The right side of the screen does not show a picture but still works to the touch. Is there a way to get the entire screen to work?
    President:
  • 2,653 Answers
You need to check to make sure the lcd cable is secure by taking apart the lcd casing. Most laptops are all the same, just carefully examine around the lcd for the "hidden" screws and carefully take it apart. If the cable is nice and secure and the video issue doesn't go away then it's safe to say the lcd is on it's way out :(
Replacing them is cheap though! Just match the part number on the back of the lcd to the new one you buy on ebay. Swap it out and you're good to go ;)
Posted on Nov 12, 2010
Why does my TV show discolored vertical bands and can I fix it at home?
The T-con board controls the picture elements on the screen. Usually replacing this board will solve the problem. If you can touch the screen and the lines disappear and later reappear, that says the screen itself is defective. The only fix is to replace the entire screen.
Oct 10, 2015 | Hisense F42K20EGB 42" LED 1080p 60Hz
Touch screen not working
Try this first if it does not work you need a new screen/control panel.
1,. Take a paper clip with machine on and stick it in the tiny hole on the right side of the control panel the screen will change when you see the screen with copiers and computer look under the computer on left side of the screen see a small dot. when it shows press the "3" key go touch panel adjust follow the screen see if that reset the screen if not need a new one.
Feb 07, 2014 | Minolta bizhub 200 Copier
I have a 20F42OT - is there someway to change the screen so the entire picture shows? for example, if there are sports scores on the bottom of the screen, you can see only top half. Screen should be...
does the remote have a aspect button? or maybe it is in the menu? If not let me know and I'll look it up. I have worked on some of these but dont remember them being wide screen
May 03, 2011 | RCA 20F420T 20" TV
Half screen is blank 42lg20 or 42lg50 when
This is likely to be the T-con board. If the entire screen glows but you have no picture on the second half of the screen then it is the main board, not the backlight inverter. If the screen is half picture and half gray it is the T-con board.
Replacement of one of the above will fix the issue.
Please rate if this helped :)
Mar 07, 2011 | LG 42LC2D 42 in. LCD HDTV
My elo toch screen does not work right. when i touch it it is on the correct side from left to right, but it is opposite on the up and down. when i touch the top right side it shows in the bottom right...
The calibration is off. Go to start and then control panel. In control panel you should find an icon for ELO calibration. Click this and start the procedure. The calibration will ask for you to touch several places on the screen in little circles with bulls eyes. After this the screen should be corrrect.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Mar 18, 2010 | Elo CarrollTouch touch-screen Monitor
LG Secret touch screen, can not use left upper, middle & right upper touch screen pad .... cannot add contacts, back space or forward a message .... When the phone is hot - the touch screen does not...
I have the same problem sometimes, when it happen I press the touch media key in the middle right side of the phone, and enter to the pictures aplication and exit touching the screen, this appear to recalibrate the touch pad most of the times.
Jun 06, 2009 | LG Secret ? KF750 Cellular Phone
Blue vertical line at reght side of screen
This is normal. Depending on what you have connected to it the lines could be white, black and white specs, or green. Just mode will show the entire picture event the parts that aren't supposed to be seen. I would not recommend that setting. Full is the best mode if you want to see the entire picture in the correct ratio.
Apr 24, 2009 | Panasonic PT-56WX53 53" Rear Projection...
Cracked Tmobile Wing Screen
My Wing LCD has cracked twice. The problem is in the design, and T-Mobile will need to fess up.
Feb 07, 2008 | T-Mobile Wing™ Smartphone
Touchscreen
I'm not entirely sure what that could mean. Perhaps if you took a picture of it for us?
I had read somewhere and even seen a video of it that there was a certain spot on the touch screen where you could tap it to access the WiFi settings without having to do so in-game. But I don't believe that it was in the right corner. I'm pretty sure it was on the left side in a corner.
I also believe that was a feature of the Japanese versions.
If you have a picture of it, that will tell me a lot more.
Nov 02, 2007 | Nintendo DS Console
Computers & Internet Logo
18 people viewed this question
David Payne
David Payne
