Dryers Experts
