Question about Cobra 29 LTD CB Radio
I just need to know how to use it for conversations and what every turn dial means.
    Guru:
  • 773 Answers
You need to hook this up to an antenna. If you are putting it in a car, you need a mobile antenna, if in a house, you need a base antenna. The antenna needs to be tuned for best SWR or you will damage the radio.
Starting from the left of the radio.
Knob 1. Volume/ squelch. The little knob does the volume of what you hear. Big knob squelches out static noise.
knob 2. Dynamike. This is the volume of your voice transmitted. Its how loud people hear you.
Knob 3. RF gain. This is the receive sensitivity. The higher you turn this, the further you can hear. There is almost no reason for you to have this anywhere but full.
knob 4. Delta Tune. This knob should be in the center. If you encounter some one transmitting off frequency, you can move your receive up and down frequency so you can tune that person in. It does not effect your transmit frequency.
Knob 5. CAL. This is to calibrate the meter for taking an SWR reading off the antenna.
Switches starting form the left.
Switch 1. Meter switch. S/RF - will show on the meter, Your signal going out when transmitting, and the signal coming in while receiving. SWR - will show on the meter, your SWR on that channel after you have calibrated the meter. CAL - This is used to calibrate the meter in conjunction with the CAL knob.
Switch 2. ANL - Automatic noise limiter. - This gets rid of electrical interference noise from the vehicle, or other interference sources. ANL/NB - This is the same as ANL, but with NB "noise blanker" This function blanks louder noises that may make it hard to hear people. It's kind of like an automatic squelch, but not nearly as effective as the actual squelch. Also, NB will lessen your receive in that, really low signals will be blanked out.
Switch 3. CB - the radio is in CB mode. This is the normal operation mode of the radio. You can transmit and receive as normal. PA "Public Address" - If you hook a PA speaker to the PA jack in the back, you can mount the speaker on the out side of the vehicle, and talk over it (Its loud). Also, anything you receive over the radio when not holding the mic key, will come over the PA speaker. This is useful when you are not in the vehicle, and need to hear when some one comes on the radio.
Switch 4. BRT and DIM - this is the brightness of the meter light and channel display. BRT stands for bright.
Switch 5. Normal and CH 9, When the switch is in the normal position, everything is normal, but when you flip it up to CH 9 it instantly puts you one channel 9 with out having to turn the dial. CH 9 is the international emergency channel. So it lets you go to Channel 9 quick. when you put it back to normal it will put you on the channel you were on.
Meter explanation. - You have 3 horizontal lines on the meter. the top line is your SWR (only when in SWR mode on the switch. The next one down is you Signal going out. And the bottom one is your signal coming in, in DB's. ***Also noted that part of the SWR line has a CAL )calibration mark. When you have the switch in CAL, and key the mic, you turn the CAL knob up until the needle is at CAL triangle, and then put the radio on SWR and key it. where the needle falls, on the top line is your SWR. If it is in the red your antenna is not tuned, and you can damage your radio.
HERE IS HOW TO TUNE YOUR ANTENN:
It is important to tune your CB radio antenna to the proper length. The length must exactly match the wavelength of the frequency you transmit on. Or be really really close.
All Cb antenna's have a way to adjust the length of the antenna. If it's a mag mount, the metal whip can be slid in and out of a metal collar. Usually a set screw. If its a fiberglass whip, the way to tune it is on top. It either has a small metal rod with a set screw to adjust the length, or it threads in and out to adjust length.
Either type you have it will need to be adjusted for proper length. Here is how to tune the antenna to lowest SWR.
Some radios have a built in SWR meter. Some do not. If yours doesn't have an SWR meter, then you have to use an external SWR meter. Radio shack carries one, and you can find them cheap on ebay.
If you have a built in SWR meter or external, the procedure is the same:
1. Turn the radio to CH 20.(This is the center of the band.)
2. Switch the meter switch to CAL. (CAL stand for calibrate.
3. Key the radio. (Important. Do not talk while keying the radio.)
4. turn the CAL knob up until the meter hits the CAL mark.
5. Now while still keying the radio flip the meter switch to SWR.
Where the meter falls after that point is you SWR reading. If its above 3, that is real bad. 2 is not gonna kill your radio but its not the greatest. 1.5 and under is a good place to be, but the lower the better.
If your SWR is high, Here is how to find out if your antenna is too long or too short.
1. Turn to CH 1
2. Repeat SWR procedure. You must calibrate every time you do it.
3. Remember the SWR reading.
4. Turn to CH 40.
5. Again repeat SWR procedure.
6. Compare the reading between CH 1 and CH 40.
Now if the SWR is higher on channel 1 then channel 40 your antenna is too short. You must make it longer.
If the SWR is longer on channel 40 then on channel 1, then the antenna is too long, you need to make it shorter.
Make height adjustments about an eight inch at a time, and take reading each time.
once the SWR is significantly lower and the reading on channel 1 and 40 are about the same, you a about matched. At this point turn the radio to the center of the band, channel 20 and take an SWR reading.
You should now have a low SWR reading, 1.5 or under. If you are 1.5 or under, you are good to go.
If you cannot get the SWR to an appropriate level, there may be an antenna problem.
Posted on Nov 25, 2010
I want to replace ford bantam rocam engine with mazda b6 engine. is that possible?
There is a strong relationship between Ford and Mazda with many shared designs.
Almost any engine can be fitted into any car, even some that seem physically too large. Few such conversions require no engineering and some require a great deal of engineering.
Sometimes a conversion needs no engineering and that is lucky...
I don't know how much, if any, engineering your proposed conversion will need and I suspect few people will be able to tell you with much accuracy.
The best advice I can offer is to make a careful study of the donor car and take careful measurements before deciding to go ahead and such a conversion usually is better made with the donor car on site. Whether such a conversion goes ahead really depends on the facilities available to you and your skill level and experience.
There is little point in such a conversion if the finished car is not much improved afterwards and that usually means more performance but it must be realised there is much more to a good conversion than a mere engine change. The clutch and/or transmission must be able to reliably withstand the increased torque, the brakes often must be modified and when the new engine is significantly heavier the suspension too must be modified...
An increase in power means increased cooling (a bigger radiator and fan) and there must be plenty of room for an efficient air intake and the exhaust system will probably need to be custom made. Quite probably the Mazda electronics will need to be used unless they too are to be custom items - and that can produce a whole new load of problems...
Mar 02, 2017 | Ford Cars & Trucks
Lpg conversion
cover dial settings?
Sep 19, 2013 | Maytag Dryers
How do I set my Canon EOS Rebel T3i 18 MP CMOS Digital SLR to auto mode
If you mean the auto exposure mode, turn the mode dial on the top of the camera to the "A+" position, between the "P" and the lightning bolt.
If you mean autofocus, set the switch on the lens to the AF position if the lens has an autofocus switch. On the camera, press the AF button (cursor-right) then turn the command dial to select the desired mode.
If you mean the auto white balance, press the WB button (cursor-up) then turn the command dial to select the desired mode.
In the auto exposure mode the ISO mode is set to auto, and you can't change this.
If you need a manual, you may download a copy here.
Feb 02, 2012 | Canon Cameras
Lost dial tone
is your unit is new?or your battery is new?if not,then it is probably your battery is weak.you cant say that a battery is GOOD if it still accepting a charge when you are going to charge...let me say that even if a power is stored on it ,you still can't say that it is still good.Becoz when a battery is weak,its current or ampere will become lower than the given specification when it was new.Thus,when a current is low,a batery can no longer supply the exact needs of the unit during the time of conversation,and thats the reason why it will shut down in just almost a minute of conversation even you know that it was fully charged .
Oct 27, 2009 | Uniden 5.8GHz Dual Cordless Phone
Fan will not work on high (5)
http://www.physics.sjsu.edu/becker/physics51/images/27_01_Resistors_in_series_and_parallel.JPG
Ok i know this might be a little difficult to understand. BUt If you click on the link above. Find Diagram (a), That picture represents your switch, not complete but in theory. each Resistor means a Different speed. As you turn the Dial it applys current to all the resistor depending on which one it points to. As you can see the (i) represents current and lets say R3 represents "speed 5" Well in theory the less resistors the fast the speed. So the at low speed the dial will be pointing to R1 at medium fan speed the dial will point at R2 and at high Speed "speed 5" the Dial points to R3. Less Resistance More Current More Current more Speed. Now You have No R3...
This basiclly means that the who switch wihich includes Warm and cold and 1,2,3,4,5 and Defrost etc need to be replaced for 5 to work again.
No solution Replace switch
Jul 15, 2009 | 2003 Chevrolet Avalanche
While engaged in a phone conversation dial-up sounds come in
sounds as if you have a tap on your line in which the phone company has half tapped you to another customers line pair. call you local phone company.
May 27, 2009 | Panasonic GigaRange KX-TG5240M Cordless...
How do I make a conference call with the NEC Dterm 80? Thank you.
To establish a 3 way conversation.
  • Pick up handset and dial first number required
  • While on the call, press Transfer (TRF) button
  • Caller will be placed on hold
  • Dial extension number or external number
  • When called answered by third party, press CNF to establish a 3 way conversation.
Note: Any party may exit conference by hanging up
Mar 05, 2009 | NEC Dterm DTP 16D-1 Corded Phone
Electra elite IPK Problem
There are several things that could be causing this and it depends on how many conversations (ports) your voicemail can handle.
1. The voicemail ports could all be busy. Dial vociemail when you know nobody is using it. If you can get in then there is nothing wrong except that your voicemail system is busy and you may need more ports.
2. If you are pressing a button on your phone, then the button may be programmed incorrectly. Using the dial pad, manually dial the vociemail and see if you can get in.
3. As a last resort, you can turn the phone system off for 10 seconds and then turn it back on. Do this with caution however and make sure nobody is using the phones. You also run the risk of defaulting the programming on your phone system. If the voicemail ports have locked up, this will clear the locked ports. If this happens again (busy) hopefully it is under warranty as either the voicemail is going bad or is misprogrammed.
Dec 08, 2008 | NEC Electra Elite DTU 16D-2 Corded Phone
I have a lumix DMC-F27 camera it will no longer zoom. No I not in movie mode.
Do you mean DMC-FZ7?
I own one. Assuming that the camera is working normally, then I know two settings that will cause the zoom to be fixed.
Suggestion No. 1:
If the zoom is fixed at the wide end:
1. Turn the mode dial to "P". Now turn on the camera.
2. Press "MENU SET".
3. Press the up arrow button.
4. Now, a menu item named "CONVERSION" should be highlighted. Press the right arrow button.
5. A sub-menu screen should now pop up, select and set "OFF".
Suggestion No. 2:
If the zoom is fixed at the telephoto end:
1. Follow Suggestion No.1.
Suggestion No. 3:
If none of the above solve the problem, then the lens might have been knocked slightly out of position.
~If the camera has been dropped.
~If the camera has been thumped or banged.
~If while zooming, the lens was obstructed.
The zoom motor also could have died, it costs about $50.00 U.S. at Panasonic.com.
My best advice would be to contact panasonic customer service.
Jul 19, 2008 | Cameras
Recording of conversation
Hold the voice record button while speaking. It will beep every so often to warn the other person recording is in progress. Beep is there because of US laws, but there is no known way to turn it off where those laws do not apply.
May 24, 2008 | Motorola Mobility RAZR V3
Cobra 29 LTD CB Radio Logo
179 people viewed this question
Top Cobra Radio Communications Experts
AnyMHz.com
AnyMHz.com
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
