Question about Microwave Ovens
Stop working, no light on panel etc. - Microwave Ovens
  • Microwave Ovens Master
  • 43,501 Answers
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Posted on Nov 12, 2010
Just stopped working panel displays time etc but no microwaving going on
  • Open internal fuse
  • Defective magnetron
  • Defective control panel
Jan 29, 2017 | Microwave Ovens
My Emerson microwave control panel stopped working
The fault could be a defective control panel, a defective internal controller, or as you guessed, maybe a loose internal connection. In any event, the cabinet will have to be removed to gain access internally and you should read and heed all precautionary notices regarding high voltage. If the source of the problem is not a loose connection or evidence of burn marks, etc. It may be time to have your microwave serviced. Also bear in mind that the age of the oven (in appliance years) may make it impractical to repair.
Dec 13, 2013 | Microwave Ovens
Our inverter microwave stopped completely and now has no power!
Amanda, If yours is newer construction (less than 40 years) the microwave is likely to have it's own circuit breaker in the electrical panel (in the garage or basement?) so no other lights or outlets might have gone out. I have never seen a microwave that had it's own user-replaceable fuse or circuit breaker.
Feb 10, 2010 | Panasonic MCM INVERTER
Clock works panel lights up but it won't heat
All of a sudden last nigh it just started acting weird the panel works and the clock etc works as well as all the cooking setting. but it doesn't light up inside and when I close the door to my GE Profile Eterna Space maker it starts huiming like its cooking something
Feb 06, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
All the light blew out, the electric still works, but the oven won't heat food
Hi, my living room light has stopped working, When i turned it on one of the little bulbs went pop and light stopped working although all electric and other lights still work. I tried the bulb in a different light and it still works as well?? I also took light off to check for loose wiring etc but all seems to be fine. Can you help? Thanks!
Oct 04, 2009 | Whirlpool Accuwave Microwave Oven
No power at all
Open and remove outside panel. Inside next to the plug in (power supply) there will be a glass fuse. Look inside the fuse and see if you can see a thin metal wire running across the entire glass tube. If it does not touch end-to-end, then it should be replaced.
If the fuse is good, then you may have faulty power supply or even bad circuit board
Jul 22, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Keypad only works
This is usually caused by either a bad door switch, a loose door switch mount, or a problem on the control panel.
Even though a door switch clicks, it may still be bad inside.
This can be caused by slamming the door or by habitually opening the door while it's cooking without hitting the Stop pad first.
If you or a friend decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
We're happy to help and we appreciate your thoughtful rating of our answer.
Dec 22, 2007 | Kenmore 62622 Microwave Oven
Goldstar Microwave
Could be the relay, an internal fuse. With the power off, open up the key panel and search for a fuse. Also, there are thermo sensors black, diameter of a dime and 3/8 inch thick with two wires. Check the fuse and replace if necessary. The thermo can be jumped out to test. Remove the wires, use a paper clip between them and tape it up. Briefly turn the unit on. Replace if it works now. The thermo is generally clamped to the wall of the oven behind the key panel. Never run without the thermo sensor.
Dec 18, 2007 | Goldstar MV-1501 Microwave Oven
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
