Question about Dryers
Speed queen gas dryer...works but makes a loud buzzing sound when the burner is on. noise stops instantly when the burner goes off.
  • maryloug Nov 12, 2010
    the nois has been going on for about four days. wife is unhappy
    thanks. this confirms my guess'
  • Dryers Master
  • 43,501 Answers
The gas valve has coils on top of it that when energized create a magnetic force which holds the gas valve open....The coils can stup a lound noise under certain conditions....there maybe a temporary electrical problem in your are that is causing them to make the noise...
I would wait a day or two and see if it stops before replacing the coils...
heatman101
Posted on Nov 12, 2010
  • D. Floyd Kolb
    D. Floyd Kolb Nov 12, 2010
    Okay the the coils are bad....
    Look up the parts by using your model number....for some the coils are available and for others the whole gas valve needs to be replaced...
    Hereis a tip that will help you with the online buying...
    How to Buy Appliance Parts Online
    heatman101
Dryer starts and runs fine but makes a loud buzzing noise from the motor that sounds a lot like the end of cycle signal
FIXED Dryer won't start. Makes electrical buzzing noise - model ...
www.applianceblog.com/.../7655-Dryer-won-t-start-Makes-electrical-buz...
Feb 12, 2007 - 10 posts - ‎1 author
It makes electrical buzzing noise when you press the start button. ... One would think that if it's the fuse that it wouldn't buzz at all but ... unplugged, re-assembled back, hooked back up to hose, turned on and running hot .... The belt was fine. ... Kenmore gas dryer 70 series is making very loud buzzing noise.
Troubleshooting Your Dryer Noises ' PartSelect.com ...
? 4:32
https://www.youtube.com/watch?v=Tk1YezyYMDY
Aug 26, 2011 - Uploaded by PartSelect
In this video you'll learn why your dryer may be making a variety of ... that is not only making a grinding noise but it also makes a loud banging noise. ... it's been drying about 15-20 min. it startsa loud humming sound. ... The dryer is working just fine, but I am concerned about the noise as it sounds electrical.
DRYER BUZZING NOISE - Dryer For Sale
Dec 18, 2015 | Amana DLE330RAW Electric Dryer
My gas dryer makes a loud buzzing sound when the gas come on how do I fix it?
This noise can be caused by the solenoid valve that controls the gas flow to the burner. If the dryer is not getting hot then the valve needs to be replaced. Depending upon the age and manufacturer the valve may be an integral part of the burner assembly.
May 23, 2015 | Amana Dryers
What's your problem?My older Speed Queen gas dryer is making squealing noiseses
I work on commercial units ,and this sounds like a trunnion bearing, or drum has come loose
1 loose trunnion bolt -easy fix
2 bearings - call experience repair
Jul 16, 2017 | Speed Queen Washing Machines
Ignitor works, lights the gas, then when the ignitor goes off, so does the flame.
Hi Stanley,
the problem with the dryer flame going out is caused by defective coils on the gas valve and the gas valve coils should be replaced
Dec 03, 2011 | Speed Queen Dryers
My Maytag Bravos dryer is brand new. It is the quiet series 300, but is the loudest dryer I have ever owned. It makes like a loud vibrating, humming noise. Is this normal? I am now drying my second load of...
People, the first words the poster said were that the dryer was "brand new". All of your suggestions assume the dryer had extensive use. This sounds like a factory defect issue!!!! My brand new Maytag Cabrio gas dryer is also making an obnoxious buzzing sound that seems to cycle on and off as the gas ignites. The buzzing sounds electronic not mechanical. What would buzz when the burner is active?
Oct 31, 2010 | Maytag Dryers
Speed Queen gas dryer model #AGM499W. Replaced the igniter but did not fix the problem. Dryer will not heat.
burner may need to be vacuum out or blown out, also could be the thermo coupler. Hope this helps tim
Sep 02, 2010 | Speed Queen AGS28AWF Gas Dryer
Speed Queen Model SWT220WA 3/4 filled with water, loud buzzing sound, stopped.
motor stalled
take off the belt and see if it will run
if it wont run could be timer or motor
if it runs cold be a stuck gearbox
Aug 28, 2009 | Speed Queen SWT921 Top Load Washer
Maytag gas dryer noise when burner comes on
The noise you are describing is coming from the gas valve solenoid coil assembly. This is usually indicative of weak coil.
If this is a warranty situation, request a factory authorized certified technician to replace the solenoid assy. at no charge.
If you want to fix it yourself, be sure and ask us for instructions on replacing the part safely.
Thank you for contacting us at FIXYA.com
May 28, 2008 | Maytag HYG2460AWW Gas Dryer
Dryers Logo
154 people viewed this question
Top Dryers Experts
