Question about General Electric WBB2090G Top Load Washer
My GE top load washer is about 5 months old. It fills up and runs through the agitation cycle but then stops at the end spin cycle. The clothes just sit in the water. I checked the hose for kinks and checked the lid. Neither are the problem. I drained it by brining the hose down to ground level and am trying a cycle without clothes to see if it works then. Please help.
    Problem Solver:
  • 5 Answers
I have had this problem with two of my previous washers a top loader and front loader.Each time it was a faulty pump that drains the water from the tub after the wash cycle is complete. If the water does not drain from the tub the machine will not go to the spin cycle. Both of my washers were 5 or 6 years old when this occurred. If the washer is only 5 months old it should be under the manufactures warranty. Good Luck.
Posted on Nov 12, 2010
My kenmore 800 washer is off cycle for example when i start a load of clothes it starts agitating before filling, and doesn't always spin all the water out of the clothes
I have the exact same problem with my Kenmore 800 top loader, Model # 110.29822800. It is only 1.5 years old. Any suggestions?
Jan 19, 2011 | Kenmore 22422 Top Load Washer
I have a GE washer model # WHDRR418GWW. It is about 19 months old. It stopped agitating and spinning. It will fill with water and the timer/knob will go thru the cycles. But when it reaches the washing...
You have what is called "agitating dogs" there are usually 4 of them at the bottom of the agitator. They have small grippers which lock onto the agitator and agitates. If the washer is ever overfilled or over time filled to heavy this will wear down the nylon teeth on the "dogs". The top of the agitator will spin off, you will see a bolt inside at the bottom, remove bolt and the agitator will pull out. Google "agitating dogs on washer. It will give you pictures for a better understanding. If the belt was broken the washer would not drain, because the belt turns the pump. These dogs are about $5 and honestly easy to install. Good Luck.
Dec 04, 2010 | GE WHDRR418GWW 35 cu. ft. Washer
I have a GE model WHDRE526E1WW washmachine.The complaint was it would not spin. I checked the agitator coupler and the washmachine agitates but won't spin or fill with water. I suspect it may be the...
Try suspecting the tub end of the water level tube being plugged with " goop " so that the washer thinks it is still full of water, thus will not fill or spin. Take the front panel off by releasing the push in clips at the top of the front panel, in the seam where it meets the washer's top. Now, find the tube at the left side of the outer tub and pull it off the tub. Clean it out or cut off an inch (don't do the cutting thing more than one time) and replace after using a thin wire to clean out the tub end of the attachment. To help prevent this from re-occuering, every few months, fill the washer to the lowest setting with the hottest water, no clothes, and several cups of bleach, and run the longest cycle you have (with no clothes, of course). Make sure to rinse out the tub on a higher water level before you wash a load of clothes.
Sep 06, 2009 | Washing Machines
The washer is not spinning and clothes are extermely wet top load 3.5
Hi, Well try to set the washer on the regular cycle, large load and let it fill. After the washer fills to the selected level, the motor should start and the agitator should start agitating.
If you hear the motor running, but the agitator doesn't move at all, do the following:-
Stop the washer and set the timer on the spin cycle and let it run.
If the washer motor runs and the washer empties the water from the tank, but it won't spin, that is an indication that the motor coupler is not turning the transmission at all.
The motor coupler is made of two pieces of plastic called fingers and a hard rubber piece that goes in between the two fingers. One of the fingers is attached to the motor and the other finger is attached to the transmission. The had rubber round piece goes between the two fingers. When one of the plastic fingers breaks, the motor is no longer coupled to the transmission and the washer will not agitate or spin dry the clothes. The reason that the motor coupler breaks before it should, it is that the user overloads the washer. People stuff the washer with too much clothes, big comforters, small placer rugs, snickers, etc.
Another reason is that the washer is used every day; normally the washer is used 3 times a week. So if you have a washer that is 5 years old and you use it every day, it has the wear and tear of a washer that is 10 years old.
Replacing the motor coupler is not hard to do, once you see how the repair is done. You will save at least $100 by replacing the motor coupler yourself.
Thanks!
mannu_rakesh
Aug 21, 2009 | Washing Machines
Washer will not agitate or spin
HI,
you can view this site to have some ideas about your agitator problem.
http://sites.google.com/site/sublimeappliancerepair/washer-will-not-spin/agitator-woes
any further question let me know.
thanks,
Mar 29, 2009 | GE Profile WPRE6100G Top Load Washer
GE top load washer does not agitate or spin.
sounds like a bad lid switch how old is it?
Dec 29, 2008 | Washing Machines
Creda machine won't agitate with clothes in it
Your load is prob to heavy for the older washer. it just doesnt have the power to handle it no more. time to replace it, sorry.
Jul 30, 2007 | Creda W120VW Front Load Washer
General Electric WBB2090G Top Load Washer Logo
270 people viewed this question
Top General Electric Washing Machines Experts
Dan Webster
Dan Webster
Sal DeAngelo
Are you a General Electric Washing Machine Expert? Answer questions, earn points and help others
