Question about HP zx6000 Tower to Rack Conversion Kit
Printer does not scan - HP zx6000 Tower to Rack Conversion Kit
  • 475 Answers
Re install your printer driver or you can download a driver if you have no installer at HP website: www.hp.com and if it doesnt work, you can test it on another pc or laptop check the USB Cable.and you can use another USB port on PC for that for getting nice result!
Check the paper jam.
Hope fully it works ....
Posted on Nov 12, 2010
How do i scan a document?
Hi, it all depends on the printer your using.
How to Scan a Document on a Multi-Function Printer
A multi-function printer with a scanner makes backing up your important documents easy. The scanner function of the printer allows you to translate a paper document like a receipt or title deed into an electronic copy that is stored on your computer. Once you have an electronic copy of your document, you can process and manipulate the document as you would any other electronic file. Follow these steps to scan a document on a multi-function printer:
Connect your multi-function printer and computer. Power them up.
Select the side of the document you are going to scan. Give the document a once-over, checking for any flaws that you do not want transferred into electronic form.
Open the printer's lid. Place the side of the document you want scanned face-down on the glass plate of your multi-function printer's scanning bed. Align the document to your satisfaction.
Close the printer's lid carefully. You may want to weigh the document down with another sheet of paper to prevent it from shifting.
Choose an appropriate scan resolution. You may have to do this using the controls of your printer or on the computer, depending on the model and software.
Press the scan button to start the process. This can be done on the printer itself or on the computer.
Preview the scan on your computer monitor. You should be able to make minor changes to the scanned image if needed.
Save the scanned image if you are satisfied with the result. Try again if you are not satisfied.
Tips & Warnings
Scanning documents at high resolution and low data compression will produce the best image quality at the cost of file size.
Not happy with a scan? Re-check the alignment of the document and try it again. Discard the duds when you get a scan that works for you.
Using harsh cleaning chemicals such as acetone or benzene can damage your multi-function printer. Abrasive cleaners are also not good on the machine, particularly the glass surface of the scanning bed.
....How to Scan a Document on an All-in-One Printer?
Scanning is a standard all-in-one printer feature that converts a hard-copy document into electronic information, which your computer can store and modify. You can scan legal files, office reports or just about any other kind of document and create an electronic backup for your files, send it as email or alter it to suit your needs. Follow these steps to scan a document on an all-in-one printer:
Turn on your all-in-one printer and computer. Check the connections between the two machines.
Lift the printer's document lid. Examine the scanning surface and the underside of the lid for dust and fingerprints.
Put the document you wish to scan face-down on the glass. Use the alignment markers to help you square up the object. These are usually found on the left-hand edge of the scanning area.
Close the printer's document lid slowly so the document does not shift position.
Select a scan resolution. The higher the dpi (dots per inch) count, the sharper and more detailed the image.
Push the scan button. You may have to do this on the printer itself or on your computer.
Check the preview of your scan on your computer. Depending on your all-in-one printer and software, you may have to prompt your computer to display the preview for you.
Edit the image as it appears on your computer if you want to make changes. Your scanning software might let you enlarge, resize or otherwise manipulate the final product.
Accept the scan and save. Return the original document to a safe location.
Hope it helps..
Oct 28, 2010 | Office Equipment & Supplies
Kodak ESP5 AiO Unable to scan to PC. Error code on opening Scanner 2106 Please advise,THANK YOU!
Please clarify a few things for me so I can help you solve this issue.
Are you trying to scan from the printer to the computer? (pushing the scan command on the printers keypad to send the signal to the computer)
OR
Are you trying to scan from the computer to the printer? (Using the scan options in your software by choosing "start" and then "programs" and opening your printers software to choose the scan option)
If your scanning from printer to computer (using the printers scan option on the keypad) and your getting an error code, chances are the problem is you have not set up your defaults in the printers menu yet. To scan from printer to computer, the printer needs to know which program you want your document to scan to in your computer. If its a text document, some people choose "Microsoft Word" and the scan fuction sends your item to that program and opens it for viewing on your computer screen.
There are different programs to use for each type of fax that need to be set up in advance in your printer to be able to scan from printer to computer. Send pictures to a photo editing software and choose the size and resolution you want as "default". Do the same for setting up text documents before you try and use this feature to eliminate the error code.
To configure your options to scan from printer to pc, push the "menu" button on your printer and use the up and down arrows on the printers keypad to move through the choices. Find the command similar to "scan options" and follow the prompts to set the defaults on handling text documents and pictures and then save your choices by pushing the "ok" button on the printers keypad.
Try scanning again with your computer turned on and open to the desktop. Push the scan button on the printer and see if it sends the image or document to your computer screen. It should warm up, then scan and show a preview on your screen for you to accept or reject. If this does not happen, please asnwer my questions as listed above and clarify what you see so I can help solve this issue right now.
Sep 27, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
When trying to scan a photo from the c7280 to the computer the printer displays the following error message No Scan Options : refer to documentation and troubleshoot. This is not covered in my printer...
That's because it's not a printer problem. The scan options are in your computer in the scanning software for your machine. Before you can scan you need to be connected to your computer with scan software running to tell it how to scan, what you're scanning, and where to send and save the image you scan.
Apr 20, 2010 | HP Photosmart C7280 Laser Printer
How do I scan on my 810 all in one? I just installed the printer.
Along with the drivers for the device you may have installed some program too. Use this program to scan the documents. Alternatively you can use Word or other word processor to scan.
Jan 04, 2010 | Dell 810 All-In-One InkJet Printer
Trying to scan pics on HP Officejet 7110. Press 'Start Scan,; display on printer shows 'Scanning to Microsoft Outlook' for over one minute. I can hear the machine scanning and see the scan light working....
Nothing in or jamming document feeder tray.
Change the setup to scan to a file, rather than email.
Try a different USB port.
Reboot all.
Reinstall printer/scanner drivers and software.
Nov 17, 2009 | HP Officejet 6310 All-In-One InkJet...
The printer is not scanning
kindly check scan lamp or else maybe scan software is not properly installed by you
Aug 28, 2009 | Dell 962 Photo All-In-One InkJet Printer
When i select scan the printer scans using photoshop. this didnt happen till recently, how do i go back to just using the printers scanning set up?
if u got problem like this, using menu scan from your computer .
from menu scan , you can choose printer scan option
Jul 29, 2009 | Canon PIXMA MX310 All-In-One Printer
Can not scan to my computer
Scanning thru a wireless connection is not supported on these printers. Printing does not require that much data to be sent back to the computer, scanning of course does. Printers require a bi-directional signal path to allow scanning such as USB and parallel ports. Sorry to be the barer of bad news.
Buddy
Corporate Computer
Over 21 years supporting/repairing PCs and printers
Jun 18, 2009 | HP Photosmart C7280 Laser Printer
Computers & Internet Logo
43 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
