Question about Canon PowerShot S400 / IXUS 400 Digital Camera
Compact flash error
My camera is fully charged, but when I try to take a picture, the message "memory card error" flashes on the screen.  I have tried several different cards with no luck.  Any ideas as to what my problem is?
  • 4 Answers
Try this link,/?St=68,E=0000000000429774916,K=2059,Sxi=0,Case=obj(45929)
If you have the right error they will repair it for free. Had mine done just before Christmas 07.
Posted on Jun 18, 2008
Olympus E520 compact flash card error
I hope you never tried to put in a memory card in, the wrong way around. This could have damaged the contacts in the camera. Or perhaps only one or two contacts in the camera are dirty or oxidised?
With a bright light and perhaps a magnifying glass, look in the memory card holder, to see of all contacts are clean and shiny and not one is bent, ir has a little dent.
If a contact is dirty use a little wooden or plastic tooth pick, to solve the problem. eventually make the point of the pick a bit softer, be cats for rubbing of some dirt, this will be enough. You never should use sharp looks in or close to a camera.
Mar 21, 2014 | Olympus E-520 Digital Camera
Busy flash picture and 3484 code
When showing busy, most of the time the camera detected an error, but can't find out what is causing the error.
Try the normal "reset" method as follows:
Like a cold boot for a computer, the camera can be "rebooted"
follow the following steps:
Switch of the camera and remove the battery.
Remove the memory card and the lens. (if possible)
Recharge the battery. Wait till the indicator on the charger indicates the battery is fully charged.
Check all contacts, if they are clean and shiny. Contacts (from battery and memory card, only to be cleaned with a dry cloth or cotton swab(s).
Reinsert the battery, reinsert the memory card and re-attach the lens.
Then switch on the camera.
If this does not help, contact a certified Canon repair centre.
Nov 29, 2013 | Canon EOS 400D / Rebel XTi Digital Camera
Digital Camera: How to Fix Compact Flash Memory Cards ErrorIt is not very typical for compact flash memory cards to give you an error. If you do receive an error, it most likely means that a pin within your CF card slot is bent, or your CF card has become corrupted. Unfortunately, if your CF card has become corrupted, you will need to reformat the memory card, which means that you may lose any pictures that were located on the card.
Fixing Your Flash Memory Card
You will want to remove your CF card and the batteries. Take a look inside the CF card slot to see if there is a bent pin. If you find a bent pin, you can correct this problem using a very small and skinny flat screwdriver. Moving very slowly, use the screwdriver to bend the pin back into place. You do not want to use enough force to make the pin back in one shot.
The pin does not have to be perfectly straight, but get it as close to straight as possible. Insert your CF card back into the slow very slowly. You should see the in align itself with the card. You can turn your digital camera on to verify that the compact flash memory card is now working.
Mar 11, 2011 | Cameras
I have a Cannon EOS Digital Rebel Xti. When I try taking a picture, I keep getting an error message indicating there is a problem with the CF Card. I have replaced the card several time but keep getting...
What you require is to format the Compact Flash Card. The CF card should be formatted when new and after every download. Format the card in the camera it is going to be used it. Constantly deleting pictures on the memory card will cause major corruptions and total failure. Formatting cleans the memory and allows the camera to communicate properly with the CF Card.
I going to give you several diagrams on where to go in your camera to format. these diagrams are screen shots right from your manual.
Dec 29, 2010 | Canon Rebel XT / EOS 350D Digital Camera
From Cannon, I just got back my camera back, after having it reworked for the purple image problem (a recall on this model). I took pictures yesterday find yesterday and today, trying to download, I 'read'...
Take a look inside your camera's CF card slot. I suspect that you may have a bent pin in there. If so, don't fret. Although professional repair would be more costly than the value of the camera, there is a very good chance that you can repair this yourself. Please see the following:
Jul 05, 2009 | Canon PowerShot S1 IS Digital Camera
Locked Memory Card
I use a Nikon D300 and have Sandisk Compact Flash memory cards. i ahve not come across this problem but would suggest that you insert the memory card into your camera and reformat the memory card. This should clear any errors in the system BUT IT WILL ALSO WIPE ANY PHOTOGRAPHS YOU AHVE TAKEN when formating the memory card.
Oct 20, 2008 | SanDisk ULTRA II 4GB Compact Flash Card...
Nikon D70
It is actually an error message generated by your compact flash and means that the card is no longer readable. A lot of D70 owners have reported this error without being able to find another solution other than reinserting the card or changing the card to a different brand. In my D70s I use Sandisk Extreme III memory and, knock on wood, have not yet had this error. You could also try cleaning out the memory card slot and check to see that all pins are aligned and not bent.
Good Luck,
May 12, 2008 | Nikon D70s Digital Camera
Media selection
have you tried using a different brand?
May 07, 2008 | Fuji Finepix S9600 Digital Camera
Compact Flash Problems
have you tried to reformat the CF card?  If you deleted the image through your computer and not with the camera, the computer may have removed more than what was needed...
Oct 27, 2007 | SanDisk ULTRA II 4GB Compact Flash Card...
Memory card not reading in canon a75
So as not to spoil your vacation, go buy yourself a new compact flash card locally. They should sell them anywhere electronics are sold, including WalMart, etc. See if you can get this new card to work in your camera. If so, then you can work on trying to get your current CF to work, by trying to format it in the camera. If you can't get a new CF to work in the camera, then you likely damaged either the pins in the CF socket in the camera, or some switch that is pushed when the card is inserted (to tell the camera there is a card in it). It is unlikely you will be able to have this fixed during your vacation, unfortunately.
Mar 05, 2007 | Canon PowerShot A75 Digital Camera
Canon PowerShot S400 / IXUS 400 Digital Camera Logo
98 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
