Question about ASUS (S370L) Processor Board
I have an Asus G71gx laptop. 6 gig ram. nvidai geforce GTX 260M graphics card. and a 2.53 GHz processor. You would think I can run just about any game out there right? well latley I have been having problems with lag spikes. It's not my ISP. I will be running at an average of 100 FPS and around 70 Ping. Then it will drop to 12 FPS and like 3000+ ping. I don't belive it is a graphic card issue because I took it to best buy and they updated all of the nvidia drivers and everything and fixed some base system error. When my game gets this lag spike I can go to my desktop and everything is delayed by atleast a 1.5 seconds. Could this be a Processor issue?
SOURCE: supporting NVIDIA GeForce graphic cards
which display card is best
Posted on Jan 13, 2008
  • 99 Answers
SOURCE: Warning on post screen during boot up and ocassional blue screen
Sounds like the CPU is overclocked in your system. I would clear CMOS the try it again. The CPU is probably overclocked to far causing it to become unstable.
Posted on Dec 09, 2008
cpenzes
  • 1102 Answers
SOURCE: conflict between geforce nvidia 7200 with MOBO asus p5pl2
i think you mean you don't see any post readings
you can go into bios setup
and set page to default settings then press f10 to save and exit
let me know if this helped
Posted on Feb 09, 2009
buffalonyman
  • 1865 Answers
SOURCE: Processor heats up while processing heavy graphics
You need a custom built computer designed for your needs. I build custom PCs, let me know if you would like a quotation
Posted on Jun 18, 2009
SOURCE: Asus P5GZ-mx compatible graphics cards
Basically, any graphics card is capable of being compatible with this motherboard. I had some difficulties for a while until I figured out you have to MANUALLY set it to use your PCIE 2.0 GPU output.
How to do this is to set your jumpers to external output only. First thing you'll want to do is update the BIOS on the motherboard (Which you can do by getting "Asus-Update". Find it on google, easy to use, just make sure your computer doesn't crash during the BIOS flashing.
Afterwards, set the jumpers to use your PCIE-2.0 slot. Took me a little while to figure this out, and it's a little hard to explain.
Above your PCIE-2.0 slot there are 5 little blue 'plastic-like' things. Those are your jumpers. Take them out and insert them HORIZONTALLY as such:
Basically, make sure the jumper things are connecting the little drawing there. They HAVE to be horizontally inserted, otherwise this WILL NOT WORK. Just plug in your monitor to the graphics card's output, and you're good to go. Hopefully it works for you.
Posted on Sep 05, 2009
I want to buy a graphics card. i want to run programming applications and games with graphics requirements (NFS series), HD support will do but not necessary. My current system : 3.06GHz P4 HT processor,...
The GeForce FX5500 is an AGP Card (which is WAY outdated). Your board has a PCI-Express x16 slot (which is a good thing) so if you are planning to play games in the ilk of the NFS series, you can get an nVidia GT, GTS or GTX series card (I only assume you plan to get an nVidia-branded card; you still have options of purchasing ATI 4000- to 5000-series cards as well). these cards serve the purpose of entry-level to mid-range games. The only limitation of your rig would be the processor since it's a single core; but with 3 GHz & 2GB of RAM, you can play almost the entire NFS series up to Undercover, Shift & World. I'm not sure about Shift 2 & The Run: I think they require 2 cores at least.
Catch reviews with tech specs & side-by-side comparisons of existing video cards at GPU Review.
Aug 13, 2011 | Nvidia GeForce FX 5500 / 256MB DDR / AGP...
Hi. i have a compaq presario sr5025an. I have 2 gig of ram. I have the intel core 2 duo e4300 processor. I am after a grapics card. cheers.
To get the full specs of your mainboard go to: http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00893006&lc=en&cc=au&lang=en&product=3401230&dlc=en#N198
This motherboard has 1 PCI Express x16 slot for a graphics card.
You could use:
Geforce 6 series (6800GT)
Geforce 7 series (GeForce 7950, GeForce 7900, GeForce 7800, GeForce 7600 ,
GeForce 7300, GeForce 7200 and GeForce 7100)
Geforce 8 series (GeForce 8800 Ultra, GeForce 8800 GTX, GeForce 8800 GTS, GeForce 8800 GTS 512, GeForce 8800 GT, GeForce 8800 GS, GeForce 8600 GTS, GeForce 8600 GT and GeForce 8500 GT)
Geforce 9 series (GeForce 9800 GX2, GeForce 9800 GTX+, GeForce 9800 GTX, GeForce 9600 GT, GeForce 9600 GSO 512, GeForce 9600 GSO and GeForce 9400 GT
Geforce 200 series (GeForce GTX 295, GeForce GTX 285, GeForce GTX 280, GeForce GTX 275, GeForce GTX 260, GeForce GTS 250 GeForce GTS 240 and GeForce GT 220
Geforce 400 series (GeForce GTX 480, GeForce GTX 470, GeForce GTX 465, GeForce GTX 460, Geforce GTX 450)
With your system however I would recommend nothing greater than a Geforce GTS 250.
Please rate me high.
Thanks.
Nov 01, 2010 | HP Computers & Internet
Sims 3 crashes
Hi. Well that is obvious if the memory as well as the virtual memory drops below the required level. Your VGA settings (Graphic Adapter) might also making the game crash. It is a good thing to disable AVG temporarily while you play the game. (Please let me know your System's specifications as well. Like RAM size, VGA size, Processor Speed and Hard Drive Capacity - Both free and used capacity. If you have default specs for the Dell I6400 no need to include). Otherwise it will use the memory and virtual memory to scan the activities of the game.
You have to keep some vacant area in your System Partition (In which you have install the Operating System). Virtual memory page file is 1.5 x the size of RAM. But you can increase the size. But you have to have a faster hard drive as well because it will be used more when you increase it. The other option is to upgrade your RAM (installing an additional RAM if the PC supports). Most of the modern games require way too high performance PCs. Most of the time RAM and VGA.
To increase the Virtual Memory:
  1. Right click on My Computer icon and go to Properties.
  2. Click on Advanced tab.
  3. Click on Settings under the category, Performance.
  4. Click on Advanced.
  5. Click on Change under Virtual Memory.
  6. Select a free Partition (Which had more than the size x 1.5 of your RAM)
  7. Select the option System Managed size if you do not wish to do it manually. If you want to configure manually, select the Custom size option and enter the size which I mentioned before in BOTH the boxes.
  8. Then click on SET.
  9. You may be asked to Reboot the machine. Do so if asked to.
  10. Then play he game.
  11. If possible please upgrade your RAM.
Sims 3 System Requirements are as follows:
  • FOR WINDOWS XP
  1. 2.0 GHz P4 processor or equivalent
  2. 1 GB RAM (512 should be enough however)
  3. 128 MB Video Card with support for Pixel Shader 2.0
  4. The latest version of DirectX 9.0c
  5. Microsoft Windows XP Service Pack 2
  6. This one is very important: At least 6.1 GB of hard drive space with at least 1 GB of additional space for custom content and saved games.
  • FOR WINDOWS VISTA
  1. 2.4 GHz P4 processor or equivalent
  2. 1.5 GB RAM
  3. 128 MB Video Card with support for Pixel Shader 2.0 (not enough)
  4. Microsoft Windows Vista Service Pack 1
  5. At least 6.1 GB of hard drive space with at least 1 GB of additional space for custom content and saved games
  6. For computers using built-in graphics chipsets under Windows, the game requires at least:
  • Intel Integrated Chipset, GMA 3-Series or above
  • 2.6 GHz Pentium D CPU, or 1.8 GHz Core 2 Duo, or equivalent
  • 0.5 GB additional RAM
  • FOR MAC OS X
  1. Mac OS X 10.5.7 Leopard or higher
  2. Intel Core Duo Processor
  3. 2 GB RAM
  4. ATI X1600 or Nvidia 7300 GT with 128 MB of Video RAM, or Intel Integrated GMA X3100.
  • This game will not run on PowerPC (G3/G4/G5) based Mac systems, or the GMA 950 class of integrated video cards.
Windows Supported Video Cards NVIDIA GeForce series FX 5900, FX 5950 6200, 6500, 6600, 6800 7200, 7300, 7600, 7800, 7900, 7950 8400, 8500, 8600, 8800 9300, 9400, 9500, 9600, 9800 G100, GT 120, GT 130, GTS 150 GTS 250, GTX 260, GTX 280, GTX 285, GTX 295 ATI Radeon™ series 9500, 9600, 9800 X300, X600, X700, X800, X850 X1300, X1600, X1800, X1900, X1950 2400, 2600, 2900 3450, 3650, 3850, 3870 4850, 4870
Intel® Graphics Media Accelerator (GMA) GMA 3-Series, GMA 4-Series
Laptop versions of these chipsets may work, but may run comparatively slower. Standalone cards that are installed in vanilla PCI slots (not PCIe or PCIx or AGP), such as some GeForce FX variants, will perform poorly.
Integrated chipsets such as the ATI Xpress and the NVIDIA TurboCache variants may default to settings that are higher than what would be optimal for them. Graphics settings can be lowered to improve performance.
The NVIDIA GeForce FX series is unsupported under Vista. MAC OS X Supported Video Cards NVIDIA GeForce series 7300, 7600 8600, 8800 9400M, 9600M GT GT 120, GT 130 ATI Radeon™ series X1600, X1900 2400, 2600 3870 4850, 4870 Intel® Graphics Media Accelerator (GMA) GMA 3-Series.
So make sure to meet at least the minimum requirements.
Enjoy Gaming.
Please feel free to ask anything related to this. Please rate the answer as well if you feel that it helped to solve the issue.
Thanks for contacting Fixya!
Jul 10, 2010 | Dell Inspiron 6400 Notebook
PC will not run Sims3. DO I need a graphics card? if so, what type of card?
Hi friend The SIMS 3 minimum hardware requirements are:
1. FOR WINDOWS XP
* Windows XP (Service Pack 2)
* 2.0 GHz P4 processor or equivalent
* 1 GB RAM
* At least 6.5 GB of hard drive space with at least 1 GB additional space for custom content
* 128 MB Video Card with support for Pixel Shader 2.0
2. FOR WINDOWS VISTA
* Windows Vista (Service Pack 1)
* 2.4 GHz P4 processor or equivalent
* 1.5 GB RAM
For computers using built-in graphics chipsets, the game requires at least:
* Intel Integrated Chipset, GMA X3000 or above.
* 2.6 GHz Pentium D CPU, or 1.8 GHz Core 2 Duo, or equivalent
* 0.5 GB additional RAM
SUPPORTED VIDEO CARDS
FX 5900, FX 5950
6200, 6500, 6600, 6800,
9600, 9800, GTX 260, GTX 280
OR
ATI Radeon™ series
9500, 9600, 9800
2400, 2600, 2900
3450, 3650, 3850, 3870,
4850, 4870
OR
Intel® Extreme Graphics
GMA X3x00 series
Please cross check your system with this requirements and upgrade accordingly.
I hope this will help you out. Plz vote for me.
Thanks
Oct 06, 2009 | EA - Electronic Arts Sims: Complete...
I have Geforce Fx5200 128mb pixel shadder 2.0 and i cant run crysis, call of duty 4 is there any way to run these games ?
Yes with a better graphics card. You need Shader 4.0 at least on that graphics card. (Plus a lot more Stream Processors)
The GeForce FX 5200 is an AGP style of graphics card, and uses 8X speed. (0.8 Volts)
It is a Budget graphics card, and does not have the graphics 'power' needed for the games you stated.
(If memory serves it has 16 Stream Processors)
There is no 'miracle' program, or tweaking of settings, that will allow you to run the above stated games at a decent capability. Even at low settings for the games.
I would suggest an ATI HD Radeon 3850 at least.
HOWEVER, other things come into play.
You need a 400 Watt power supply that has 30 Amps on the 12 volt power rail. The power supply must have a 2x4 power cable. (Example:
http://www.playtool.com/pages/psuconnectors/connectors.html#eps4plus4 )
OR, enough 4-pin Molex power cables that are unused to put in a 2x4 power cable adapter.
Your processor has have the processing power needed also, or you will have a 'bottleneck' of graphics information.
A graphics card has it's own processor. (GPU. Graphics Processing Unit)
It also has it's own Ram Memory. (Graphics ram memory)
However if the processor is too slow, the graphics information cannot be processed from the processor to the game program, and vice-versa, in a speedily fashion.
Graphics information, (Data), hangs up. Frames freeze, and frame rate slows down.
Post the computer name , model name. and model number, and we'll see if a better graphics card will help.
(Example: HP Pavilion D5200t)
Sep 24, 2009 | Computers & Internet
Cant get sims 3 to work on laptop
Could be your laptop doesn't have the necessary horsepower to run SIMS 3 (mine doesn't)
THE SIMS 3 MINIMUM HARDWARE REQUIREMENTS
FOR WINDOWS XP
* 1 GB RAM
FOR WINDOWS VISTA
* 1.5 GB RAM
FX 5900, FX 5950
ATI Radeon™ series
9500, 9600, 9800
2400, 2600, 2900
4850, 4870
GMA X3x00 series
Jul 05, 2009 | Acer Aspire 3690 Notebook
Notebook graphics card upgrade
  • Asus ROG STRIX GTX 1080 O8G GAMING. ...
  • MSI GeForce GTX 1070 GAMING X 8G. ...
  • EVGA GeForce GTX 1080 Ti Founders Edition. ...
  • Zotac GeForce GTX 1050 Ti 4GB OC Edition. ...
  • Nvidia GeForce GTX 1080 Founders Edition. ...
  • Nvidia GeForce GTX 1060 Founders Edition. ...
  • XFX Radeon RX 480
you can purchase any one and use it
May 15, 2017 | Philips i855 Cellular Phone
Graphics card
Probably more RAM, but 900MB means you must have a 1GB card - that's pretty good. 2GB total should be plenty.
Jul 05, 2008 | Evga e-GeForce 6200 GeForce 6200, (256 MB)...
Graphics card
In order for Cold Fear to run properly, your PC must meet or exceed these minimum requirements:
Opertaing System: Windows 2000 / XP Only
Processor: 1 GHz processor minimum, (2 GHz recommended)
RAM: 256MB RAM minimum, (512MB recommended)
Video Card: DirectX 9 compliant 64MB (128MB recommended) see supported list *
Sound Card: DirectX 9 compliant
DirectX Version: DirectX 9 included on disk
DVD-ROM: 8X or better
Hard Drive Space: 2.2 GB
Peripherals: Mouse, keyboard, Windows compliant game pad.
* Supported Video Cards at Time of Release
Nvidia GeForce 3/4/FX/6 series (GeForce 4 MX not supported)
ATI Radeon 8500/9000/X series
These chipsets are the only ones that will run this game. Laptop versions of these chips may work but are not supported
NOTICE: This game contains technology intended to prevent copying that may conflict with some DVD-RW and virtual drives.
Also, make sure that no other programs are running.
Dec 09, 2007 | Computers & Internet
ASUS (S370L) Processor Board Logo
230 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
