Question about eMachines T1440 PC Desktop
I have an emachines T1440 desktop. the front face of the machine is broken, the power cord, and the wires from the power cord to the power supply box. What type of case or tower can i use the remaining of the parts with?
  • eMachines Master
  • 4,338 Answers
Luckily, eMachine uses a generic system board. You can purchase a case from any computer store. The only thing to watch for is the plate in the rear of the motherboard, make sure it matches your ports. Again I believe you can use the one from your eMachine.
Posted on Nov 12, 2010
Power cord on motherboard
Hello, The power to your motherboard is coming from your power supply if it is bad you will have to get another emachine power supply, for emachines, only emachine parts work.
Mar 01, 2014 | E-Machines eMachines Desktop PC
Can't get the cover off
Ensure that all required screws have been removed. Make sure that you're removing the correct panel. Clear any cabling that make be hanging up your removal of the panel.
Nov 12, 2012 | eMachines T1440 PC Desktop
NO POWER TO THE MOTHER BOARD OF MY EMACHINE
The Wires goes on the motherboard, check your motherboard manual for reference
Mar 17, 2009 | E-Machines eMachines T3830 PC Desktop
Front Power switch wire is broken
As long as the rating is the same as the power supply you should have no problems
Make sure to check your wiring and all the connections are correct or you could have one expensive paper weight.
Dec 29, 2008 | E-Machines T2893 PC Desktop
EMachine T1440 will no boot on
There is a battery inside the pc, remove it and replace it with a new one. Leaving it unplugged for that long taxes the battery too much. This should help and also plug everything in and reset the power switch on the back.
Aug 19, 2008 | E-Machines eMachines Desktop PC
EMachines not powering up
You may have updated windows to a point that this old machine cant handle the revamp. Kick back to an older ops system, although that poses security risks. Your motherboard may also have given up. Best advice - upgrade, and retire this machine to the recycle bin.
Jul 18, 2008 | E-Machines eMachines Desktop PC
Power problem
look for a switch on the back of the computer by the power supply it must be in the I position not the O . if that will not work then the motherboard my be damaged or the power supply itself not the cord for it is very rare for a power cord to polarize any more. last the power button itself may be damaged but in al my years I have not found a bad power button yet. Always it has been the motherboard or the power supply.
May 08, 2008 | E-Machines eMachines Desktop PC
Emachine with XP home edition doesn't start
Hi hearalso, down to the basic's. Replace power cord.
No help there than, remove the case's side panel to expose the motherboard. (Normally it is the left side panel while facing the front of the PC.)
Look closely for a small (green in color) led light. The power cord must be connected to the PC & connected to you're power strip but do not press the power on button on the PC.
The green led tell's you the board is receiving 5volts. Check all connections. Un-plug & reconnect every data & power connector in your PC. (Double check). There is a fuse inside your power supply that may have blown. Check you're manual page, Approva Statements B-1. Fuse Warning Instruction Caution.
Check fuse in power supply. (Unplug power cord before opening).
If you can not power up the PC after all of the above than if possible, swap out the power supply.
Replacing the power supply is the last step.
If you have more questions, feel free to ask.
Good Luck!
Mike
Apr 09, 2008 | E-Machines eMachines Desktop PC
E-Machines 2862 Dead On Power-Up
I believe that the front button is not connecting to the switch for the power supply. Also make sure all internal connections are secure. Sometimes the button breaks from behind so that it cannot contact the switch. Let me know if it helps. There are other solutions if you tried this one first.
Nov 01, 2007 | E-Machines T2682 (000002965) PC Desktop
eMachines T1440 PC Desktop Logo
95 people viewed this question
Top eMachines Computers & Internet Experts
brian soufane
Avishek Samaddar
Avishek Samaddar
Are you an eMachines Computer and Internet Expert? Answer questions, earn points and help others
