Question about Kenwood DDX-512 Car DVD Player
Where is says turn subwoofer off an on is locked and won't let me turn it on
  • 15,935 Answers
The pre-out must be designated as subwoofer FIRST - then you can turn it on/off.
See page 60 of your manual.
MANUAL LINK
Its in SYSTEM SETUP menu. (#12 below)... change it from REAR to SUBWOOFER.
Thanks for using FixYa!!
Posted on Nov 12, 2010
Fuse replacement
The fuse is integrated in hte AC socket. You'll need a small screw driver to pry up the part that talks about the power requirements. Check the online manuals for more details.
Aug 24, 2013 | PSB Alpha Sub Zero Subwoofer
The subwoofer SP-PWM505 won't turn on.
Make sure its not set to Auto. Also check for a fuse in the back. Unplug the amp side and with the sub plugged in touch the RCA. You should hear noise from sub. Try this last. Some may say this is not good for the sub. Im in the business and never have seen it cause a problem
Jun 18, 2013 | JVC SP-PW100 Subwoofer
Subwoofer wont play!!
first clean your board.ok.....same problem......?remove chargin connector
Jun 14, 2013 | Audio Players & Recorders
JBL Flip won't turn on
this doesnt help. how can i get back on?
Jan 11, 2013 | Harman Kardon JBL Flip black
Why won't my powered subwoofer turn on? It's not
Have you check if the plug is good on it?
Dec 03, 2012 | Audio Players & Recorders
8 INCH MTX ROAD THUNDER SUBWOOFER WON'T WORK NO SOUND NO NOTHING
has it ever worked, if so did you ever use it in the cold because in the cold it is possible for the wiring inside the speaker to crack and break
Oct 29, 2012 | Velodyne CT-80 Subwoofer
Dpx-u5120 dosent show subwoofer option in function mode , how to fix it ?
I manage to slove to my DPX-U5120 Subwoofer level adjustment. In STANDBY mode, Press the Main Volume button and turn to Setting, turn until you find the SW Preout, Swith to normal mode, its won't work if u switch to REAR
Go back to CD/USB Mode, Then Press the Main Volume and find Audio Adjustment and now u can find the Subwoofer Level , Sub Phrase and Sub LPF adjustment.. Um Glad i found this and Happy Setting
Mar 22, 2012 | Car Audio & Video
Describe your Venue SUB10 Subwoofer Problem: The subwoofer won't turn on at all. The red light doesn't even come on. Could it be the fuse in the subwoofer? If so, where is the fuse located?
You can remove the screw near the volume knob and the screw near the on/off switch - then slide out the amp remove the black and white wire - then check the fuse - if its blown look for we repair amps - ebay - if its good then it probably still needs work - it should turn red when plugged in and no signal and green when signal is present - which means amp is on.
Sep 11, 2011 | JBL Venue SUB10 Subwoofer
I have a 1998 Chevy Blazer and I need the Delco Audio System Radio Code for it. I had to replace the battery and now my radio won't work.
For Security reasons (to deter car radio thieves) then please email " restoredclassic@aol.com " for details of how to restore your radio from the LOCK situation.
Hope helps.
Jun 07, 2011 | Car Audio & Video
2005 Corolla cd player "ate"
try disconnecting the battery for a few minutes to reset the radio. Sometimes a microprocessor will lock up. You can reset it by disconnecting the battery.
Jun 01, 2011 | Car Audio & Video
Kenwood DDX-512 Car DVD Player Logo
220 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Jeff Turcotte
Jeff Turcotte
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
