Question about Maytag Neptune MDE5500AY Electric Dryer
Rattling noise, sounds like its coming from the rear Dryer does run and operates seems to quit after it warms up (1 to 2 Minutes)
  • Maytag Master
  • 3,053 Answers
Hello, jr I was trying to help you out here. I wasgoing back to some customers that asked questions in the past and it appearedthat no one answered them, so I thought I would take some of my personal timeto see if I can help. Here is a link to about everything you want to know aboutyour dryer, from repair to trouble shooting it. If you go to this link andclick around, I am sure you will find out so much about your dryer, you willknow more that the company that made it. Here Is the link for you to click onhttp://home.howstuffworks.com/how-to-repair-a-dryer.htmPlease if this helped you at all, if youcan find the time to rate my help and some kind words written would beappreciated for my free help , I would appreciate it. Here is also my direct link to my own pagesof other areas of my expertise for other problems you might have in Automotive,Appliance, and Electronics. Drop In anytime for my help. Thanks So Much, Mike http://beta.fixya.com/users/mc1bean
Posted on Oct 26, 2011
My Audi A4 2009 makes a rattling noise on cold starts which resolves in less than 30 seconds. Dealer says its an air pump. This doesn't seem correct. The noise comes from the front of the care. Does not...
READ THIS (happy ending so far...):
audi a4 2L turbo quattro, manual transmission with 98,000 KM. Perfect conditions, no oil leaks whatsoever.
Left the car off for two weeks in very cold weather (-10C down to -25C). When I restarted, it started immediately but with heavy rattling noise due to camshaft adjuster not getting enough oil pressure. After 3 minutes of warming up (outside temp.: -12C) at very low rpm (below 2,000rpm), I start moving the car. Still hearing heavy rattle noise. As soon as I pass 2,000 rpm, I get a scary red warning, low oil pressure. Turn off the engine immediately. In 1 minute, I re-start the car and the engine lights check ok, so I drive in first gear super slow (1,200rpm) hearing the same rattling noise. After another minute, finally the noise all the sudden disappears and the car starts running just fine.
Called Audi dealer and they told me that in extreme weather conditions, I should warm the engine for 10-15 minutes if necessary before start moving.
Take away: luckily, I didn't screw up the engine since I was using it at extremely low rpm (easy to do with clutch and manual transmission) until the oil reached full pressure. I am pretty sure now that the problem was leaving the car off for such a long time in freezing weather. All the oil flows back to the bottom, and when I restarted it, the cold oil with high viscosity took a long time to reach all the parts of the engine, specially the camshaft adjusters that are actuated by using oil pressure. Next day, the car started at -9C perfectly without making any noise (as usual). Basically, the longer you leave your audi in cold weather, the longer you might hear the rattling noise until the oil reach full pressure inside the engine. My car took 6 minutes to fix it after couple of weeks in cold weather. This makes sense to me; in fact, in the past I only heard the rattling noise after leaving the car off for a couple of days in the winter.
So far, this has had an happy ending....
Dec 19, 2010 | 2009 Audi A4
Dryer starts fine, runs fine, heats fine, but makes a clicking / rattling sound while running. Sound is coming from rear, like where metal tube is connected.
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Sep 14, 2010 | Whirlpool Dryers
Loud vibrating noise after warming up
heatman101
May 10, 2010 | GE Profile Harmony DPGT750EC Electric...
3 yr old LG TROMM DLE 5977W Dryer-loud rattling noise started about a month ago.If I press on the front of the dryer below the door it stops.Something has come loose that stopped the vibrating noise?How do...
Remove the bracket at the top rear of the dryer 6 screws
Tilt top up and forward to remove
Remove operator panel by unplugging connectors and removing screws.
Pull up and forward to remove front panel
Nov 06, 2009 | Dishwashers
My Maytag gas dryer makes a loud rattle and clanging noise.
Prob. some failure of a bracket or loose inside...
Have a local tecnician check it out.
i think that ll be best cause i can't imagine that will be an easy fix.
I hope this is useful, and greets,
Olivier.
Oct 21, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Electric Maytag Neptune Dryer - rattling noise
Your probably going to have to remove the rear panel and take a look to see what is causing the noise.
Disconnect the power cord and exhaust tube, remove the rear panel and check for anything loose.
You can also pop the lid and fold it back to inspect the top of the tub and belt. Roll the drum all the way around and inspect the belt for "chunks" missing.
If you include your model number, I can send you a web site that will show you an exploded view of the dryer.
Regards,
Aug 14, 2009 | Maytag Neptune MDE5500AY Electric Dryer
KENMORE DRYER
Hello ENRIGHT11 Welcome to Fixya
My name is Huum,
You said,
DRYER MAKES VERY LOUD NOISE WHEN RUNNING. ALTHOUGH IT HEATS UP AND BEGINS TO DRY, IT STOPS RUNNING COMPLETELY AFTER ABOUT 5 MINUTES. IF YOU WAIT AN HOUR, YOU CAN START IT AGAIN, BUT IT AGAIN SOUNDS VERY LOUD (ALMOST A RATTLING SOUND) AND THEN SHUTS OFF AFTER 5 MINUTES
Faulty Blower Wheel
If you hear a great deal of noise coming from the blower area of the dryer when it is running, then the blower wheel could be defective.
The are many different designs for blower wheels and just as many unique failure modes. Vanes (fins) can break off the wheel and bounce around in the blower breaking more pieces. The blower can break around the coupler with the shaft. This can cause the blower to spin loosely on the shaft. The blower can form cracks which cause it to vibrate, etc.
You should also not be surprised to find foreign debris in the blower. The occasional bird, rodent or squirrel has been known to bypass the out vent cover. If they crawl into the exhaust tube the first thing they come into contact with is the blower wheel.
If the blower wheel is not spinning, or if it is missing vanes, it is not moving air efficiently. As a result, heat is not removed from the heat source and it can trip the high limit switch or blow the thermal cut-off.
Worn Belt
A worn belt can stretch and/or become brittle with age. The belt can then slip on the drum or motor to cause squeaking. If this is the case, the solution is to replace the worn belt.
The belt is not the only item that can cause squeaking. It can also be caused by a faulty idler pulley, worn drum bearings, worn drum glides or worn drum rollers depending on brand and style.
When replacing the Belt is is a good idea to also change the Drum Support Rollers, Drum Glides, Idler Pulley and Clips. All of these items are economical easily changeable when replacing the belt. The upside is that your dryer will operate like new.
Recent Customer Symptoms:
Dryer makes loud noise when turned on. Dryer works and heats up OK but makes too much noise.
Worn Drum Glides
Some dryer models are equipped with Drum Glides. The front of the dryer rests on these glides. They provide a low friction surface on which the drum spins. After time however, this glides wear down. Much like an automobile brakes, these glides make a load grinding noise when they wear thin. This griding against the drum usually leaves a bare metal stripe that is visible at the point of contact. If the glides are worn, the solution is to replace them.
The drum glides not the only items that can cause squeaking. It can also be caused by a faulty idler pulley, worn drum bearings, a worn belt or worn drum rollers depending on brand and style.
When replacing the Drum Glides it is a good idea to also change the Drum Support Rollers, Drum Belt, Idler Pulley and Clips. All of these items are economical and easily changeable when replacing the glides. The upside is that your dryer will operate like new.
Worn Rear Drum Bearing
Some dryer models are equiped with a Rear Drum Bearing. The rear of the drum rests on this bearing. It provides a low friction surface on which the drum spins. After time however, this bearing will wear down. If the bearing is worn, the solution is to replace it.
The rear drum bearing not the only item that can cause squeaking. It can also be caused by a faulty idler pulley, worn drum glides, a worn belt or worn drum rollers depending on brand and style.
When replacing the rear drum bearing it is a good idea to also change the drum glides, drum support rollers, drum belt, idler pulley and clips depending on make and model. All of these items are economical and easily changeable when replacing the rear drum bearing. The upside is that your dryer will operate like new.
Worn Drum Support Rollers
Some dryers such as Whirlpool/Kenmore brands are equipped with Rear Drum Support Rollers. The weight of the dryer drum rests on these rollers. They provide a low friction surface on which the drum spins when in operation. After time however, these rollers wear down. When they wear, often times they begin to elongate and form a non-round 'cam' shape. The result is that when the dryer is turned on it creates a rumble that sounds as though you are trying to dry a pair of tennis shoes. This sound is usually the drum being forced up and down on the non-round wheels. If the rollers are worn, the solution is to replace them.
When replacing the Drum Rollers it is a good idea to also change the Front Drum Glides, Drum Belt, Idler Pulley and Clips. All of these items are economical and easily changeable when replacing the glides. The upside is that your dryer will operate like new. Whirlpool
Kenmore models have a dryer maintenance kit that contains all of these items in a single kit.
Thank You For trusting us with your question
Please remember to leave a
solved rating before you leave!
Jan 21, 2009 | Kenmore 63942 Dryer
Dryer is making loud thumping noise.
Take off the back panel of the dryer and look at the motor and belt turning the drum. There may be something caught on the drum and is pinned in place causing the noise. The motor could be loose on the platform and needs to be tightened. It is probably something physical and seen causing the noise.
Jan 04, 2009 | Whirlpool LER4634J Electric Dryer
Kenmore 80 series dryer.
true story.I brought my lawnmower to a friend of mine,i said to him Tony my lawnmore is making a terrable noise, he said to me worry when its making no noise...its possable a worn tension pully it would make a rattle like sound,Solution replace pully wheel!.Top of the morning to you Eire
Nov 15, 2007 | Kenmore 63942 Dryer
Maytag Neptune MDE5500AY Electric Dryer Logo
37 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
