Question about Sport & Outdoor - Others
Powerwinch 502, on a 28"
otacon
  • 1944 Answers
SOURCE: " please re-operate after pushing reset button".
Could you please provide more details such as Camcorder model and company? Thanks.
Posted on Dec 21, 2007
  • 8 Answers
SOURCE: how do you operate the motor? I have no details as
The pedal has generally four functions:
1) Forward and back on the pedal make the motor go left and right (push forward to turn the motor right, push back to turn it left)
2) Momentary power - the little 'button' towards the top will engage the motor as long as you press down on it.
3) Selector Swith - on the side of the foot pedeal there is a switch with the following settings Con - Off - Mom (Continuous - keeps the motor going all the time, Off - well it's off and Mom - will only go when you press the momentary button).
4) Speed select - the knob on the left controlls how fast the motor goes.
It takes some getting used to but offers tremendous control and hands free operation!
Posted on Sep 07, 2009
  • 107 Answers
SOURCE: we have an older maestro
Call Lutron's tech support at 1-800-523-9466. They're available 24/7 and will probably simply replace it.
Posted on Dec 30, 2010
  • 55 Answers
SOURCE: Snow Bear Winch..... Will not
Hi there, I had the same problem, my winch has a chain to lift the plow.I put oil on the chain to keep from rusting and thats what started my troubles.So I took the mount off that holds the chain on the winch and there's a brass piece that is squeezed behind it.Cleaned and tightened it and works fine now. If you take motor off winch to check gears[ DON'T USE GREASE] when reassembling! When its cold it doesn't want to turn, just use motor oil or spray lube
Posted on Jan 22, 2011
  • 9 Answers
SOURCE: When I try and use the winch all I get is a
It sounds like you have broken a pinion tooth. Remove the screw from the end housings and open to inspect the drive gears. Parts can be purchased from Superwinch for these or off e-Bay.
Posted on Jan 24, 2011
Only have a model number and need to order a Minn Kota electric motor propellor
Minn Kota go by the thrust which is mentioned on the top plate. I got mine off Craigs List as well.
  • Minn Kota Prop Compatibility Chart - TrollingMotors.net https://www.trollingmotors.net/blogs/selection/86967623-minn-kota... Minn Kota Prop Compatibility Chart Minn Kota Prop Charts. ... Minn Kota with a serial number and they can recommend a compatible prop for your older Minn Kota motor. ...
  • Minn Kota Motors www.minnkotamotors.com Prop Selection & Part ... Electric Anchor Winches; Shop All; APPAREL. ... A combination of a Minn Kota motor and foot controlled rudder steering allow you truly ...
  • Trolling Motor Replacement Props - Minn Kota www.minnkotamotors.com/Accessories/Trolling-Motor-Accessories/... Minn Kota builds the world's toughest ... Electric Anchor Winches; Shop All; APPAREL. Mens; Ladies; Youth; Shop All; WHAT MOTOR DO I NEED? LET US HELP YOU ...
  • Minn Kota Replacement Propellers - www.fishntech https://www.fishntech.com/minn_kota_propellers.html ... Minn Kota Electric Trolling Motor Replacement Propellers & Nut Kits, ... Minn Kota Replacement Propellers . ... Minn Kota Electric Trolling Motor Replacement ...
  • Minn Kota props replacement props for Minn Kota www.minn-kota.com/minn-kota/minn-kota-propellor/page/2 Minn Kota Replacement Props for propellor Weedless Wedge 2 Props ... Minn Kota MKP 3 Prop 2061151 ... MinnKota Trolling Motor Power Center $57.58; DeckHand Electric ...
  • MINNKOTA MKP 37 2091170 TROLLING MOTOR PROPELLER ' ... www.ebay.ca/sch/...nkw=MINNKOTA+MKP+37+2091170+TROLLING+MOTOR+P... Find best value and selection for your MINNKOTA MKP 37 2091170 TROLLING MOTOR PROPELLER ... MINNKOTA MKP 37 2091170 TROLLING ... MINN KOTA ...
  • Jun 08, 2016 | Minn Kota Endura 30 Freshwater Transom...
    Horizontal jib sheet power winch
    Can u send the photo of this motor to my mail
    khader_abu@yahoo.com
    Aug 14, 2008 | Powerwinch Boating
    John Deere 2012 648g3 skidder winch will let out, when you try to winch in it will roll slack out of cable, but winch won't lock up and pull hard. How can I fix it?
    if your saying that winch will take in and let out ok but wont hold a load in tension , then your winch directional valve or the winch motor is worn out and is allowing oil to pass right thru it regardless of it not being activated as skidder winches don't have a brake like electric winches do it uses the power of the oil locked into motor to hold a load ( that's also why id never stand under a load suspended by one !!!)
    Nov 15, 2015 | John Deere Garden
    Gearmatic winch 19 on a Cat 518. Winch pulls in powerfully all the time. Lever position does nothing.
    Byron: On site, Captain_Crunch said: "
  • Little band applys big band there is a toggle block at anchor point (rear of houseing) my guess is it is siezed that was our problem."
    Or, Try watching this YouTube video: https://www.youtube.com/watch?v=iZFGmWYmYnA
    May 25, 2015 | Cars & Trucks
    My powerwinch brake won't release
    you have to conscious of the fact that when dealing with water and equipment running in water there will be a distinct possibility of rusted bits. Winches have a brake system to hold the line in place when stopped so at a guess I would say that the release mechanism is rusted and not working properly. Try spraying in some wd-40 or crc tp see it that helps.
    May 15, 2013 | Powerwinch RC30 Trailer Winch
    Wire a winch
    The 1585202 winch is capable of pulling 8500 pounds when provided adequate DC power. With no load (winding up slack the cable) the motor requires 84 amps and winds at 18 feet / second. When fully loaded (8500 pounds), the motor requires in excess of 320 amps and winds at 3.5 feet / second. That's an awfully large amount of current and it will need heavy duty power supply cables to work without overheating or melting insulation. I suspect your 1585200 is the same model with same electrical requirements, but did not include a fairlead, mounting plate, etc..
    Superwinch has wiring kit #2007 for front mount (5 foot cables) and #2008 for trailer mounts (25 foot cables) and can simplify the installation with other accessories as well. They're a U.S. company and can be contacted them directly:
    Superwinch, LLC
    359 Lake Road
    Dayville, CT 06241 US
    Ph: 860-928-7787
    F: 860-928-1143
    www.superwinch.com
    Dec 22, 2011 | Electric Superwinch 12 Volt DC Winch -...
    Unit will not pull up the anchor
    First, put a volt meter across the winch's power terminals to verify that the voltage is not dropping several volts when comanded to run, indicating a bad cable connection somewhere. Anchor winch's pull alot of current from a battery.
    For a test, use car jumper cables from a good battery to the winch to see if it runs better.
    Oct 18, 2009 | Boating
    Anchor winch
    There is a great chance the clutch has frozen due to corrosion.It need to be pulled apart at the clutch.Its not a big job and quiet easy.The plates freeze together and need to be "cracked" apart.I hope this helps
    Sep 23, 2009 | Boating
    Powerwinch windlass not working.
    Of course, first check the voltage at the connections to the windlass. Have someone operate the switch while you measure with a volt meter. If no voltage check breakers, or fuses. Heavy current devices like a windlass will often require fuses near where they connect to battery power.
    A windlass requires a LOT of current to run. Not just voltage. Trace the wires from the battery connection all the way to the windlass. If possible, loosen any connections (ex; a lug with a nut or bolt) and clean with a wire brush then reconnect. Be sure to disconnect the battery while cleaning. Many times wires will corrode past the insulation. Especially if they were not tinned wire to begin with (tinned wire has a silver shine, regular copper has a copper color and typically turns dark or even black when corroded).
    Since a windlass requires a lot of current, often there may be a relay near the windlass that might go bad. Listen to see if this is activating while someone operates the switch.
    Apr 27, 2017 | Powerwinch 36' Class Freefall P77736 775...
    Sport & Outdoor - Others Logo
    175 people viewed this question
    Top Sport & Outdoor - Others Experts
    Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
