Question about Konica Minolta Magicolor 2530 DL Laser Printer
My Konica Minolta 2530DL printer has paper jam ,as i tried to remove paper a part of it tornoaway and got stucked in the fuser roller arear. How can i remove the fuser to get the piece of paper out
  • 1,218 Answers
This error message is displayed by the printer when paper is jammed in one or more locations. In such a case, users are recommended to remove the jammed paper from the specified location. The entire paper path must be checked for any pieces of paper. To stop the message, open and close the top most cover of the printer. Lastly, verify the flags and the sensors. If the problem persists, the cause of the error message could be a broken sensor or sensor lever.
Posted on Nov 12, 2010
Remove fuser
These model you replace the fusing unit you don't get small parts for the fuser for these small machines.
Sep 04, 2014 | Konica Minolta magicolor 2530DL
Minolta di350 jam at fuser
IF you can find a fuser. The Di 350 is a legacy Minolta, now Konica Minolta. mite be able to find refurbished unit. If accordion check to make sure the pick fingers are not broken they prevent paper from wrapping around the fuser roller. one mite be broken causing it to hit it.
Dec 10, 2013 | Minolta DiALTA Di350 Laser Printer
Minolta 2530DL. This piece of junk has another
Thank you for your kind reply.
I'm not going by the readout - but by the fact that bits of paper get stuck under one or two of the final feed rocker/rollers,,,, and are a bu@@er to get out.
Kinolta Customer Service - AND MANAGEMENT - are aware of just how badly designed this paper feed system is, but will do nothing about it.
I have had to virtually strip this piece of carp down, just to give me a little more access,,,, even then, its more than a struggle.
Thanks again.
Aug 23, 2013 | Konica Minolta Magicolor 2530 DL Laser...
Printing problem on a Konica Minolta 2530DL. Was printing fine until we printed a set of thick labels. Now the print quality is really poor on the right side of the paper. It is both streaking and...
sounds like a lable has gotten stuck in the fixing unit, you may need a tech to remove it, do not use any sharp tools to remove it ,this could cause damage to your roller,
good luck, tinyman
Jul 19, 2011 | Konica Minolta Magicolor 2530 DL Laser...
Paper will stuck at the heater
HI i think you have a bad upper fuser roller thats why the paper rolled up with it or maybe there are finge clow are not good first of all just remove paper and just clean the upper fuser roller with fuser oil if yours fuser roller and finger clow are not damaged it will work fine enjoy
thanks
May 14, 2010 | Konica Minolta DiALTA Di200 Copier
In Konica Minolta 2430dk, I had a media jam in the fuser. I cleared the visible paper, but there is still some stuck inside the fuser that is impossible to clear (I can't get my fingers to it), so printer...
The only solution is to take the fuser unit out of the printer, then you may be able to manually rotate the rollers to clear the jam. If there are any marks or scratches on the fuser rollers, you will need to replace the fuser unit, or you will get marks on your prints
Jun 21, 2009 | Konica Minolta magicolor 2430 DL Laser...
My Konica Minolta Printer cuts paper
You most likely have a "claw" out of place in the fusing section. These are sharp little spring guided teeth that keep the paper off of the heated roller. If you had a paper jam and pulled the paper out forcefully it can flip these claws out of place, causing it to cut your paper. (or jam more often). To find these claws, follow the heat. They rest on the hottest part of the pressure rollers of the fuser.
Mar 06, 2009 | Konica Minolta magicolor 2300DL Laser...
Paper jam in fuser
Remove the right hand side cover of the printer, (loosen the two screws, one is at the back).... see the small stepper motor at the top right?
Rotate the white gear teeth connected to it, just visible, DOWNWARDS, ANTI CLOCKWISE, using a blunt screwdriver or something, a few teeth at a time, this will eventually rotate the fuser roller and the paper will come out of the bottom of the fuser.
Oct 25, 2008 | Konica Minolta Magicolor 2450 Printer
Minolta 2350 DL laser printer stuck paper in rear user roller
sry, dont understand, where is the paper jam, in the end at the fuser ? or some where else?
Feb 05, 2008 | Konica Minolta magicolor 2430 DL Laser...
Labels jamming
Check the entire paper processing path as it sound like either the roller gear is not engaging properly to push the paper out of the top, or the output paper path is somehow blocked, like from a label or something else stuck at the top, the roller gear is damaged, or other obstruction.
Nov 16, 2007 | Konica Minolta magicolor 2300DL Laser...
Konica Minolta Magicolor 2530 DL Laser Printer Logo
500 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
