Question about Ricoh Aficio 1013F Copier
How do I stop information page from printing out?
Have Ricoh Aficio 1013F, after I print or copy, a few seconds later it prints out an information page. How do I stop this from happening?
  • 1 more comment
  • Boban1999 Jul 15, 2008
    I have same problem.I don't know where is this key operator tools and where can i find this option (user parametar), so i can set this parametars to 0?
  • rosaciot Jul 17, 2008
    I have same problem, everytime we turn-on the copier after some time a printed page with system information come out. I can't find on user menu the "key operator" voice :(
  • Tim Babcock
    Tim Babcock May 11, 2010
    Is this happening when you are printing or faxing?
I have same problem.I don't know where is this key operator tools and where can i find this option (user parametar), so i can set this parametars to o?
Posted on Jul 15, 2008
  • 42 Answers
(Reports on/off)-Key operator tools,user parameter,switch03,bits 0 and 5 set to 0.That should do it.
Posted on Jul 06, 2008
Is it possible to do two sided copies with this printer? If so, how can i do that?
as far as i know this can not make a two sided print automatically, but i think you can make a two sided copy manually. first copy the first side then return or place the paper on the by pass tray then print the second second side. hope this help
Sep 07, 2010 | Ricoh Aficio 1013F Copier
Print function is not working properly. I have a Ricoh Afcicio 1013F. It prints a few pages then has an error msg.
Does the machine copy okay? If you copy several pages, do they all come out normally, or do you get an error message like when you print?
What is the error message that shows up? If the machine prints a few pages before the error comes up, and it works fine when you are copying, the problem is likely either with your network or with the application you are trying to print from. Depending on what the error message says, it will help to isolate the problem.
It could also be the print driver itself. You can go to Ricoh-USA.com to the Downloads section and either update or reinstall the print driver if nothing else works.
Jun 05, 2010 | Ricoh Aficio 1013F Copier
My Ricoh Aficio 1013f has 16,000 copies on it. It
Ask the service agent, what the maintance cycle of the model is. Sound like it needs a periodic service.
This being the drum and some rollers. this will resolve the squeak as well
Good Luck
Mar 03, 2010 | Ricoh Aficio 1013F Copier
How to set factory default at Ricoh Aficio 1013F
Hello sir;You may go to SP mode to print out default setting list;
Press "clear mode" key then enter107 then press and hold down "clear/stop" key, touch on screen for "copy" then press 5992 hit enter, touch 0 to print out the standard setting list, turn off the copier when you finish.
Jan 04, 2010 | Ricoh Aficio 1013F Copier
My Ricoh Aicio 1013F is showing a duplicate shadow on the copy.
This is almost always the hot roller and/or the pressure roller bushings in the fusing unit. The Hot roller in this model is rated for 90,000 copies, but they commonly fail earlier than that. The pressure roller bushings also wear as they are made of plastic. If you can drag your finger across one of your copies, and the toner doesn't stick to the paper, then you definitely need bushings.
Check how many copies you have by press the "user tools/counter" button in the upper left of the control panel. You should see the word "counter" on the display. Press the "OK" button near the display; this will show you your copy count. If you are near the 75 to 80,000 mark (or multiples there of [150- to 160,000, etc.]), I'd say it's time to replace the hot roller.
Unless you are certified to work on these machines, you would need to get a service technician to do this. These particular machines are more difficult than some of the larger models, and I definitely would not suggest anybody try this repair unless they know exactly what they are doing.
Dec 15, 2009 | Ricoh Aficio 1013F Copier
How to print middle page from scanned document
Dear! First of all, You should check your printer timer may be it enable and after the completing the time it shutdown automatically. Secondly, You choose custom option and use it command it from 85 to 100 and 30 copies for each it will work completely.
Thank You
Jul 25, 2009 | Ricoh Aficio AP410N Laser Printer
I have option to buy ricoh 1013F copier i need it to be wireless
If you already have wireless setup easiest way is to purchase a wireless bridge, gives you wireless connection with hard wired port to connect to the copier. Configure the bridge to same wireless settings as your network and plug cat5 cable from machine to bridge setup print driver and you are golden,
Hope this helps,
TankMurdock
Apr 23, 2009 | Ricoh Aficio 1013F Copier
Ricoh Aficio 1013F
you need to install printer on computer as network printer from the supplied CD.
Mar 27, 2009 | Ricoh Aficio 1013F Copier
How can I print from Tray 2 on Ricoh Aficio 1013F
It needs to be added within the printer driver.
In The Printers/faxes dialog box, "right click" the "Aficio 1013F", click "properties" click the "accessories" (or "change accessories") button, and add tray 2 as an option, Click "apply", and exit the utility, now you can manually select tray 2 when printing.
Feb 20, 2009 | Ricoh Aficio 1013F Copier
Text "ghosts" or shadows
Replace Drum or blade(if possible) will fix on most types of copiers/printers, or rarer it is cause of fuser.
Oct 19, 2007 | Ricoh Aficio 1013F Copier
133 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
