Question about Dryers
Not sure if I hooked up the wires correctly after installing a new element
  • b0001744 Nov 12, 2010
    The wires I am refering to are the ones that connect to the element and the thermostat that is connected to the element frame. All wires are either red or red with a white strip on it.
  • Dryers Master
  • 8,404 Answers
You wrote a general question ... here is a general answer. Dryers are generally 220 VAC, if you are North America. As such, you should have a black wire on one end and a red wire on the other end (of the element)(those wires may not have any particular color ... the principle applies). At the connection box where the cord enters ... You should have a black wire, a red wire, and neutral (white) which will make 115 VAC to run the light and timer and there should be a frame ground (green). There is a possibility that you don't have a frame ground in which case you would only have a neutral wire.
Thanks for your quesiton at FixYa.com
Posted on Nov 12, 2010
  • A Miller Nov 12, 2010
    If the machine is an electric dryer and you are in North America (please do not confirm your location for security purposes) and it is 220 volts ... and this is a replacement element ... the red goes on one end and the red with a white trace goes on the other. If you are still unsure ...and you have a volt meter, you can disconnect one or both of the wires, plug in the machine and read the voltage across the pair (i.e. the red and the red with the white trace) It should be in the vicinity of 220 Volts AC. Remember, the thermostat is simply a switching device that turns the power on and off.
    If you are in another country with different voltages ... disregard.
    Thanks for the
    Thank you for your interest in FixYa.com
Hi,our Idesit IWB5113 has stopped heating the water,element,or something more tech?
replacing the heating element should take care of the problem. Make sure you unplug the unit before installing the new one. Also you may want to take a photo of the wiring so you will know where they hook to.
Nov 01, 2016 | Dishwashers
Tip
How to replace the Thermostat and Element for Electric Hot Water Heater
If you are having a problem with your electric hot water heater then you may also wonder if you can replace the failed part. The short answer to this is yes! The replacement is easy enough that most any handy person can easily perform this task.
First off make sure that you remove all power to your electric hot water heater. Then remove the access covers that cover the thermostats and the heating elements. After performing the required diagnostic tests to find the fail part you can then concentrate on the part removal and replacement. Check the tips at the bottom of this one to see how to trouble shoot your hot water heater.
To replace the heating element you may have one of two styles of element. One style has a four bolt flange that holds the element in and the other has threads that hold it in.
Before removing an element make sure that you shut off the water and drain the tank to a level below that of the element that you need to replace. This will keep you from making a mess and possibly hurting your self with the hot water.
For the four bolt flange type element, you simply remove the two wires from the element and then turn out the bolts from the flange. Once the flange is off the element will just pull back and out of the hole.
Replace with a new element and gasket. Make sure that the new gasket gets seated in the hole to seal the element when you tighten down the bolts on the flange again. The bolts do not need to be super tight. Just snug them up good and then fill the hot water heater with water to check for leaks and then tighten more if necessary.
For the screw in elements, a removal tool is a good idea.
A large socket looks like it would work, but because of the thinness of the hex part of the element and the bevel on most large sockets, it is very difficult to get them to grip the element securely. Most hardware stores or home centers sell a very inexpensive removal tool that works very effectively. It is well worth the effort to get the proper tool to do the job. To remove the screw in element you need to turn the element to the left or counter clockwise. Then make sure that you do not cross thread the new element as you turn in clockwise or to the right and tighten it in. Once again, make sure the gasket is seated correctly and do not over tighten. Re-hook the wires after leak checking the tank and replace the cover before energizing the electric hot water heater.
To replace either the top or bottom thermostat, you also need to de-energize the hot water heater and remove the cover. When removing a thermostat it is a very good idea to mark the wires and the position where they were on the old thermostat. This makes the re-installation of the new thermostat easier. The old thermostat is held tightly too the tank so that it gets a good reading on the tank temperature. Be careful not to bend the bracket that holds the thermostat when you remove the old one. If you do not have the new thermostat making good contact with the tank it will not operate correctly and give you too hot of water. After switching the old thermostat with the new one, replace all of the wires to their correct position, replace the plastic, and the cover before energizing the hot water heater. Both the top and bottom thermostats are similar in their replacement, but the top thermostat also incorporates a safety reset control and switches power to the bottom element when the top of the tank is hot enough, so there a re a few more wires to that thermostat. This also keeps the two thermostats from being interchangeable. You cannot install a bottom thermostat or the top or a top one on the bottom.
This whole process is not as complicated as it may seem and you can do it!
http://www.fixya.com/support/r4654730-electric_water_heater_not_working
http://www.fixya.com/support/r4422595-electric_water_heater_wiring_diagram
http://www.fixya.com/support/r4656190-electric_hot_water_heater_temperature
http://www.fixya.com/support/r4041115-clean_hot_water_heater
http://www.fixya.com/support/r3689051-home_water_heaters_hot_water_heater
on Apr 29, 2010 | Water Heaters
Tip
Surface Burner Replacement on Electric Smooth Top Range
Steps necessary to replace one of the surface elements on a smooth top electric range.
Before you begin:
1. UNPLUG the range before servicing.
2. There are a few screws located under the front edge of the cook top. You will need to open the oven door to see them. Remove these screws and the top should lift up.
On some ranges, there is a disconnect plug for the surface element wiring harness. If you have this feature, Follow these steps:
a. Unplug the cook top and leave the elements in place.
b. Place the whole cook top assembly face-down on a soft surface (like some old towels, or a blanket).
c. Remove the bad surface element by removing only the bracket pair that the affected element is attached to. Leave the rest of the elements wired together. Write down the wire color codes so you can be sure the new element is installed correctly. HINT: A digital camera can save you some time.
d. When installing the new surface element, make sure you use the same alignment marks (the numbered positions around the perimeter) as the old element. Avoid touching the burner surface and handle with care. Try to handle from the underside of the element only.
If the wiring harness does NOT unplug, prop the cook top in place and install the surface element from underneath. A helpful hint: Use some duct tape to hold the assembly until you have screwed it back into place. Don't forget to remove the duct tape when completed.
on Apr 05, 2010 | Kitchen Ranges
Same sears 66 gallon water heater keeps resetting button after replacing both upper and lower theremostats and elements
1) Live answer Jan 2013.
Read why ECO trips and scroll down and read ECO keeps tripping:
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html#ECO
Check that thermostats are sitting flat against tank.
Look and smell for signs of burning.
Check watt rating printed on end of new element matches watt rating that shows on label on side of tank
Make sure factory-installed installed insulation is put back over thermostat and element to avoid cool room temps from affecting thermostat.
Test wires.
http://waterheatertimer.org/How-to-test-water-heater-wires.html
Make sure tank is wired correctly.
http://waterheatertimer.org/images/WH-w-combined2-1000.jpg
2) Add comment and say what you discover
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Jan 02, 2013 | Water Heaters
Dryer will not heat after new element installed
You will need to re check your wiring. If you have a voltmeter make sure that the proper voltage is coming through the wires. If not then trace back to where you have voltage and you will find the part that is not working. You can hook direct to the element and make sure that you just didn't get a bad one.
Oct 06, 2012 | Kenmore 63942 Dryer
I have a new paddle light switch im trying to install and for some reason it keeps poping the breaker. im wondering if im installing it correctly
make sure you are hooking up the correct color wires to it main wire on top of switch, bottom wire of switch other color wire they should be blackor any other color , just dont hook up the white wire to it this will make your breaker pop , If your copper is touching any metal this will make it pop also,good luck
Jul 29, 2011 | Cooper Industries Cooper Wiring: Single...
Water heater keeps popin the breaker replaces breaker still no good. new heater just installed all wires are good
I assume this is a 240 volt water heater that runs on a 30 amp circuit. Read the instructions that came with the new water heater to be sure. If the wires are connected correctly then you have a defective water heater. Let's first make sure it is wired correctly. Turn the breaker off and take a look at it. It must be a 30 Amp breaker and the wires going to the water heater must be 10/2 with ground. This is an orange wire. If you cannot see the water heater from the service panel it must be wired to a disconnect box. Look at the breaker and make sure the red & black wires are tightly connected to the double pole breaker and the copper wire is connected to the ground bar. At the disconnect box (if applicable) the red/black wires from the service panel must be connect to LINE and ground to ground bar. The wire going to the water heater from the disconnect box is connected to LOAD. It is easy to get these mixed up because they are not always in the same location and are hard to read on some disconnect boxes. Look carefully and make sure they are correct. At the water heater you connect Black to Black and Red to Red. Make sure the ground is connected tightly and none of the wires are touching each other. Use wire nuts and then tape the connections with electrical tape. You should not have applied power to the water heater until it was full of water. If you did then your burnt out the electrodes. I would suspect you have a short somewhere or the water heater is defective.
Dec 10, 2009 | Cars & Trucks
Rheem 92 gal. no hot water. breaker not tripping. lower thormostat reading no ohms. the upper thermostat is reading about 6 ohms. however when i turn power on the upper thermostat reads no voltage? Do i...
Have you checked to make sure that the elements are good by checking the ohms. Be sure that the power is off and the wires are disconnected from elements and then also be sure to check the ohms across the tank to make sure there is not a dead short in the element reading through the tank. If both elements are good then I suggest replacing both thermos then they will both be new and should work for you . Thermos can be problematic when trying to test them sometimes they won't always give you correct readings. Make sure you have the breaker off whenever you mess with a waterheater, and make sure you install the thermos correctly with the right wires going where they should.
Apr 19, 2009 | Rheem 80 GAL ELEC TALL Water Heater 6YR SC...
I have an electric whirlpool dryer and had to buy a new heating element the problem is that I don't have a clue what wires go where. I have 2 red wires and an orange one but I'm not sure which ones hook to...
small orange goes to small terminal on hi limit thermostat you'll find only one of the red wires will fit the terminal on element it is slightly bigger than terminal on hi limit
Jun 05, 2008 | Whirlpool Dryers
Dryers Logo
Top Dryers Experts
