Question about Belkin (F5D7230-4) Router (587009)
When i try to console into my router i get a "page cannot be reached" error yes i am using the correct IP
  • Belkin Master
  • 4,338 Answers
Have you reset the router? Then restart your PC....
Reset the router to factory default
Resolution With the router powered on, use a small thin object to press and hold the reset button for exactly seven seconds. The router lights will flash and this will restore the router to factory default. Connect your computer to one of the routers lan ports with an etherent cable. Open your web browser and navigate to 192.168.2.1. This should show the router status page with the default settings.
Posted on Nov 12, 2010
What is error code 52032
Error Code: 52032
Unable to connect to your wireless network
Likely cause: It appears that the security settings entered into the Wii console are not the same as what your wireless router is set to allow, or your router is not able to assign the Wii an IP address.
How to fix: Make sure the security key and security type are entered into the Wii exactly as they appear in your router's settings; manually assign an IP address to the Wii.
  1. Don't know how to find your router's security key?
    Let us help! Select the brand of your router below and we'll show you how to access your router's settings. Linksys Netgear DLink Belkin Apple 2Wire All other brands
      Once you have entered the correct WEP or WPA key into your system, try the connection test again. If the problem persists, keep reading this page.
    Additional information:
    • Using an Actiontec or 2Wire router? The default security key is often found on a sticker located on the router.
    • Security keys are case-sensitive.
    • WEP keys contain numbers 0 through 9, and only letters A through F.
  2. Manually assign an IP address to your Wii console.
      Assigning an IP address to your Wii is easy!
    1. Access the Wii System settings and select "Internet" from Page 2.
    2. Select "Connection Settings" and choose the connection file you currently use (will have a red border around it).
    3. Select "Change Settings," and click the right blue arrow twice to reach "Auto-Obtain IP Address."
    4. Click on "No" and select "Advanced Settings."
    5. Now, click in the "IP Address" field to enter an IP address. Look at the brand of your router, and enter the IP address listed below into the field.
      • Linksys - enter: 192.168.001.140
      • Netgear - enter: 192.168.001.250
      • Belkin - enter: 192.168.002.090
      • D-Link - enter: 192.168.000.190
      • Apple - enter: 010.000.001.250
      • 2Wire - enter: 192.168.001.250
      • Actiontec - enter: 192.168.001.250
      • SMC Networks - enter: 192.168.002.190
      • Don't see your router brand listed? Click here for help with finding an IP address to enter.
    6. Once the IP address is entered, select "OK."
    7. Select the Subnet Mask box, then enter 255.255.255.0 and select "OK."
    8. Select the Default Router box. You will need to enter the defail gateway address for your router brand. Look at the brand of your router, and enter the gateway address listed below into the field.
      • Linksys - enter: 192.168.001.001
      • Netgear - enter: 192.168.001.001
      • Belkin - enter: 192.168.002.001
      • D-Link - enter: 192.168.000.001
      • Apple - enter: 010.000.001.253
      • 2Wire - enter: 192.168.001.254
      • Actiontec - enter: 192.168.001.001
      • SMC Networks - enter: 192.168.002.001
    9. Select "Confirm" but DO NOT select "Save."
    10. Tap the right arrow to reach the page ro "Auto Obtain DNS."
    11. Select "No" and then "Advanced Settings."
    12. Click into the "Primary DNS" field and enter: 008.008.008.008
    13. Click into the "Secondary DNS" field and enter: 008.008.004.004 Please note: These are public DNS's provided by Google and are subject to Google's Terms of Service. If you prefer to not use this service, doing an Internet search for "public DNS" will provide you with several other options you can use.
    14. Select "Confirm," and then "Save."
    15. Click on "Save" and then "OK" to perform a connection test.
    16. If the test was successful, then your Wii is now connected online. If you received error code 52130, please call 1-800-255-3700 so that we may assist you further.
  3. Other suggestions:
    • Did this connection used to work but has suddently stopped? "Power cycle" your router by unplugging it from the power outlet. Wait a few minutes, and plug the router back in. Wait a couple of minutes for it to initialize, and try to connect the Wii console online and test for proper response.
    • The Wii may have detected and set itself to the wrong security type during the initial connection set up. Try creating a new connection file and going through the connection process again (steps), but be sure that when the Wii asks for a security code, the type shown on screen (WEP or WPA) is what your router is set to. If it is different, try a "Manual Setup."
    • Check for wireless interference, which can affect the signal strength to the Wii console. To help minimize wireless interference, try the following:
      • Make sure other wireless devices such as cordless phones or wireless speakers are turned off, and that the Wii console is an open area without objects or electronics blocking the signal. (For instance, if the Wii is placed in a crowded entertainment center, try moving the Wii somewhere with more room.)
      • Change your router's channel setting to 1 or 11. By default, most routers broadcast on channel 6, which overlaps with other channels and may be weaker. For help doing this, click here and select your router brand and model (if available). The information you need is found in the "Broadcast Channel:" area.
Oct 01, 2011 | Nintendo Wii Console
I can't connect to netflix. Error code 52031 Rita
Error Code: 52031 Was this information helpful? Unable to connect to your wireless network
  1. Don't know how to find your router's security key? Let us help! Select the brand of your router below and we'll show you how to access your router's settings. Linksys Netgear DLink Belkin Apple 2Wire All other brands
    Still stuck? We can help! We have an easy-to-follow guide that will walk you through the process of finding creating a new connection file and starting from scratch. Even if you're sure you've entered the correct security key, we suggest following our guide to create a new connection file and start over. If at the end you still need help, you'll find contact information to reach our specially-trained representatives.
Sep 20, 2011 | Nintendo Wii Console
Error 52030. Unable rto connect to internet
Hi
Jul 29, 2011 | Computers & Internet
Trying to hock up the wii get error 52232
http://www.nintendo.com/consumer/systems/wii/en_na/errors/index.jsp
Copy and paste this link or Click Here for it
This particular code has a lengthy troubleshooting process. Besides my personal input, I think the above website will assist you in the step-by-step process to correct this error. If you need assistance going through this or needs clarification, don't hesitate to ask. I'll be happy to help you through this.
Thank you I hope this information helps you,
Regards,
Nico
Jul 06, 2011 | Nintendo Wii Console
Error code 52230 - when trying to connect to Netflix. Unable to connect to the server for the last 2 days.
Likely cause: Your router or Internet Service Provider is having difficulty assigning a DNS or IP address to the Wii.
How to fix: Manually assign an IP address and DNS to the Wii.
  1. Manually assign an IP address to your Wii console.
  2. Other suggestions:
May 05, 2011 | Nintendo Wii Console
Belkin (F5D7230-4) Router (587009) Logo
19 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
