Question about Sharp 32C-240 32" TV
My tv was on, the tv went black, the tv was making a soft semi rapid ticking sound, the tv was unplugged for 12 hours then plugged back in. The tv is making the same sound? Suggestions or solutions
  • Sharp Master
  • 5,568 Answers
The clicking is caused by the relay that supplies AC to the main power supply. It disconnects repeatedly because there is a fault on the output of the main supply or within the supply itself. If this action didn't happen, it could cause a fire or trip your household breaker. Since this is a CRT type set, I would be checking for a shorted horizontal output transistor or a failed fly-back transformer with which this transistor works to produce high voltage for the CRT and the signal that moves the sweep back and forth across the width of the screen.
The transistor replacement with labor wouldn't be terribly costly if done by an honest tech but if the fly-back transformer has failed, it may not be available any more and would in any case cost $60-100 US plus labor. These two parts will often fail nearly simultaneously as the result of one of them going first, then damaging the other.
Posted on Nov 12, 2010
No picture, but has sound
What make and model of tv, and what do you have plugged into it normally?
Dec 09, 2013 | Sharp 27F541 TV
Westinghouse SK19h210Sd black screen with sound only
Change input device to some other like a DVD player and see.
Switch off TV, switch off power, remove plug and wait for 48 hours and retry.
If problem persists, call in a qualified service technician.
Aug 06, 2012 | Westinghouse SK-19H210S Television
The screen went black but sound was still on. I just unpluged it and then Pluged it back in. But there is a red light flashing.
leave it unplug for an hour if it still do the same thing after plugging in back then its time to call a tech.the problem is in the video section a ic control that section at this time i dont have a schematic for that tv to give you the part number on the chassis.how ever you have not mentioned the model of your set.have a tech look on your set and make some repairs.good luck.
Mar 06, 2011 | Panasonic Televison & Video
The Control Panel/Dispenser light went crazy...
Sounds like a electronics problem would need to replace the board, LG parts are not normally expensive.
Apr 11, 2010 | LG LFX25960ST Stainless Steel French Door...
No picture, then no picture and no sound
if your could hear a slight ticking (tick-tick tick) or whining then some electronic component might have been damaged (shorted). if you have no experience repairing electronic equipments then i suggest you to send your TV to a service station!
Nov 14, 2007 | Toshiba 27AF42 27" TV
Lamps
color wheel brakes then causes this same affects check your wheel
Nov 05, 2007 | Samsung HLP4663W 46" Rear Projection HDTV
No picture
Bad IHVT ( flyback transformer)--need complete service
number off back for part #-----------Let me know...T.
Oct 15, 2007 | GE 46GW947 46" Rear Projection Television
Sharp 32C-240 32" TV Logo
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
