Question about Acer AL1916W 19" LCD Monitor
Acer monitor dims outs after 3 seconds when you start it
  • 11,361 Answers
Check the caps, transistors, fuse, etc.
See pictures here: http://s807.photobucket.com/albums/yy352/budm/ACER%20AL1916W%20Abd/
http://s807.photobucket.com/albums/yy352/budm/Acer%20AL1916W/
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed ACER monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://en.wikipedia.org/wiki/Capacitor_plague
Learn about bad caps: Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Posted on Nov 12, 2010
Screen dimmed
The monitor is going bad. The capacitors that drive the screen are getting weak. It is too expensive to fix, you'll need a new monitor.
Dec 08, 2013 | Soyo Computers & Internet
My monitor went dim and goes black after a few seconds. I can just turn off the monitor for a few seconds and then it comes back for a few more mintues but still is dim and goes black again. Also while...
I don't know what OS you have but there is a power management setting you might want to check. Most likely the monitor is set to go quickly into sleep mode at inactivity. Alternately I don't know what monitor you have but it might be a backlight Issue as well
Dec 20, 2017 | Acer X Computers & Internet
Acer LCD monitor goes black after 1 second
More likely to be bad caps (bulging top), look for that first, the caps may be out gassing, see example of failed monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Jan 21, 2010 | Computers & Internet
Acer AL175 TFT monitor is coming on but its very dim
The screen itself is starting to go bad which is why your having to turn up the brightness to 100% just to see something. Replacing the screen would cost more then the whole lcd monitor itself so its best to get a new one.
Dec 10, 2009 | Acer AL1715 17" LCD Monitor
Acer monitor only display for about 3 to 4 second
Sounds like a busted syncing circuit, probably due to a condenser. It takes about that time to heat or overcharge, at which point a safety feature will turn off the display.
You just MIGHT get some more life hours out of the monitor by tuning it to a lower resolution, but it will buy you a month even in the best hypothesis.
I'm afraid the monitor is in for a repair/replacement.
Oct 30, 2009 | Acer AL1716 F Monitor
Acer aspire one second display monitor blue
Look onto your keyboard. There is a key that looks like 2 oval one shaded the other clear. Press FN and that key with the symbol on it. It will turn off your LCD and put it into the other. Then hit it again, both screens will have power, but slightly dim, press it once more to turn it off.
Good Luck
Jun 18, 2009 | Acer Computers & Internet
Blank ACer X221W Monitor
Hi this is the way how to examine what's wrong with your LCD monitors. Power on both CPU and monitor. After it went dim and blank, you have to check if you can see the image on the screen or not by shining a flashlight into the screen, not directly but find the best angle to the screen and take a look very closely. If you can see the icons or any image, there will be a minor problem. Like me, I can see window image using flashlight and check lamps inside. Some of them were broken and it is easily replaced. If you cannot see anything on the screen, there'll be some problems with inverter board. If you have soldering tool and want to fix it by yourself, check the caps first. It may cause this problem. Some caps might show leaking or burn spot on the board because of too high temp. If you don't have soldering tool, you better go get a technician to do so.
Mar 05, 2008 | Acer X221WSD Monitor
Monitor comes on, but then dims (still visible)
It's usually happening with powersupply complaint.. Contact u'r area LG service provider for service.
Mar 03, 2008 | LG Flatron L1510S 15" LCD Monitor
Monitor dims for one account, not the other
I would first contact the GF administrator and ask them if they've heard of this before. Then I would contact Acer.
Jan 18, 2007 | Acer AL1916B 19" LCD Monitor
Acer AL1916W 19" LCD Monitor Logo
80 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
