Question about HP Photosmart 2575 All-In-One Printer, Scanner, Copier
How can I remove paper stuck way back in? I have removed all of the visible paper but there is still some stuck in the rollers beneath the cartridges of the HP Photosmart 2575. It doesn't appear to have any way to turn or loosen the rollers.
    Genius:
  • HP Expert
  • 1,325 Answers
Hi
turn off the printer, disconnect the power cord
i located a link from HP , you will have to go to the rear of the printer , remove the rear cover
there are bits of paper that must be removed from the rollers...
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00444561&lc=en&dlc=en&cc=ca&lang=en&product=441245
hope this helps
Posted on Nov 12, 2010
HP laserjet 1518
HP printers frequently time how long a page takes to run through the machine. If it is too slow, they signal a jam error.
Try cleaning all the rollers and pinch wheels etc within the laser.
Dec 10, 2013 | HP LaserJet Office Equipment & Supplies
My paper keep getting jam and will not go into print
  1. Turn off the printer.
  2. Inspect the location or tray the printed paper ejects to. If the stuck paper is visible manually remove it.
  3. Remove all paper trays and any paper that may be stuck between the tray and the printer. If the stuck paper is visible manually remove it.
  4. Open the printer door that allows you access to the printer ink cartridges or toner and look for any stuck paper. If the stuck paper is visible manually remove it.
  5. Turn the printer back on. If you continue to receive a printer jam error try repeating the above steps again. If issue still persists and you see no paper that is stuck in the printer it
May 14, 2011 | Office Equipment & Supplies
ESP5200printer,new,paper jam message
Hi slicknick58,
Paper jam message occurs when there are stuck papers inside the printer. There are several ways on how to correct this problem, either you remove the visible stuck paper manually or replace the toner or ink cartridge. Below are the steps you'll want to follow when this problem still occurs.
1. Turn off the printer. Turn the printer off and on to see if it can automatically clear some or all of the jam.
2. Inspect the location or tray the printed paper ejects to. If the stuck paper is visible manually remove it. Remove any paper trays. Inspect them for wrinkled or damaged paper.
3. Open the printer door that allows you access to the printer ink cartridges or toner and look for any stuck paper. If the stuck paper is visible manually remove it.
4. If necessary, remove the toner or ink cartridge. Place it in a bag or away from light to avoid damaging it.
5. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
6. If the paper does tear, try rotating the roller gears manually to free the paper . Don't force anything.
7. Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
8. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path and try repeating the above steps again.
Hope it helps.
Thank you for using FixYa.
Apr 20, 2011 | Kodak ESP 5 Printer
STUCK LABEL IN THE P-TOUCH QL-500 LABEL MAKER, This is now the third printer I have purchased and replaced because of stuck labels on the rubber roller, this is a great printer until this happens. Any...
I downloaded service manual
You need to remove the top cover
Remove the curved cover 1st , has 2 plastic pins to press inwards
Lift the curved cover upwards
Remove the darkcover beneath the labels
At the back 5x self tapping screws
At the from 2x machine screws, left hand one is under a label
Prise off the cover by inserting a screwdriver at the back edge
Voila
Remove the stuck label
Reassemble
Apr 01, 2011 | Office Equipment & Supplies
Asked me a paper was jam
You didnt wrote where it is the paper jam.
Here are few common jams:
  1. if the paper jams in fuser unit, do/check next:clean the paper delivery rollers ( when you open left door its two roller on axis beneath the drum ), check the sensor flapper beneath the drum unit if its worn out you need to replace it, does the paper comes out like bent in the roll? open fresh pack of the paper and try again it could be moisture fault.
  2. the paper stucks in pickup section, clean the paper pickup, feed and separation roller, to do that remove paper drawer and you will be able to see the rollers on left inner side.Open the lower leftside door and check the paper senzor in the middle.You can apply some wd40 on spring of flapper or on left side bushing.
  3. dadf jam, check for any paper leftovers and clean the paper pickup and feed rollers
Hope that helps!
Sep 07, 2010 | Canon iR 2016i Black and White Copier
The printer is saying there is a paper jam but there is no paper stuck any way in the machine.The resume button does not resolve the problem.
The paper jam may not be very visible and obvious. It may be somewhere after the rollers. Some paper may be stuck in some place in the paper path. Open up the printer and clean the insides with a soft cloth and a brush. That should remove all the bits of paper inside. OR the teeth on the roller sides may have some dirt stuck on them which does not allow the rollers to roll freely and hence is as bad as paper jam. The idea is that the rollers do not roll whether because of paper or some dirt on the roller teeth. They have to be cleaned.
Nov 17, 2009 | Canon PIXMA iX4000 InkJet Photo Printer
Paper jam back door of Lexmark T640
I went at it with surgical tools and was able to grip and remove the paper by the visible edge
Dec 12, 2008 | Lexmark T640 Laser Printer
Paper stuck in roller
Clear the paper jam. To see paper jams and how to clear them, click here. If the printer does not start printing, press the control panel button.
Mar 31, 2008 | Brother HL-2040 Laser Printer
Forms stuck on roller
Not simply, Remove from mains, all covers must come off first, then it is obvious. Probably will need new fuser
2d9596b.jpg INFO
Ensure labels are laser type and paper type is set accordingly
Nov 02, 2007 | Brother HL 1440 Laser Printer
Brother 4100e paper jam
Can be tricky people usally damage the fuser rollers removing this jam with pliers/tweezers, it has concertined and stuck after fuser rollers and before exit rollers it will be stuck on the switch best bet is to dismantle properly and remove fuser then dismantle fuser and remove jam, another thing to be concerned about is why did it, three seneraros, Damp paper going threw fuser dries and crincles(use fresh paper from sealed packet), fuser is worn(have fuser replaced), just a bad bit of paper (just have fuser jam removed. Fusrr runs on 240v, covers break easy
Oct 15, 2007 | Brother IntelliFAX 1270E Plain Paper Fax
HP Photosmart 2575 All-In-One Printer, Scanner, Copier Logo
Seeker5211
Seeker5211
