Samsung 52 inch dlp tv purchased in 2003 will not handle 1080i signal from brighthouse hddvr. states no signal detected thanks howard
    Problem Solver:
  • 5 Answers
Be sure you are using the correct component input
This model has three component inputs and only one (the third from left) will work on 1080i signal the first two only handle 480i and 480p
This tv will not operate with 720p signal
supertek57
Posted on Jun 17, 2008
Why is there sound but no picture?
According to the owner's manual page 2.7 (and this is an OLD [by HDTV standards] set), the TV can only handle input resolutions of 480p or 1080i on the composite inputs. Most HDTV programming today is 720p with some 1080i and 1080p on certain channels (like some Discovery shows about nature). It is possible that your set will not process the 720p signals being sent.
Nov 03, 2015 | Samsung TSL3294HF TV
I am unable to 1080i reception on my TV with a HDDVR cablebox
You need to specify your TV make and model, and HDDVR make and model if you want help. Describe the problem in as much detail as possible.
Feb 16, 2011 | Televison & Video
What is high pitched sound with samsung 52 inch dlp tv . works fine
Need to adjust the vs voltage in the power supply is to high, you have to use a multimeter on dc voltage and only go down 10% of the actual voltage.
Dec 18, 2010 | Samsung HL-S5087W DLP TV
How heavy is a hitachi 52 inch dlp tv
The weight of the hitachi 52 inch TV is around 94.1 lbs 0r 42.6 Kg
Thanx
Jul 31, 2010 | Hitachi UltraVision CineForm 55VG825 55"...
480i to 1080i?
It depends on which input you are using, but the HDMI inputs are auto detecting. Most likely whatever device you have connected is not putting out a 1080i signal, and needs to be configured to do that. Once you do, you should see the input icons on the top right briefly come up, and below the input number, you should see "1080i"
Feb 01, 2009 | Sharp Aquos LC-52SE94U 52 in. LCD HDTV
My samsung 52" flat lcd hd tv
yours DLP TV not a LCD.
LCD has on one light with red.
If the DLP likes that.
1st -- check the thermostat
2nd -- check the power board.
Jun 10, 2008 | Samsung 52 in. LCD Flat-Panel HDTV
Inputs
learn lip reading..... but really 1080i inputs have to cut main circuit and be processed through your main amplifier .
shorted or too low a signal at input is a start.
Jan 08, 2008 | Samsung DLP HL-P5663W 56" TV
Mitsubishi TV 52'
Mitsubishi gives this error , when it does not detect a video signal.....Check your wiring.
Dec 24, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Hitachi 53SDX89BA
I also have a Hitachi 53SDX89BA and I bought it with the same assumption as you: that it's HD ready. The specs in the manual states the following: "Full 1080i HDTV Capatable with Set-Top Box". I beleive this means that it does not include an HD tuner, but that it is capable of handling up to 1080i resolution. Normal (non-HD) resolution on this TV is 480i.
So here's my problem: Until recently, I wasn't using the HD settings on this TV because I don't have a set top box, nor do I subscribe to any HD content from my cable provider. However, I just purchased an XBox 360 along with an XBox 360 HD-DVD player (it's an XBox peripheral that works with the game console). The Xbox asks you to choose the resolution output (480i, 720i or 1080i) to match your TV's HD capabilities. When I select 1080i output and change my TV's settings to receive an HD signal, the picture quality is amazing. However, the video signal seems to get lost ocassionally (i.e. TV picture gets scrambled) but then it comes right back. This does not happen when I select a 480i output on the Xbox...but of course, the picture isn't as crisp and clear as a 1080i picture.
I don't know if this is a problem with the TV or with the Xbox. Has anybody else had this problem??
Dec 06, 2007 | Hitachi 50UX57B 50" Rear Projection...
RCA 52" rear projection d - board
by "D" board i would think that would be the deflection..which i have to ask....What does that have to do with it .... these uniits have a board called signal board that handles formating the different pic sizes. What was the problem before that board was replaced?
Nov 19, 2007 | RCA HD52W56 52" Rear Projection HDTV
Televison & Video Logo
384 people viewed this question
Top Televison & Video Experts
Electro Med Services...
