Question about Canon Pixma iP4500 InkJet Printer
I AM TRYING TO RESET THE INK LEVEL INDICATOR ON A HP OFFICEJET 4500
  • Marius Chiriac Nov 12, 2010
    is your printer an HP or Canon.
    if you whant to resae the ink level on an Canon printer ( iP4500) you need a cartridge reseter. I could give you one for 50$
aicaxz
  • 511 Answers
SOURCE: I used to refill the ink cartridge of HP Deskjet D1460 by injecting ink. The problem is the level of ink is not resetted to full level, its still very low level. However, the printer prints normally
Close the top left pin at head contactor (1 pin only), with tape. Plug it in head carriage. Unplug it. Close to top rigtht with tape too. Plug the head. Unplug head. Remove all the tape cleanly. Plug again. See ink monitor.
Posted on May 31, 2009
SOURCE: Cannon Pixma 160 - How do I reset the ink level indicator
crapt the driver
Posted on Oct 21, 2008
  • 320 Answers
SOURCE: HP Deskjet F4280 Ink Level
when you refill the cardtridge, you can not reset the ink level... because refilling doesn't show the ink levels.. you no need to worry. if ink is there in the carttridge it will print...
Shouldn't worry about it. They are only a rough guide. The only time to worry about it is when the printer stops working and it has told you it's run out of ink! Thank you.......
Posted on Jan 29, 2009
ctau
  • 372 Answers
SOURCE: how to check ink level on hp officejet 6210 all-in-one printer
  • Open the Printer Toolbox . There are two ways to do this:
    • Click Start and select HP Solution Center . Select the Settings menu, then the Print Settings submenu, and finally the Printer Toolbox .
    • In your printing application, click File , click Print , and click Properties . Click the Services tab, then the Service This Device icon.
  • The Printer Toolbox opens. Click the Estimated Ink Level tab. A cartridge may be running out of ink even if the graphic shows ink remaining (see the note at the start of this section). Lines or streaks always appear in printouts when the cartridges begin to run out of ink. Replace print cartridges that are out of ink or low on ink.
  • Posted on Mar 22, 2009
    • 159 Answers
    SOURCE: I just refilled my HP6500 ink cartridge 920. The
    There is no way to reset the ink levels on this cartridge type yet. Any replacement chips on the internet are violating patent law. Once the chip tells the printer it is empty it will not print no matter how much ink is left in it. There is always a lag time between the introduction of a new cartridge type and the ability to fill it properly. For refills I would recommend Cartridge World when this cartridge type can be refilled.
    Posted on Feb 06, 2010
    How do i find ink levels in Windows 8 for HP Office Jet J4580
    It depends on what type of ink cartridge you have installed.....with HP genuine ink cartridges and HP Solution center installed, everything should be there. However, if you get an HP integrated ink cartridge refilled (i.e. HP 60, 61, 74, 75, 901, 92-98....currently offered at Costco or Frys today) or if you buy a remanufactured/compatible HP ink cartridge, the ink levels will not be displayed nor can they be reset (HP has a smart chip embedded within the nozzle plate at base of ink cartridge which counts the drops and then registers as empty).....so you'll just need to live with it and ignore 'ink low', 'non-genuine', 'counterfeit' messages and similar while you are using these types of aftermarket supplies. The first video below provides an overview of the 'low ink' phenomena.
    NOTE: These types of 'SEVERE' cartridge errors (i.e. "refer to documentation" / "incompatible cartridges", "print cartridge(s) problem" etc.) typically indicates the internal micro-electronics of the HP #901 / 901XL cartridge are damaged. The cartridge's electrical wire runs at rear and lower side of the ink cartridge are very delicate and are somewhat susceptible to ink attack over time, which can lead to premature failures. In addition, the older the cartridge the higher the chance of an internal electrical failure. I suggest you first run a 'Tap 41' diagnostic test to check cartridges electrical health (this is a forced test); you may also bypass the error (temporarily) on all models which use HP 901 cartridges. Refer to Inkjet411 youtube videos below:
    HP Officejet J4500 J4600 4500 Printer Error Messages -HP 901 & 901XL Cartridges
    http://www.youtube.com/watch?v=RivHgvWCkJ8
    HP 901 & 901XL Ink Cartridge Alerts - Low Ink Warnings:
    http://www.youtube.com/watch?v=hzLM5mlkTt4
    HP Officejet J4500 J4600 4500 Printers Tap 41 Diagnostics - HP 901 Incompatible Print Cartridges: http://www.youtube.com/watch?v=S6uATgXxQlE
    HP Officejet J4500 J4600 4500 Cartridge Error Bypass - HP 901 Cartridge Errors: http://www.youtube.com/watch?v=I4-m_RLdRE4
    HP 901 Ink Refilling & Cartridge Care Tips - Everything you need to know: http://www.youtube.com/watch?v=jTtNj6rN4g4
    Apr 12, 2013 | HP OfficeJet J4580 All-In-One InkJet...
    ATASCO HP OFFICEJET J4585
    When you get an HP integrated ink cartridge refilled (i.e. HP 60, 61, 74, 75, 901, 92-98....currently offered at Costco or Frys today) or if you buy a remanufactured/compatible HP ink cartridge, the ink levels cannot be reset (HP has a smart chip embedded within the nozzle plate at base of ink cartridge which counts the drops and then registers as empty).....so you'll just need to live with it and ignore 'ink low', 'non-genuine', 'counterfeit' messages and similar while you are using these types of aftermarket supplies. The first video below provides an overview of the 'low ink' phenomena.
    Additionally, severe cartridge error (i.e. "refer to documentation" / "incompatible cartridges", "print cartridge(s) problem" etc.) typically indicates the internal micro-electronics of the HP #901 / 901XL cartridge are damaged. The cartridge's electrical wire runs at rear and lower side of the ink cartridge are very delicate and are somewhat susceptible to ink attack over time, which can lead to premature failures. In addition, the older the cartridge the higher the chance of an internal electrical failure. I suggest you first run a 'Tap 41' diagnostic test to check cartridges electrical health (this is a forced test); you may also bypass the error (temporarily) on all models which use HP 901 cartridges. Refer to Inkjet411 youtube videos below:
    Feb 22, 2013 | HP OfficeJet J4580 All-In-One Laser...
    The exclamation mark is on and the screen is flickering hp j4580 officejet all in one
    A flashing exclamation mark is typically associated with a sever cartridge error (i.e. "refer to documentation" / "incompatible cartridges", "print cartridge(s) problem" etc.) typically indicates the internal micro-electronics of the HP #901 / 901XL cartridge are damaged. Have you tried replacing the ink cartridge with a new HP genuine cartridge to confirm?
    NOTE: The cartridge's electrical wire runs at rear and lower side of the ink cartridge are very delicate and are somewhat susceptible to ink attack over time, which can lead to premature failures. In addition, the older the cartridge the higher the chance of an internal electrical failure. I suggest you first run a 'Tap 41' diagnostic test to check cartridges electrical health (this is a forced test); you may also bypass the error (temporarily) on all models which use HP 901 cartridges. Refer to Inkjet411 youtube videos below:
    Jan 10, 2013 | HP OfficeJet J4580 All-In-One Laser...
    Reset 4500 hp estimated inklevel
    The best you can do is, Disconnect the power cord from back of printer ( while printer is on ) and reconnect after 30 seconds.
    This should help you in displaying ink level on printer front panel and also from solution Center on your pc ( if the complete software is installed )
    Basic software installation or just connected to PC will not display ink level on your PC Screen
    Regards,
    Suhail
    May 17, 2012 | HEWLETT-PACKARD Officejet 4500 All-in-One...
    How to reset the ink level of my hp officejet 6500
    Checking ink levelsUse one of the following methods to check the ink levels. Method one: Check the ink levels from the HP All-in-One The ink level is displayed on the main screen of the control panel display. Locate the two icons that represent the print cartridges. The icon on the left is for the color cartridge and the icon on the right is for the black cartridge.
    • The exclamation mark (! ) symbol indicates a low ink level.
    • The question mark (? ) symbol indicates the product cannot determine the status of the print cartridge. This might be because the cartridge is refilled.
    Figure 1: Ink levels on the control panel displayc01362755.gif 1 - Exclamation mark indicates low ink in the color cartridge 2 - Ink level in the black cartridge is OK Method two: Check the ink levels from the computer using the HP ToolboxFollow these steps to check the estimated ink levels using HP Toolbox.
    1. Make sure the product is on and connected to the computer.
    2. Open HP Solution Center .
      • Windows XP: On the Windows taskbar, click Start , click All Programs , point to HP , and then click HP Solution Center .
      • Windows Vista: On the Windows taskbar, click the Windows icon (c01364735.gif ), click All Programs , click HP , and then click HP Solution Center .
      • Windows 2000: On the Windows taskbar, click Start , click Programs , point to HP , and then click HP Solution Center .
    3. Click Settings .
    4. Point to Print Settings , and then click Printer Toolbox . Printer Toolbox opens.
    5. Check the ink levels displayed on the Estimated Ink Levels tab.
    Figure 2: Estimated ink levelsc00670267.gif
    Jun 02, 2010 | HP Officejet 6500 Wireless All-in-One...
    How to reset ink levels from HP J4580 printer refilled 901 wont show ink level comes up as empty
    slowly off and on the printer for five times without cartridge, printer saves data of cart of last 5 only so next time it reads full ink..
    Jan 10, 2010 | HP OfficeJet J4580 All-In-One Laser...
    "incompatible ink cartridge"
    Printer needs to be reset:
    1. Power OFF printer
    2. UN-plug power cord at wall/surge protector
    3. Turn ON printer (w/o power cord plugged in)
    4. Plug in power cord
    5. Turn ON printer
    (This will reset the printer)
    Sep 01, 2009 | HP OfficeJet J4580 All-In-One Laser...
    HP J4500 color cartridge error
    Take the cartridge out and clean the contacts off with something (ie: pencil eraser, your thumb...) That worked for me! I couldn't find a solution anywhere even after chatting with online tech support from HP. Quick and painless! I hope this helps...
    May 31, 2009 | HP OfficeJet J4580 All-In-One Laser...
    My hp officejet j4580 says incompatible black ink cartridge
    I've been in print cartridge hell since I bought a J4580.
    I spent an hour on chat with HP customer service and was able to resolve the problem by partially resetting the printer. Here's how:
    • Make sure your print cartridges are installed.
    • Unplug the machine, wait 20 seconds
    • Press and hold the # and 3 keys
    • Plug the machine back in
    • You'll see a reset message on the machine, release the # and 3 keys
    • Follow the prompts to set the language and location
    Cross your fingers, hopefully your printer will print now!
    Apr 11, 2009 | HP OfficeJet 6110 All-In-One InkJet...
    Canon Pixma iP4500 InkJet Printer Logo
    1,044 people viewed this question
    old marine
    old marine
