Question about Kodak MX1063 Digital Camera
I dropped my mx1063 and now the lens won't retract all the way, and when I try to turn it on it starts to make the chime sound, but then just shuts right off again. Is there some sort of quick fix for this, or will it need to be disassembled and repaired?
  • Kodak Master
  • 4,738 Answers
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try.
Posted on Nov 12, 2010
If i on the camera the lens won't work properly and message that turn off the camera and turn on again
Hi there:
If the camera has recently been dropped it may have lens damage that is preventing it from powering up. There are a number of ways with which a lens error can be caused. Particulates might have managed to get into the mechanical bits that allow the lens to retract, a purely physical interference with the lens mechanism. If the camera was dropped, especially while the lens was extended, there's a pretty good chance something might have been knocked loose, such as the guide pins upon which the lens withdraws and retracts.
Additional details could find in this article link: fixing-lens-error-on-digital-camera.html
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
Aug 22, 2012 | Sony Cyber-shot DSC-W170 Digital Camera
Kodak MX1063 replaced battery. I have 2 of them . When I turn them on the lense extendeds then retracts and shuts off??? I can not get them to stay on. They are fully charged.
Hi
Thanks for using FixYa. To start with try to blow compressed air around the lens cover so that if there is any dirt it cleans if off. You can also stick a thin strip of paper between the lens shutter and the outer support ring & move it in a way that it clears the debris that's stuck in there. If still the issue is not resolved then you'll have to replace the lens assembly & lens mechanism to fix this issue. It is recommended to be done by a professional. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Sep 15, 2010 | Kodak Cameras
Lens stuck. Will not go in and I cannot take
The lens has probably got something in the retraction mechanism that is stopping it retracting. This can be something as simple as sand or grit or as a result of a drop or knock. In most cases the camera will need to be stripped apart to remove the lens assy before it can be repaired. This is best left to a professional camera repair shop.
Dec 28, 2009 | Kodak MX1063 Digital Camera
The camera will not stay on
try to use lithium batteries they are the stronger in the market, o just grab a fresh AA alkaline batteries, not the cheap batteries for clocks o remotes. otherwise it won't turn on
Oct 08, 2009 | Kodak MX1063 Digital Camera
Turn camera on, lens goes in and out then camera shuts off
You may try resetting the Camera to the original factory settings.
If the issue persists then service will be required.
Aug 27, 2009 | Panasonic Lumix® DMC-FS3 Digital Camera
Lens will not retract, camera was not dropped,
Leave the batteries out for a while and then try turning camera on..hopefully its resets the camera and retracts lens.
Jul 07, 2009 | Kodak EASYSHARE Z1285 Digital Camera
C875 lens won't retract
Camera (with new rechargable batteries) won't let the lens come out or if it does it instantly retracts.
Nov 14, 2008 | Kodak EasyShare C875 Digital Camera
Kodak MX1063 Digital Camera Logo
148 people viewed this question
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
