Question about Cadex CPB2335 138" 23 GAUGE PINNER PIN NAILER KIT
I didn't get an instruction manual with my 23 gauge Cadex Pin Nailer. I've only used it for about five minutes and now it won't fire pins any more. Possibly there is a pin jammed but without a Manual I don't know how to clear it. Is there somewhere I can download (our upload -- depending upon one's point of view), a Manual for the Cadex Pin Nailer. (Mine fires from 5/8 to 2" pins). Thank you. Art Locke
    President:
  • 1,082 Answers
Check out this forum. Talking about your nailer.
You could ask them for advice and help, perhaps someone has what you need.
http://forums.jlconline.com/forums/showthread.php?t=48870
Posted on Nov 12, 2010
How do you load a stanley bostitch model mB8 with staples
The Stanley Bostitch HP118K is a headless pin nailer, it is not able to use staples.
Jul 14, 2012 | Stanley Bostitch HP118K 23 Gauge Headless...
How to fix firing pin from sticking after each shot?
you might have to clean the firing pin, it may be covered with powder residue..
Mar 18, 2012 | RTO Paslode 902000 IM250 Ii Cordless 16...
SB 1842bn
When a firing pin won't return it's usually caused by damaged o-rings inside the gun. The most likely culprits are the o-rings around the outside of the cylinder or the rings on the drive piston. Another cause could be a cracked cylinder or bent driver. Remove the cap on top of the gun and check the condition of the o-rings, cylinder and driver. You'll have to order any parts that need to be replaced as Bostitch doesn't make a rebuild kit for this gun. Don't forget to lightly oil the o-rings with pnumatic gun oil when reassembling the gun. Most pin and finish nailers say they are oil-less but they still need a drop once in a while to keep the o-rings from being damaged.
Feb 14, 2012 | Stanley Bostitch HP118K 23 Gauge Headless...
Firing pin won't return SB 1842bn
Lubricate it and crank up air pressure and return spring.
Feb 14, 2012 | Stanley Bostitch Sb1842bn 18 Gauge Brad...
I am looking for an online manual for a Bostitch
http://www.bostitch.com/catalog_images/web_pdf/103280.pdf
Nov 30, 2009 | Stanley Bostitch HP118K 23 Gauge Headless...
Replacing driver unit in bostitch 23 gauge pin nailer model hp118k access through top of frame unit or bottom
Access is via the head cap. Remove the 4 screws and carefully take off the top. Be careful the head plunger does not fall out and keep it upside down.this way you are sure how to put head back on.
tap top of body against your hand to drive piston up and remove and replace piston assembly.
good luck
Apr 14, 2009 | Stanley Bostitch HP118K 23 Gauge Headless...
Cadex CPB2335 138" 23 GAUGE PINNER PIN NAILER KIT Logo
123 people viewed this question
Top Cadex Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Are you a Cadex Air Tool and Compressor Expert? Answer questions, earn points and help others
