Question about Encore The Print Shop 23 Deluxe Full Version for PC
Printshop 23 runtime error...how to fix? - Encore The Print Shop 23 Deluxe Full Version for PC
2 Suggested Answers
  • 197 Answers
SOURCE: I am running printshop 23
did you recieve a tryal vertion or have you been updating the programs updats
Posted on Aug 18, 2011
I want to know the signification on error9401
Runtime Error Runtime Error 9401 is a common kind of computer error that can be caused by damaged registry files, damaged .log files, faulty program installation and uninstall, serious virus attacks and application confliction. Runtime Error Runtime Error 9401 problems sometimes are hard to detect by Windows operating system itself and you have to restart your computer to get rid of Runtime Error Runtime Error 9401.
Runtime Error Runtime Error 9401 can lead to:
  • Blue Screen of Death Errors
  • Registry errors
  • Obscure computer errors like ActiveX Errors, DLL errors and EXE errors
  • Serious Malware Threats
  • Slow PC Performance
  • Computer & Application Shutdown
Apr 17, 2015 | Cars & Trucks
Runtime error R6034 on my pc ,how do i fix it?
re-install run-time C++ libraries from Microsoft site
Feb 06, 2014 | Sony HDE1/B 1TB External USB Hard Drive...
Installing print shop 23 on windows 8.1 get framework incompatibility error. what should i do?
I now have PrintShop 23.1 up and running on my Windows 8.1. This is what worked for me:
1. First, RIGHT CLICK on the Printshop icon on your desktop, select Properties, click on Compatibility, and make the selection to run the program in Compatibility Mode for Windows 8. Click Apply, then OK to exit.
2. Double click the Printshop icon on your desk top to open Printshop. If it works - great! However, if it does NOT work, it means the .NET framework required to run the program was uninstalled or corrupted by the Windows 8.1 upgrade and needs to be reinstalled, so please do the following.
3. From your Control Panel, select Programs and Features; in Programs and Features, uninstall Printshop. (You get to the Control Panel by clicking on Settings in your desktop popout taskbar, usually on the right side.) 4. Check to make sure the Microsoft .NET framework is also uninstalled. If not, attempt to uninstall. If you have recently gone to Windows 8.1, it may be partly or fully uninstalled because the 8.1 upgrade might have removed (or damaged) part of it. If it will not uninstall, don't worry! Proceed . . . 5. Follow this step even if you see no sign of the .NET framework in Programs and Features. It is almost certain that you have debris from it on your computer because this is a known problem, and Printshop will not reinstall unless the debris is removed. THEREFORE, clean your computer by using the Microsoft .NET Framework Cleanup Tool found at the following link:
.NET Framework Cleanup Tool http://blogs.msdn.com/b/astebner/archive/2008/08/28/8904493.aspx
6. AFTER Printshop is once again installed, it will very likely NOT RUN unless you follow Step #1, above, to run it in Windows 8 Compatibility Mode.
Dec 20, 2013 | Broderbund The Print Shop 23 Deluxe
Uninstalled printshop 23 and am having problems re-installing. The installation process stops half-way through the process.
Hi Sharon
Had a quick look on the support page for this product and found the instructions, have a look here
Andrew Wright
Feb 21, 2012 | Encore The Print Shop 23 Deluxe Full...
I am currently using both Print Shop 5.0 Premier and Print Shop 10. I am switching to a new computer with Windows 7 and will need to install Print Shop 23 Deluxe. Will I be able to retrieve all the files...
I will advice you to locate the print-shop folders that are on your computer. or simple open one of the files you created with this software and right click file location. it will open where all the other files are stored on your computer. backup everything stored on your computer to a flash drive.
Let me know if this solution helps.
May 14, 2011 | Encore The Print Shop 23 Deluxe Full...
I purchased printshop 20 deluxe and installed on my computer which has windows 7 installed on it. The installation shows it was successful however when I try to run the printshop program it tries to start...
The Print Shop version 20 Deluxe for PC is not compatible with Windows 7. The newer Version 23 is compatible. This is due to software compatibility issues with Windows 7.
You can check for Win 7 Compatibility for "software or hardware" @ Windows 7 Compatibility Center
It will not run on Win 7, even when you are using the Compatibility Mode options. Too bad you have to get the newer version 23.
Hope it helps.
Mar 14, 2011 | Broderbund The Print Shop 20 Deluxe for PC
I just purchased router WRT 120 N during the installation I am getting the error 322
HI there,
To fix Runtime error 332, you should understand the concept of Runtime error 332 and identify the causes of it firstly. What is Runtime error 332? This error usually occurs when a DLL file is missing, or not registered on your computer. It is a really common problem for windows users which crashes now and then.
#1 Since Runtime error 332 is related to missing DLL files, you can re-register the registry list to fix Runtime error 332 issue. For example, if you encounter Runtime error 332 at dll files, to re-register the file, please do this:
1. Click Start-Run
2. Type in regsvr32 c:\windows\system32\dllfile Download Repair tools (http://www.registryquick.net/page/RegistryQuick_setup.exe)
3. Re-start your computer
If you can not find the specific file on you computer, you should download it from the Internet and locate it to the right place.
#2 To fix Runtime error 332, you also can try to run free registry scan for your computer. In my opinion, it is the most important step for you to fix Runtime error 332 and avoid other runtime errors effectively. There are various registry repair tools available on the Internet that scan, analyze, and fix your computer. Besides fixing your Runtime error 332, these tools will remove any registry errors, invalid shortcuts, duplicate files and repair DLL files. Eventually, you computer will be free from system error messages and sluggish performance. What you need to do is to fix Runtime error 332 as well as other registry errors to prevent your registry from total corruption. If you continue to run this damaged system and don't fix Run-time Error, this potential risk will bring you more troubles, Even system crash.
Dec 20, 2010 | Linksys WRT120N Router
My system is windows vista 64 bit. Print shop
you have to go to the help section or help tab at the top of your printshop window, on your printshop program...and then click technical support , and it will give you options...click on the option of troubleshooting and it will take you to the broderbund direct online troubleshooting page, and click on the appropriate option for windows vista 64bit, and it will walk you through step by step; which involves going into your printer port settings under control panel section of your computer, and just follow the online directions...I just did it and my newsletter on printshop 23 deluxe is now saving without problems!
Aug 11, 2009 | Encore The Print Shop 23 Deluxe Full...
Photosmart D7460 will not print envelopes from Printshop 23
u should go to print setup in ur program then go to paper type which u want to use it then select "Envelop" instead of "A4"
Jun 14, 2009 | HP Photosmart D7460 Printer
Encore The Print Shop 23 Deluxe Full Version for PC  Logo
243 people viewed this question
Top Encore Computers & Internet Experts
Prashant M
Prashant M
Are you an Encore Computer and Internet Expert? Answer questions, earn points and help others
