Question about Linksys Wireless-G WRT54GS Router (e125894)
How do i set my NAT to open on my WRT54GS? what is the default password to access it?
  • Linksys Master
  • 4,338 Answers
Do this,
Open an Internet Explorer browser page on your wired computer(desktop).In the address bar type - 192.168.1.1 and press Enter...
Leave Username blank & in Password use admin in lower case...
Click on "Applications and Gaming" tab and then click on "Port Range Forwarding" subtab...
1) On the first line in Application box type in ABC, in the start box type in 53 and End box type in 53, leave the protocol as both and under ip address type in 192.168.1.20 and check the enable box...
2) On the second line in Application box type in PQR, in the start box type in 88 and End box type in 88, leave the protocol as both and under ip address type in 192.168.1.20 and check the enable box...
3) On the third line in Application box type in XYZ, in the start box type in 3074 and End box type in 3074, leave the protocol as both and under ip address type in 192.168.1.20 and check the enable box and click on Save Settings...
4) Once you return to the set up page click on the Security tab and uncheck Block Anonymous Internet Requests and click on Save Settings...
5) Click on set-up and change the MTU Size to 1452 and click Save Settings...
6) Goto the XBox Network Settings and IP Address Settings and select manual IP Settings and assign the following on your Xbox
IP Address :- 192.168.1.20, Subnet Mask :- 255.255.255.0, Default Gateway :- 192.168.1.1...
7) Also assign the DNS Addresses on the Xbox
Primary dns :- 4.2.2.2...Secondary dns :- 192.168.1.1
8) Turn off your modem, router, and Xbox...Wait for a minute...
9) Plug the modem power first, wait for another minute and plug the router power cable, wait another minute and turn on the Xbox and test it...it will connect...
Posted on Nov 12, 2010
Testimonial: "thanks a lot for the help. it was very helpful"
How do i change my nat to open
1 Make sure your ZyXEL Device hardware is properly connected (refer to the Quick StartGuide).
2 Prepare your computer/computer network to connect to the ZyXEL Device (refer to theQuick Start Guide).
3 Launch your web browser.
4 Type "192.168.1.1" as the URL.
5 A window displays
6 For administrator access enter the default admin password 1234 to configure the wizardsand the advanced features.(or if you already changed your password, enter that password)
7 On the right hand side of the screen you will see a drop down menu. click onNETWORK.
8 Then click on NAT.
You should be able to adjust your NAT settings from this page.
Sep 25, 2011 | Zyxel P660HW-D1 Router
How to change NAT status to open?
5 A window displays
7 On the right hand side of the screen you will see a drop down menu. click on NETWORK.
Sep 04, 2011 | Zyxel P660HW-D1 Router
NAT IS STRICT
STEPS TO CHANGE NAT SETTINGS TO "OPEN":
1- Using your Browser, Log on to your router (by normally typing in the 192.168.1.1 address check your router's manual to see what the default gateway address)
2- If you already know how to log in to your router, then skip this step. If you have never logged on to your router then more than likely you still have the default initial log in credentials (username: admin - Password:1234 ..... Again check your router's manual to be sure). The minute you log in you need to change that password immediately, most network-savvy folks know that 90% of the people out there never reset their router's initial password and they can log on and make any changes to suit their needs, including locking you out of your own router.
3- Once you are logged in, you should be able to find two advance settings (One if for NAT - and the other is for Upnp)
4- Let's start with the NAT setting changes, and we will move on the Upnp at the end. I have personally tried the NAT setting changes and it didn't fix anything, I still had a "Strict" NAT setting on my xbox360, Only when I checked for the Upnp "allow authorized incoming traffic" options when the NAT settings on my XBOX finally came back as "Open" and not "Strict". But I will still explain what I did anyways with the NAT table cause I know it may work for some other routers.
5- So what I did with the NAT setting is this. I located the NAT advanced setting on my router, I click on the NAT (Edit List setting) or whichever link/button you have on your router advanced NAT settings to access the table needed to open certain ports (TCP and UDP - 88 & 3074) .
6- You will need to find out what the static/dynamic (preferably Static) IP address you xbox360 has. To do so, go to the Dashboard, go to the Console settings page, and click on the network settings to see the IP address (should be something like 192.168.1.x). You will need that IP address to enter into your NAT table on your router.
7- Once you got your XBOX's IP address enter it in the NAT Port Forwarding table (From - To - IP address: those are the 3 fields you should have on the table if you are using SUA NAT)
8 - In the first line enter 88 under both "From" and To" fields, then enter the IP address of the xbox in the field where you are to enter an IP address. (this is for UDP port)
9 - Repeat the same step for port TCP (which is 3074)
10- If these changes do not help open your NAT settings, then try the Upnp option. Click on your Upnp Advances settings and click on the "Allow Traffic" option, this is mostly secure because you are only accepting the incoming traffic that matches your outgoing traffic.
Mar 02, 2011 | Belkin Basic Wireless Router
I need to change the nat type to open and and not strict
Fot your to change thesettings of the NAT of your router you need yo access the router page by opening a browser and type 192.168.2.1 on the address bar. It will ask you for a username and password. The default username is admin and the password is 1234. The click on the NAT settings on the left part of the page.
Thanks for using Fixya.
Jan 27, 2011 | Edimax BR-6226n nLite Wireless Broadband...
Password
Are you trying to access the router set up.
There is not default user name for the router. Keep it blank. the default password will be " admin ". If that doesn't work the router password must be changed. Try some of your passwords and see if that opens the set up page. If nothing is woirking then you will need to reset the router and set up the router again.
Click here for more information about routers
Jul 13, 2009 | Computers & Internet
Dont know how to set nat type to open
For you to be able to open the NAT on the router you have to open or forward the application port on it. This router has a graphical interface where you can configure port forwarding, access http://192.168.1.1 (default) username blank and password is admin. Now look for port forwarding and open the port for your application.
Jun 29, 2009 | Linksys Wireless-N WRT150N Router
I need to change my nat settings
Type into the address bar www.whatismyip.com copy and paste your ip address into the address bar, a username and password will be required to access the page, most default usernames and passwords will be admin and password, for sky users the password may be sky, if these don't work then dont worry there are websites that have a list of all routers default usernames and passwords. once on the router setup go to security setup, and go to where it says WEP, click disable WEP and accept changes. if it is for gaming make sure that the UPnP is clicked on. and there you go, bare in mind that your pc may stuggle to connact to the router at this point because of the change, so just change the settings on your computer to suite the routers settings and there you are an open NAT and internet that still works. hope this works for you!
Apr 10, 2009 | D-Link DI 514 Wireless Router (DI-514)
1 linksys wrt54gs router 2 xbox 360's and a not open nat setting
connect the 360 to a port in the router and have the internet going straight into ur router ull stay connected at all times as soon as u turn on the xbox itll log on automaticly
Feb 21, 2009 | Linksys Wireless-G WRT54GS Router...
Trying to turn a Linksys WRT54GS into a hub
  1. If you want to set the router to work only as a switch with wireless access point, you may need to get into its setup page and adjust some settings.
  2. Using a computer that is wired directly to one of the router's Ethernet ports, launch IE and type 192.168.1.1. It is the default IP address of the router. Then it will open a window, asking for a username and password. By default, there is no username and the password is admin.
  3. Once you're in the router's User Interface, look for a sub tab called "Advanced Routing" under the main tab SETUP. Then set router mode to "Router" instead of Gateway. In some router's, the choice there is NAT enable or disable. If it is the one showing there instead of Router mode, then set NAT to disable. Click Save settings which is located at the bottom portion of the screen.
  4. Then click on "Basic Setup" and then disable DHCP server. Save the settings then.
  5. Then your modem now will be connected to one of the 4 Ethernet ports of the router.
Hope this helps!
Nov 21, 2008 | Linksys Wireless-G WRT54GS Router...
Linksys Wireless-G WRT54GS Router (e125894) Logo
227 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
