Question about Olevia 742I 42 in. LCD TV
Just moved my TV to a home with cable. It was hooked up to Dish network. there is no signal. Thank you.
    Novelist:
  • 123 Answers
We would be happy to help get your DISH Network signal back.The first thing we want to check is if there is anything blocking the signal toyour satellite dish like tree branches, severe cloud cover, or snow build-up.If it is safe to do so, remove the obstruction or wait for it to pass. If thatis not the case then reset your receiver by unplugging it for 10 seconds thenplugging it back in, the reset may take up to 5 minutes to finish (note: thereceiver's power plug usually has a red tag attached to it). At this point wewant to check the connection between your receiver and the outlet; please visitthis link and select the model receiver you are using to check the wiring ofyour receiver: http://www.dishnetwork.com/SupportSection/setup-receiver-towall.Once you have check the connections perform a check switch test. Press the menubutton, then the numbers 6-1-1 on your DISH remote, this should take you to thepoint dish screen, select check switch on the right, then test on the bottom ofthe screen. Once the test is complete exit the menus and let the receiveracquire the signal (If Error 836 appears, do not save the matrix, cancelit and call our 24/7 customer support number listed below.). After all thesesteps if the receiver is still not getting the signal it should please give usa call on our 24/7 customer service line 1-800-333-DISH (3474) for additionaltroubleshooting.
We hope this gets your signal back. Thanks for choosing DISH Network!
Phillip Chang
DISH Network Customer Service Representative
Posted on Mar 14, 2011
We move the tv from living room to bed room and we have to change the chanel from 3 to 60 to get the tv to work on dish network, we try to change from 3 to 60 we try evereything whit no result, we call...
Rescan all the channels?Hook the tv and the satalite signal cable in the tv and dish network box correctly check?Go to tv menu.Goto SETUP,pick CH. pick option CABLE enter to rescan all channels.This should have all the channels,belong to the package u order.
Sep 04, 2010 | Televison & Video
We recently moved our dish ( we are in an rv) and now we get a signal on one tv only. we have dish network and a 625 DVR. we have moved many times and have never had a problem before. in order to switch...
5shades690,
Are you still having problems with your TV 2 off the 625 receiver? You have a cable off the back of the receiver, TV 2 Home Distribution. That's feeding to your TV 2 location. You might check to make sure it is secure. You can also see if that cable screws into a diplexer if it is being back feed through the satellite cables. These are all potential problem spots, especially since you said it was working before. I hope this helps.
Ray Calo
DISH Network
Jul 28, 2010 | DISH Network DVR-625 DTV Receiver /...
I have Dish sattelite and it won't work with memorex under cabinet. They said I need a cable box in between the dish receiver and the tv. Why is this?
You need a receiver for each TV you want to receive the reception on. Your dish receives the broadcast signal from the network and your receiver decodes and recodes the signal to view on your TV. The companies have created their own proprietary equipment to accomplish this to keep anyone and everyone from simply installing their own dish and receiving all of their broadcast channels for FREE. In the olden days when satellite and cable TV was new, that is exactly what people did. Remember those gigantic dishes some people installed in their yards? They would intercept the signals coming from the satellites and hook up directly to their TVs. The companies got smart and started to scramble the signals going up to the satellites to make these home owner dishes obsolete. Because the signals are scrambled, you now need a receiver to un-scramble the signal. I hope this helps and good luck. Please remember to vote d368a18.jpg if you found this helpful. Thanks.
Oct 31, 2009 | Memorex MVUC821 8 in. Under Cabinet TV
Lg lht854 does not work tv sound
Ok your dish network wont play through the LHT854? Which Dish network receiver do you have 211, 311, 625, 612, 722? From the owners manuel for the LHT854 it looks like you can only hook up the audio from another source by an optical cable, so how is the LHT854 hooked up to the dish network receiver?
Aug 19, 2009 | LG LHT854 Theater System
Hooking Up Panasonic sc-ht670 home theater to Dish DVR 625 and Panasonic TH-42PHD7UY Plasma TV
You will need to run a set of audio cables from the TV1 output on the rear of the 625 directly to one of the three audio inputs on the surround system. Thanks for using Fix Ya.
May 13, 2009 | DISH Network DVR-625 DTV Receiver /...
Unhooked the TV,took it to another room, hooked it up, just fuzz
Make sure the cable you now have hooked up to TV is actually hooked up to the dish. If you're sure it is then take the TV back to original location and hook it back up. If it works in that location you have a bad cable. If it still doesn't work it's the TV. The only other thing I can suggest is that some TV's must autotune before a picture can be shown. If you're sure you have a ggod signal go to the TV menu and do an auto tune or auto search. The TV will then go thru all the different possibilities looking for signals. Once it has completed the search it will then give you a picture. You can then go and add/delete channels and set it up however you want.
Jan 24, 2009 | GE 32GT660 32" TV
No signal when hooking up to dish network.
I unhooked the new tv and hooked up the old one to see what channel it was on and then rehooked up the new tv and put it on the same channel as the old one.This worked but I also had to put the cable into the hook up on the back marked cable instead of the one marked HDTV.
Dec 11, 2008 | Polaroid FLM-323B Television
Digital signal
hi my name is mark, if you are already hooked to dish network, there is nothing you have to do. you are ready fotr the dtv change over june 12 09
Aug 17, 2008 | Protron PLTV-32 Television
Hi. I need help finding 119!
I looks like you are picking 110W with the LNB on your left if you are facing the dish.
Try to get 119W first if you connect the cable to the 119 LNB, once you find 119W that way, you will also have 110W.
Good Luck.
Feb 24, 2008 | RCA DISH Network(r) 311 Satellite System
Hooking up tv to dvd player
You will probably have to use your tv remote and change the input for your dvd. It's usually video 1,2 or component 1,or 2
Jul 01, 2007 | Insignia IS-LCDTV32 32 in. Television
Olevia 742I 42 in. LCD TV Logo
140 people viewed this question
Top Olevia Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you an Olevia Televison and Video Expert? Answer questions, earn points and help others
