Question about Hitachi 42HDS69 42 in. Plasma Television
When i turn it on i hear it click inside the tv but no picture or sound i do see a little red light come oninside the tv
    Problem Solver:
  • 6 Answers
What about at the front of the TV... Is the stand by light on? It's the red light...
If the stand by light is on, then you can try removing the back cover and clean/vacuum especially the fan... disconnect the connectors to the main power supply ( it's the one on top and in the middle). Reconnect after a few minutes.
If the problem is not solved then you might have a faulty power supply board.
Good luck.
Note: Make sure that you unplugged the TV power cable first before you remove the cover. And also while you're vacuuming, you have to hold the metal frame to dissipate the static electricity created by the vacuum (motor).
Good luck.
Posted on Nov 12, 2010
My 39in Emerson TV won't turn on. When using remote or buttons on TV you see little red light flicker and hear a click but no sound or picture. What could be wrong????
It sounds like the power board is failing. If you have a meter you can check the 120 a/c voltage to the board then turn on tv even if you don't see or hear anything check to see if any a/c voltage come out of the main transformer don't know the required voltage from transformer
Oct 19, 2014 | Televison & Video
No sound/picture and red power light always on (Hitachi 43FDX15B)
When u turn the tv on,u hear alot of clicking?That mean the Ballast that help the projection bulb to work is dead.Change the Ballast,might as well change the bulb too.U don't know what is the condition of the projection bulb in.
May 29, 2010 | Hitachi 43FDX15B 43" Rear Projection...
My SD-P6093-K Pioneer has recently stopped turning on. It makes a click noise as if it was turning on, but about 3 seconds later it makes another click noise and then then nothing. No picture no anything....
STK ICs 2 of them,example STK392-110.also CK hori out put transistor and little blue capacitor 2Kvolts it feeds back to Hori Transistor. Mats has STKs
1-800-628-1118 $10.95 each they retail for $55.00 each in repair shops.
Mar 16, 2010 | Pioneer SD-P62A3-K 62" Rear Projection...
When turned on, no picture, sound or response. LED is OK
I had a similar problem with my HANNSLounge 32", the screen switched on with green light but none of the front panel buttons worked (screen is black apart from showing the input source in the top left).
After powering off numerous times I tried starting up with a blank SD card in the reader and the tv cycled between red green and blue screens and then reset itself. (Some sort of firmware restore?) After which point I had a working screen again! (Will have to see how long it lasts for!)
Feb 12, 2009 | Hannspree HANNslounge 32 in. LCD HDTV 32
Standby/timer light stays on red. no picture or sound on tv.
my sony red light flash.but it will not turn on just clicks
Nov 26, 2008 | Sony KP-48S75 48" Rear Projection...
No picture, no sound.
Hi i have a pilips 42" plasma tv (42PF5320/79) i can hear clicking the green light is on and the tv will go into stand by if i press the power button and the red light also comes on .I have turned it on and off and it works now nothing just the light on the front as if its working looking at the back through the slots two green lights come on then the tv clicks and they turn off,thanks
Aug 06, 2008 | Philips 42PF9630A 42 in. Plasma Television
Panasonic pt53wx42f
WHEN POWER IS FIRST TURNED ON I HAVE A SOLID RED LIGHT BUT NO PICTURE. THEN YOU HEAR THE TV CLICK OFF. THEN RED LIGHT STARTS TO BLINK IN SET OF (3) TIMES.
Jun 25, 2008 | Panasonic PT-47WX53 47" Rear Projection...
Sony Trinitron blank tv/no picture
When I turn on the TV I hear the click sound and the TV powers up. Immediatly the red (standby) light begins to flash 6 times on and off. this happenes only in the morning, but after 5:00PM when youturn on the TV as if nothing is wrong.
what is the problem?
Feb 08, 2008 | Sony FD Trinitron WEGA KV-32HS510 32" TV
Lg tv will not turn on, red light
i think your bulb is shot must be replaced
Dec 17, 2007 | LG 42PX4DR 42 in. Plasma TV
2000 27" Sony Wega
Sony has a code for those blinks indicating the problem area. Count the blonks till the pause then google Sony blink codes for the area to fix.
Jul 03, 2007 | Sony FD Trinitron WEGA KV-29LS35 29" TV
Hitachi 42HDS69 42 in. Plasma Television Logo
115 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
