Question about Maytag MER5775Q Electric Kitchen Range
Maytag advanced cooking system
I have a digital oven and do not know how to work it. I cannot set the timer right. I tryed to cook biscuts and the top burned also.
  • johncast Jul 31, 2008
    I have a maytag stove with he advance cooking system, and i don't know how to turn the oven on. and how to set the timmer,THIS WAS A BUMMER LAST THANKSGIVING DAY, WE TRIED TO COOK YESTERDAY, AND CANT REMMEBER HOW WE DID IT, IT TOOK ONE OF THE COMMPUTER WIZ'S THAT WAS HERE ON THANKSGIVING DAY. THOUGHT I START GETTING READY FOR THE NEXT THANKSGIVING NOW, PLEASE HELP, MY E-MAIL ADRESS IS:
    john.castillo.25@verizon.net
  • Anonymous Jan 18, 2009
    maytag electric stove with digital control panel.. How do you set the timer for the oven?
  • 525 Answers
I attempted to locate a user's manual for you but your model number came back as invalid, please recheck your model number, and follow the link that I provided. This will allow you to download a manual for your range.
http://www.managemyhome.com/mmh/products/ManualSearch.action
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
Posted on Jun 18, 2008
How can I set the timer and still use the oven to cook food?
Use kitchen timer not cooking timer, it's written on your oven timer pad. I did that before
Jul 05, 2015 | Maytag MMV4205 Microwave Oven
Maytag microwave suddenly stopped working, overheated, nothing was cooking.
It is more than likely the magnetron is fried, to replace fuse! unplug microwave oven, remove top, "several screws" look to the right to the keypad control board, look down to a printed circuit board, clipped fuse should be near by, pop it out and replace with same current rating, assemble before testing, "lethal voltages present"
Apr 22, 2012 | Maytag MMV4205 Microwave Oven
I have maytag advance cooking system(electric) and the oven will not work.The timer to set the oven and the time is not lighting up but the stove is working.any sugestion
try resetting the clock. If it is digital, push the clock button and then the number buttons untill you have the proper time displayed...then push the clock button again. If your clock and timer are manual, try pushing in the clock lever and turning it 1/4 turn. If this works it would indicate that your timer has a start and finish time and that the oven is not working because the clock has rotated around to the finish time.
Sep 09, 2011 | Microwave Ovens
I have about and 8 year old maytag advanced cooking system. how do i use the self clean feature. i know its not just hitting the clean button
you should have a set clean time on your timer..if it allows set for 4 hours..maybe auto...
then close door and lock
Dec 19, 2010 | Maytag Ovens
Resetting the clock
You can set the timer on a single oven slow cooker to automatically switch to a warming setting when you estimate foods will finish cooking.The programmable features allow you to leave food stewing at home while you are out of the house, freeing up your day. Set the timer on a Corningware slow cooker to let the kitchen appliance do all the work, and come home to a fully cooked meal.
INSTRUCTION BELOW.
  • Fill the insert of the single oven slow cooker with food and cover it with the lid. At least a quarter of the insert should be filled with liquid to keep the environment moist during long cooking times.
  • 2 Press the "On/Off" button on the left side of the electronic control panel in the front of the appliance. This will turn on the slow cooker to the low heat "Warm" setting.
  • 3 Press the "Cook Time" button on the right side of the electronic control panel to add hours to the timer which will show a total time in hours with a red digital display. Continue to press the button until the display indicates the desired cook time in one-hour increments up to 10 hours. The cooker will automatically adjust the temperature setting based on the amount of time you programmed on the timer. Cooking times of six hours or less automatically start on "High" heat and times of seven hours or more will start on "Low" heat. A small indicator light will come on below the word to tell you the cooking temperature.
  • Please rate this solution after use.
    Thank you and thanks for using fixya.
    Oct 03, 2010 | Maytag CWG3100A Gas Single Oven
    I have lost my manual for a Simpson Appolo Atlas Stove
    call manufactuerer and ask if you can order one or try to do so online
    Dec 22, 2009 | Stoves EC500DOA Electric Kitchen Range
    Have a GE Electric Cook Top oven with digital
    Unplug the stove. plug back in and program a short clean cycle. If this does not fix it is eithe the selector switch or the electronic control. Verifying the switch contacts with a meter is the only way to be sure.
    Eric
    Jun 21, 2009 | Ovens
    Maytag advanced cooking system/the super capacity plus
    My Maytag , advanced Cooking system , super capacity gas stove has a problem with the oven. It looks like it lights, but most often, doesn't heat up, and I can sometimes smell gas. Anyone know what what cause this?
    Jan 20, 2009 | Maytag Ovens
    Maytag cook top too hot!
    Remove cooktop and check to see how much insulation is below the top, on top of the oven cavity, You may want to install some more insulation. The specs for this range probably allows this to happen. you should not put anything on the top after cooking in the oven, as glass breakage may occur.
    Dec 04, 2008 | Maytag MER5775Q Electric Kitchen Range
    Maytag MER5775Q Electric Kitchen Range Logo
    4,297 people viewed this question
    Top Maytag Kitchen Ranges Experts
    vince
    Sal DeAngelo
    Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
