Question about Microwave Ovens
Turntable will not turn. have checked everything. could it be the roller guide? model # is kot-131uw.
  • Microwave Ovens Master
  • 43,501 Answers
Usually when the turntable stops turning it is because the motor that turns the turntable has gone bad...
For may microwaves you can buy a new motor and repair it, but it is cost prohibitive for many as a new microwave is not much more then the parts without considering the labor for installation...
Here isa tip that will help you to figure out what is wrong with your MicrowaveOven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Posted on Nov 12, 2010
Microwave just stopped turning, everything else works
Check the turntable guide to make sure it is lined up properly and that there is no debris caught in it. You may need to re-align or clean your turntable guide.
Cleaning and realigning a turntable guide;
Remove your glass turntable cooking tray from your microwave. Gently wash with warm soapy water to remove any debris. Next remove the turntable guide and clean it in the same manner, with warm soapy water. Pay particular attention to the turntable rollers. There could be spilled food particles caught in the rollers, hindering the rollers' movement. Also, gently cleanse the internal cavity of your microwave, paying special attention to the area below the turntable.
With the internal cavity, turntable, and turntable guide completely clean and dry, return the parts to your microwave. First place the turntable guide on the bottom of the microwave. There should be a circular groove in the bottom of the microwave cavity keeping the turntable guide in place. Follow the guide with the turntable cooking tray. Carefully place the glass tray over the turntable guide and onto the drive bushing. The drive bushing should fit neatly into the grooves on the bottom of your glass cooking tray. It may take some adjusting before the tray will sit properly onto the drive bushing.
Test your microwave after this thorough cleaning and realigning in order to determine whether this has solved your problem. DO NOT run your microwave with nothing in it.
CAUTION: Your microwave oven is capable of giving you a serious electrical shock, even when it is unplugged. We strongly suggest you seek the assistance of an appliance repair technician when conducting any microwave oven repair.
Also, Examine the plastic drive bushing the turntable tray sits on. It may have become worn, or even may have split in two;
Drive bushing replacement
Inspect the plastic drive bushing located below your microwave oven's turntable tray. There may be some debris blocking the tray's range of motion. Clean away any blockage you find, and then test your microwave to see if this has cleared up the problem. DO NOT run your microwave with nothing in it.
However, if upon your inspection, you notice that the plastic drive bushing below the turntable tray is worn and/or broken, you will need to have the bushing replaced. Consult with a certified and experienced appliance repair technician. Replacing a drive bushing is a lengthy and involved process that the average layman should not perform.
Good luck.
Jan 05, 2012 | Kenmore Brew 'n Wave 63992/63999 Microwave...
JennAir JMC7000ADW Microwave Oven Turntable not turning
Good luck.
Dec 17, 2011 | Jenn-Air JMC7000 Microwave Oven
Turn table turns some of the time
Good luck.
Walesarumi
Sep 26, 2011 | Kenmore 66469 / 66462 / 66464 Microwave...
I have a built in convection/microwave oven model AWM540IX, the turntable is not turning, is there anything I can do or will I need to get professional assistance?
Good luck....
Mar 21, 2011 | Whirlpool Microwave Ovens
The turntable on our Ewave KOT 170SW Microwave oven has quit rotating. Other than that the oven works fine. Any troubleshooting tips? If the turntable needs to be replaced, how big a job is it? I'm not...
i went to replace lite bulbs but didnt unplug it..removed cover and shorted out...now no lite and no turntable but does come on & heats food is it fixable.......ewave microwave kot-131uw....
Feb 28, 2011 | Kenmore 80412 Microwave Oven
Microwave quit
Well first of all you can try to clean the turntable- Remove your glass turntable cooking tray from your microwave. Gently wash with warm soapy water to remove any debris. Next remove the turntable guide and clean it in the same manner, with warm soapy water. Pay particular attention to the turntable rollers. There could be spilled food particles caught in the rollers, hindering the rollers' movement. Also, gently cleanse the internal cavity of your microwave, paying special attention to the area below the turntable. With the internal cavity, turntable, and turntable guide completely clean and dry, return the parts to your microwave. First place the turntable guide on the bottom of the microwave. There should be a circular groove in the bottom of the microwave cavity keeping the turntable guide in place. Follow the guide with the turntable cooking tray. Carefully place the glass tray over the turntable guide and onto the drive bushing. The drive bushing should fit neatly into the grooves on the bottom of your glass cooking tray. It may take some adjusting before the tray will sit properly onto the drive bushing. If further you have the same problem then this could be a failing turntable motor...... Please post comments for further help or information.......
Good Luck!!
Thanks
Jun 25, 2010 | Sharp R-1610 Microwave Oven
E Wave microwave stop heating
Sounds like the magnetron has failed. There are some high voltage circuits that feed the magnetron and you can potentially get hurt if you don't know what you are doing. Would recommend you have it serviced by a professional if you want it fixed, otherwise look for a new one since the cost of repair can come close to the price of a new microwave oven.
Dec 27, 2008 | Dacor DMT2420 1200 Watts Microwave Oven
E-wave microwave model #kot-131uw just quit all of a sudden
Is it dead, meaning no display, no light when you open the door and no beeps when you press a pad on the keypad
Dec 03, 2008 | Microwave Ovens
Microwave Ovens Logo
24 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
