Question about Whirlpool Dryers
My dryer is making a clicking noise when I turn it on for about 5-10 seconds and then it shuts off. sometimes it turns itself back on.
  • Whirlpool Master
  • 8,404 Answers
I suspect the start capacitor on your motor has failed.
Remove the back of the machine and inspect the motor to find the start capacitor. Contact your local appliance parts place to see if they have or can order a replacement part for you.
Thanks for using FixYa.com
Posted on Nov 12, 2010
Fridigdere up rite stackable dryer keeps beeping and shuts off after running for about 5,10 seconds,what do I check,?????
Google the model and codes. You should find instructions in how to to retrieve the codes and that will point you in the right direction.
Oct 14, 2016 | Dryers
Samsung HLS5086WX/XAA made popping noise and shut off, then made whirring noise.
When my TV did this in the past it ended up being the color wheel. I had someone replace it and it worked fine. I asked it if had to be calibrated after it is installed and he said no. Also make sure the door switch is pushed down when you install the back bulb door. Sometimes this switch can go bad as well.
Jan 10, 2013 | Samsung HLS5086WX/XAA
Why does my dryer keep turning itself off before end of cycle?
If the dryer makes a motor growling noise at start up and shut off a short time later then it is probably a bad motor bushing and that will nessesitate a motor replacement. Bruce
Sep 27, 2012 | Dryers
My rca d52w19 makes a noise when turned on.no picturet henshutsof
what kind of noise? is it like an electrical buzzing?
a rapid clicking?
Apr 29, 2010 | RCA D52W19 52" Rear Projection Television
My tv turns off by itself and makes a clicking noise
Most likely it has some bad capacitors in the power supply. Flat--panel sets are VERY hard on capacitors, due to the fact that the "rising heat' from the set "cooks" the caps and they fail VERY early.
Oct 12, 2009 | Samsung HP-T4234 TV
Dryer doesn't want to run- makes grinding noise
its sounds like a worn bearing problem.with the m/c switch off ,turn drum by hand and see if it is hard to do so.if you get a gritty feeling in your hands or hear a grinding noise,then that is probably the bearing.
Jul 23, 2009 | Dryers
90 series dryer wont start
first check and see did any clohes fall down in the blower wheel,,from fillter no...check the belt that its not jammed,,check your idler wheel ...always unp[lug unit first.....now we will check motor ,turn unit on if you get a humming for about 10 to 15 seconds than a click,,replace motor
Dec 25, 2008 | Kenmore 63942 Dryer
Dryers Logo
63 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
