Question about Porter Cable - Cable C5101 Oil Free Induction Horizontal Portable Compressor
I have a porter cale C5101 compressor. It hesitate to auto start when the pressure is low, always trip my circuit breaker.
    Genius:
  • 1,015 Answers
What amp breaker do you have this hooked to. I would use no less than 15 amp ,preferrably a 20 amp. Next do you drain tank after use on a regular basis. If you don't moisture can build up inside tank and cause hard starting on automatic. If you need to drain tank there should be a drain valve on bottom of tank. try turning it counterclocwise with compressor off. If it dosen't turn that way try clockwise,air and moisture should drain. If you have alot of water in tank then shut valve and turn compressor on and bring to full pressure,then repeat draining procedure until no more water comes out. Hope this helps. Thank you
Posted on Nov 12, 2010
Porter cable cffn25 won't run. Trips breaker
The little compressors were not built for continuous duty. The pump probably seized, or the motor burned up, or both.
Nov 25, 2013 | Porter Cable Air Tools & Compressors
Carrier puron 38txa a/c compressor will not turn on
Make sure there is power at the compressor, but first at the contactor (being supplied to contactor ). Power being supplied to contacter (line voltage) ?
Yes, then close contactor manually and if it works then check for 24 volts at the contactor coil. Find 24 volts, then you need a contactor.
No supply (line voltage), then check breaker
Breaker on, then check run capacitor and if good check high and low pressure protection.High pressure = trips on high head pressure (manual reset) then clean condenser coil.
Low pressure trips on low charge (auto reset on restored charge)
Sep 03, 2013 | Heating & Cooling
My porter cable 5101 air compressor will no build up pressure.. no visable leaks found
use liquid soap in water to check for leak if you have no bubble at any connection you probably need a rebuild kit for pump,this model is oilless and wear fast
sometime the o'ring on pump output pipe is worn,you need to open head of the pump to see it
Nov 12, 2012 | Porter Cable - Cable C5101 Oil Free...
I have a porter cable c5101 when i switch on motor runs but the pressure guage does not go up i have a pressure of about 30psi and no more when i switch off there is air escaping from by the switch area.
you have a check valve problem
this valve stop air to go from tank to pump
air flow by switch because of unloader valve,it try to unload air in the pump head
Oct 27, 2011 | Porter Cable - Cable C5101 Oil Free...
Compressor starts innitially,then when pressure gets low it trips breaker when it tries to start back up.20 amp breaker to light switch to compressor is about 2o ft on12-2 wire. tried 30 amp breaker,does...
the start capacitor on the motor body is weak,the motor needs this component to over come the air pressure when cycling to re-build the low air pressure,change both the start and run capacitors when doing the start because the other run capacitor is just as old and it will soon fail
Mar 19, 2011 | Craftsman 33 gal Air Compressor 6 hp...
I have a C2150 4 gal compressor from Porter cable with 2hp peak and 1.2hp continous rated motor. The problem is that I can not run the compressor on a 15amp circuit with out tripping the breaker. It even...
Try to use a higher amperage extension cord.
This unit is rated for 15 amps. It should be able to run on a 20 amp circuit unless there is voltage drop due to small wiring. Try an air conditioner extension and let us know the result.
Gary
Dec 19, 2010 | Porter Cable C2002 150 Psi 6 Gal...
My Campbell Hausfeld 30 gal 6.5 hp oilless compressor, WL611201 trips the breaker when I switch it on auto. But will not trip the breaker if I use the breaker as an on off swithch. However, it somtimes...
not likely as your pressure switch is pneumatic, What else operates on that same breaker, perhaps replace the breaker as they sometimes get "tired"
hope this helps
Let me know
Dec 18, 2010 | Campbell Hausfeld Air Tools & Compressors
Second time compressor tries to fill tank blows braker
The compressor pobably has a faulty unloader valve which bleeds the pressure off that is left in the cylinder when the compressor turns off . The unloader valve allows the compressor to start the next on cycle with the cylinder empty. Trying to start the compressor with the cylinder under pressure causes too much current draw and trip the circuit breaker.
Jul 06, 2010 | Campbell Hausfeld 10 HP 120Gallon...
My c3151, loads to tank fine then the unit will cut in and out. The unit will trip a breaker. Is this an easy fix?
the line from the compressor to the tank should have a check valve .so that the compressor head does not have pressure for easy start up... check and replace if needed. when compressor attempts to start its to dificult with the pressure, causing circuit overload.
Jan 12, 2010 | Porter Cable Cable 4.5 Gallons 150PSI Job...
Porter Cable - Cable C5101 Oil Free Induction Horizontal Portable Compressor Logo
176 people viewed this question
Top Porter Cable Air Tools & Compressors Experts
John Trevino
elunsford
Are you a Porter Cable Air Tool and Compressor Expert? Answer questions, earn points and help others
