Question about Kenmore 75172 / 75174 / 75179 Dual Fuel (Electric and Gas) Kitchen Range
The oven locked after a power failure. How do you unlock"
  • 2,382 Answers
Hi, did the oven door locked at power up? Press Cancel/Off key to start a latch reset, wait 20-30 seconds and open door. Is the oven door locked due to power failure during Self-Clean? Turn Breaker/Fuse Off and then turn Breaker/Fuse On, wait 20-30 seconds and open the door. Do you see an Error Message on "open temperature sensor?" The temperature sensor has malfunctioned and requires service by an authorized service provider.
Posted on Nov 12, 2010
How to unlock oven Door frigidaire?
Usually the door locks during a self cleaning cycle for safety reasons. If the self cleaning cycle did not finish properly (over temp sensor trip, etc.) it could end up with the lock deployed or it could be that the locking mechanism failed in the lock position (unlikely!). Turn off the power to the oven by finding the correct circuit breaker in your electrical distribution box. Keep it off for some 30 seconds. If the oven is ok it will reset and unlock the door. If it has a failure in the locking mechanism you should be able to access that part from the top or you may have to call a repair person. Hope this helps!
Jan 20, 2016 | Ovens
Power Failure while oven was in self cleaning mode. When power was restored the control panel is completely dark, no error codes or PF indicator. The oven door is also locked after 24 hours, so the the...
Hello. You have an open rear oven thermostat causing the complete power failure of your unit. The part numbers you need are W10176670 for the upgraded blower and 9759243 for the thermostat. You will have to remove the oven from the wall in order to remove the back covers to access the thermostat and blower. The blower has been upgraded from 950cfm of airflow to 1200cfm. I have performed this service flash--you will definitely need a helper or 2 in order to pull the oven out and work on it. There is a service bulletin on your oven describing this exact situation. When you replace the thermostat and blower, re-mount the oven and then restore power, the oven will function and unlock. The link for the thermostat is here:
Thermal Overload Safety Thermostat
The link for the blower is here:
http://www.appliancepartspros.com/whirlpool-blower-w10176670-ap4369539.html
If you are hesitant about performing the repair yourself, definitely call for service. I hope this helps you!
Nov 06, 2015 | Whirlpool RBS305PRS Stainless Steel Oven
Oven door will not open
The lock motor (latch) has gone bad. Unfortunately, the part has been discontinued and is no longer available for this model.
Apr 24, 2012 | Amana AOCS3040 Electric Single Oven
How to " unlock" the
your oven is on self cleaning mode, and it locks it
Jan 10, 2011 | Whirlpool Ovens
Somehow I have "locked my microwave - when I try
Easiest thing to do is to unplug it or turn off power at breaker for a couple of minutes, should reset.
Nov 14, 2010 | Sharp Microwave Ovens
What does the sign "control lock" mean?
Here is what the manual for your oven says about control lock.
Let me know if you have questions.
Control Lock
The Control Lock shuts down the control panel pads to prevent
unintended use of the oven(s). The Control Lock will remain set
after a power failure, if set before the power failure. The only time
it is not available is during the Sabbath Mode or Self-Clean cycle.
When the control is locked, only the TIMER SET · START, TIMER
CANCEL, OVEN LIGHT and CANCEL OFF, UPPER OVEN
CANCEL / OFF or LOWER OVEN CANCEL / OFF pads will
function. On double oven models, CLOCK SET · START will also
function.
The Control Lock is preset unlocked, but can be locked.
To Lock/Unlock Control: Press and hold CONTROL LOCK for
about 3 seconds, until “CONTROL LOCK” and a picture of a lock
appear on the display. Repeat to unlock and remove “CONTROL
LOCK” from the display.
May 13, 2010 | KitchenAid SGL OVEN T/C
Oven door locked and will not unlock
hi friend,
step 1
Look for a manual lever to unlock the oven. If there is one, it will probably swing back and forth horizontally, just below the upper edge of the oven door.
  • Step 2 Swing the locking lever, if one is present, all the way to the left. This should unlock the oven. If there is no manual lever to unlock the oven, it may be unlocked using push-button controls.
  • Step 3 Check to see if the oven is in a self-cleaning cycle, or has just completed a self-cleaning cycle. If so, the door will unlock automatically once the oven has finished the cleaning cycle and cooled completely, which may take several hours. You cannot unlock the oven before it has cooled.
  • Step 4 Unlock the "Clean/Off" button. Depending on the brand and model of your oven, the button may display both of these designations or just one. If your oven door is locked, but the oven is not warm and is not in a cleaning cycle, unlock it by pressing and holding the "Clean/Off" button.
  • jQuery('.article ol .image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); }); Who Can Help Sponsored hope this helps u
    please rate me.................
    thank u for using fixya
    regards
    sivaranjini
    Nov 25, 2009 | Tappan TEF242 Electric Kitchen Range
    Frigidaire oven f9 code
    Here's the info from the service manual:
    "Fault Code: F9
    Likely Failure Condition/Cause:
    1. Door motor failure / jammed. Latch
    motor switch failure.
    2. Control software failure, or component
    failure (relay stuck).
    3. Wiring Problem.
    Suggested Corrective Action:
    1. Press CLEAR key.
    2. If CLEAR key does not eliminate problem, turn off power for
    30 seconds, then turn on power.
    3. Check wiring of Lock Motor, and Lock Switch A and Door
    Switch circuits.
    4. Unplug P4, apply power (L1) directly to the Lock Motor, if the
    motor does not rotate, replace Lock Motor Assembly. Plug
    P4.
    5. Check Lock Switch A for proper operation (do they open and
    close, check with ohmmeter). The Lock Motor may be
    powered as in above step to open and close Lock Switch. If
    the Lock Switch is defective, replace Motor Lock Assembly.
    6. If all above steps fail to correct situation, replace control."
    - www.fixyourboard.com
    Jul 25, 2009 | Frigidaire FEB30S5D Electric Single Oven
    Door locked after power surge/failure
    The question here is how long did you leave the breaker off? Gaggenau ovens have a memory and I always advise turn the oven off for 5 mins before turning the breaker back on. Give that a try. The first thing the oven does when the power is reapplied is go thru a test phase which included locking and unlocking the door. The key symbol will go on and off during this. Sometimes you have to also can run a self clean then cancel it to reset the lock. This works as well.
    Jan 06, 2008 | Gaggenau EB270 Electric Single Oven
    Kenmore 75172 / 75174 / 75179 Dual Fuel (Electric and Gas) Kitchen Range Logo
    108 people viewed this question
    Top Kenmore Kitchen Ranges Experts
    Dan Webster
    Dan Webster
    Mike Carew
    Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
