Question about Xerox WorkCentre XD130DF Laser Printer
How do I change the paper feed rollers on a xerox workcentre xd130df?
rytech uk
  • 85 Answers
SOURCE: Xerox XD130DF J2 error replace
Im presuming that your have replaced the drum??
if so :
Remove the new drum.
On the front of that drum, there is a green cover. Take it off and what has happened is the flag on the gear had dropped in shipping.
You will see a flag like piece of plastic on one of the gears, reset it to up and somewhat to the right.
Then put the green cover back on
That flag has to be in the up position when new. It passes down and actuates a drum reset switch on the machine.
When that is back in the up position. re insert the drum and on the first revolution it will turn on the switch.
I can try and send you more information if you provide an E-mail address, or simply take the drum back to where you bought it for exchange.
Posted on Jun 20, 2008
yooperbud
  • 8637 Answers
SOURCE: Xerox WorkCentre Pro 215 E2 Error Code
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Posted on Jan 29, 2009
  • 2072 Answers
SOURCE: Frequent paper jams on Xerox PE220
You have to spin them backward to get them into a good position to clean them, They will resist you, but just take it slow and clean them with alcohol or formula 409 type cleaner.
But what will often cause jams on that machine is the seperation pad that is located on the paper tray itself. It will get very slick and allow 2 or more pieces of paper to feed, It is a small gray to black pad on the middle front of the tray, about 1/4 inch wide and and inch or so long, If it is smoothe scuff it with some scotch brite then order one or two.
Google a business called "the parts drop" and call Britt, they should have the pads and rollers at a fair price.
Posted on Feb 09, 2009
  • 78 Answers
SOURCE: Xerox Workcentre PE220 doesn't load paper.
you need to follow on your edocs.find a part number for your pick up rollers.
Posted on Dec 11, 2009
  • 111 Answers
SOURCE: Error code 39,003,40;61256 on a xerox workcentre
Here is the easy solution to fix the issue :
Click on the link and follow instructions to fix the issue.
http://www.pchell.com/hardware/cd_drive_error_code_39.shtml
Posted on Apr 01, 2010
I have Xerox M 20i .When ever I feed papers from ADf. Print is not coming normal.Some time it shrink the text,I checked the roller are fine.
The Xerox is a business machine and has a setting to reduce the size of scans by percentage.
Read the instruction manual to turn it off or play with the buttons.
WorkCentre M20/M20i Documentation - Xerox Support and Drivers
www.support.xerox.com/support/workcentre-m20-m20i/documentation/enus.html
  1. Cached
  2. Similar
Product documentation for WorkCentre M20/M20i. ... WorkCentre M20/M20i Firmware Installation Instructions. Setup and Installation Guides. Description.
[PDF]WorkCentre M20i System Administration Guide - Xerox Support and ...
www.support.xerox.com/support/workcentre-m20i/file-redirect/enus.html?...en... Xerox WorkCentre M20i System Administration Guide. Page i. Table of Contents. 1 Welcome ................................................................................. 1-1. Introduction .
Xerox 20i Google Search
Nov 19, 2016 | Xerox Office Equipment & Supplies
No paper feed
Pull out a paper cassette and you see paper feed roller (it is rubber), just clean roller with cloth and water or alcohol
Jan 13, 2011 | Xerox WorkCentre XD100 All-In-One Laser...
I need the part # for a pickup roller
If anything else fails, call Xerox and ask for parts support. They might be able to sell you the part. Keep in mind you might have to purchase the whole paper feed assembly, not just the roller.
good luck.
Sep 10, 2009 | Xerox WorkCentre Pro 580 Plain Paper Laser...
WorkCentre XD130df
More than likely you have a bad fuser gear. It will break teeth, crack and not drive or the tab that inserts on the roller to drive it has snapped.
You have to remove the back cover to unplug the fuser then there are 2 screws that hold it into the frame.
The gear is on the right side of the fuser.
The price of the gear is less then 20 dollars.
Here is a link to a reputable parts source.
https://www.partsdrop.com/store/
Ask for Britt if you call. This is not me. Nor where I work. Just a reliable source.
May 02, 2008 | Xerox WorkCentre XD130DF Laser Printer
Xerox Workcentre XD130df error
Not familiar with XD 130 but A1 in most Xerox machines refers to a jam in the document feeder, open everything you can and look for torn pieces of paper on a sensor
Jan 23, 2008 | Office Equipment & Supplies
Xerox WorkCentre XD130DF Laser Printer Logo
63 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
