Question about Speed Queen AES28AWF Electric Dryer
WHILE TURNING THE SWITCH TO DRY IT BUZZES THEN STARTS THE DRYER ROTATING . IT WILL NOT START BACK UP IF I OPEN IT UP AFTER I GET IT GOING .IT WILL ONLY START THE DRYER IF I UNPLUG IT AND WAIT A WHILE THE SWITCH SEEMS TO RESET THEN WORKS. BUT IF I OPEN IT UP AND SEE IF ITS CLOSE TO DRYING IT STOPS AND WILL NOT RESTART. DO YOU THINK THIS IS ONLY THE SWITCH. IF SO WHERE MAY I OBTAIN ONE IN THE KC AREA?
5 Suggested Answers
SOURCE: Dryer is not drying clothes dry
My Maytag Neptune isn't drying my clothes
Posted on Oct 14, 2009
techline
  • 39 Answers
SOURCE: My dryer-Speedqueen AES17AWF- was drying, I opened
try turning the drum by hand both ways, it will turn hard, but it should turn, if it doesn't, then you have something caught in the blower wheel. If it does turn, close the door and try to start it again. Hope this helps!
Posted on Dec 06, 2009
  • 205 Answers
SOURCE: gas dryer won't dry clothes.
Hello- You most likely need an ignitor or thermal fuse if you are getting no heat at all. Depending on you exact model and if you are electrically handy and have a multi-meter you can test these components and replace them. If you are at all uncomfortable have a Tech come out, they should have the parts on hand and it should be a fairly easy fix. Hope this helps, best regards.
Posted on Sep 27, 2010
Daniel S
  • 4323 Answers
SOURCE: I have a model
Hi
I believe that everything else is fine rather it is the thermal fuse that is located inside the rear panel to the exhaust duct that is bad and should be replaced. If you want you can test this fuse for continuity and if it is bad then it should be replaced, as it cannot be reset. If the fuse is fine then it can be due to the control board that is bad and should be replaced. Hope this helps...please post back for further assistance.
Daniel
Posted on Sep 06, 2011
Put in a new start switch. now when i turn switch on it just buzzes. if i start turning drum by hand it starts. ?
It sounds like your dryer motor has a bad "start capacitor" or is not getting the full 240 volts to make it start.
If it is getting hot enough to dry the clothes in one run cycle, than it will be the capacitor that is the problem.
If you don't have much experience with electrical motors, I suggest to call a qualified technician and have him address the problem.
Good luck with that
Feb 11, 2016 | Dryers
Dryer makes a buzzing noise when I turn it on but it doesn't come on, just buzzes.
Open the dryer door and slowly rotate the dryer drum in a counterclockwise (CCW) direction. Rotate the drum 2-3 revolutions and then shut the door and see if it will start. If it continues to just hum and not start could indicate a voltage issue, motor issue or a friction issue. Open the door again and locate the door switch plunger in the upper or lower corner on the hinge side of the drum opening. Hold the plunger in while someone begins rotating the drum counterclockwise. While turning the drum counter clockwise and holding the door switch plunger inwards press the start button. If it starts, there is likely a friction problem or motor problem.
What is the model number?
Nov 06, 2012 | Dryers
Dryer buzzes but won't start
see the diagram :
1) O.k if the thermostat 2) Thermofuse is o.k is good resultant BUT please 3) Test the door switch for open or defective , if the remain open the motor will NOT START. see the diagram. 4) After changing the switch if the problem remain the same the motor is faulty( centrifugal swithc, etc) need repair or replace. 5) Test the push button start for diryt or open, test the wires for loose, broke, or burn wires too.
God bless you
Jun 09, 2012 | Whirlpool LER4634J Electric Dryer
Kenmore dryer 70 series doesn't always start, sometimes it will just put out a buzzing sound after its been running and trying to restart, will start back up after 20-30 minutes.
Oct 02, 2011 | Kenmore 63942 Dryer
Maytag Performa dryer blows fuse after clothes get hot. I cleaned a large buildup of lint from inside the dryer all the way to my roof. I then replaced the hi limit thermostat, thermal fuse and dryer...
their are two possiblities causing that
1) while cleaning the lint from the motor a wire accidently got pulled of of the motor switch
2) to me the buzzing when start button is pushed and may or may not start,the motor is bad
When trying the trick to start the motor by hand the door switch also must be pressed in
Gene
Aug 05, 2011 | Maytag PYE2200 Dryer
Start button buzzes when pressed, dryer doesn't start.
I assume the buzzing quit when you release the start button. Open the dryer door and slowly rotate the dryer drum in a counterclockwise (CCW) direction. Rotate the drum 2-3 revolutions and then shut the door and see if it will start. If it continues to just hum and not start could indicate a voltage issue, motor issue or a friction issue. Open the door again and locate the door switch plunger in the upper or lower corner on the hinge side of the drum opening. Hold the plunger in while someone begins rotating the drum counterclockwise. While turning the drum counter clockwise and holding the door switch plunger inwards press the start button. If it starts, there is likely a friction problem or motor problem.
Apr 26, 2011 | GE DVL223EBWW Electric Dryer
When hitting start button, it sometimes buzzes, but fails to start. Can sometimes wait for a little while and try again, and it starts. When it buzzes, it will only buzz for a few seconds and then nothing.
it is either the door switch or start switch, this website will show you how to test both, Good Luck Tim:
http://www.partselect.com/dryer+dryer-wont-start+repair.htm
Apr 16, 2011 | Whirlpool LER4634J Electric Dryer
Whirlpool Dryer model # LER7646E will not start but is getting power, start switch buzzes when activated.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer is not Turning
Dryer Repair - The
heatman101
Dec 16, 2010 | Whirlpool Dryers
When turning the knob to start dryer, buzzing sounds but drum doesn't start to turn unless you gently push atart the inside drum
The problem is either a faulty start winding in the motor, or the circuit which energizes the start winding is failing.
A dryer motor has two windings: start & run. The start winding gets it going and a centrifugal switch disconnects the start winding when the motor gets up to speed.
Check the dryer start switch -- then the motor connections and the centrifugal switch inside the motor.
May 05, 2009 | Dryers
Dryer doesnt turn on
take the top of your dry off and look by the buzzes to see there fuse there it could need new one
Apr 18, 2008 | GE DSKP233EWWH Electric Portable Dryer
Speed Queen AES28AWF Electric Dryer Logo
37 people viewed this question
Top Speed Queen Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
danoyachtcap
danoyachtcap
Are you a Speed Queen Dryer Expert? Answer questions, earn points and help others
