Question about Whirlpool GSW9800PW Washer
Whirlpool Gold Washer Cataylist
The washer does not fill and shows and F3 error and when resetting at F4 Error. Help
  • 15,935 Answers
The problem with the fabric softener not dispensing is not likely related to and F03 error code due to the washer not draining.
For the dispenser problem, I recommend that you pull the dispenser drawer out and clean it thoroughly.
The fabric softener dispenser works on a siphoning principle.
Make sure that the siphon hole in the dispenser is clear and not restricted or plugged.
You can fill the fabric softener compartment with water and make sure that it is siphoning properly while you are cleaning it.
Make sure that the cover is properly replaced on the fabric softener dispenser when the drawer is replaced in the washer.
You can use the diagnostic test described below to test the fabric softener dispenser.
If the softener dispenser does not fill and dispense properly, you could have a failed dispenser valve, a failed control board or a wiring failure between components.
You indicated that you tested the pump and that it is good. You could have a clogged drain hose or a clogged washer drain that would prevent the washer from draining.
You could also have a failed drain pump even though it runs. If the impeller is jammed or damaged, it will not pump out the water in the washer.
You will likely need to unplug the washer and drain the water out of the tub using a wet/dry shop vacuum.
To check the pump and drain hose at the bottom of the washer, remove the bottom front service panel and remove the drain pump. You may find a clog or restriction in the drain pump or connecting hoses. If the drain pump is damaged or will not work, it will need to be replaced.
The F4 error code on your washer indicates a problem in the electrical circuits of the washer... and not end-user repairable.
This problem requires a technician to test the wiring circuits to diagnose the problem.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 21, 2010
Fh error code wirpool duet washer
Display shows F20 or FH - Front-load washer ' Whirlpool ...
https://www.whirlpool.com/...fh-front-load-...
Whirlpool Home AppliancesQuestion: Display shows F20 or FH - Front-load washer. Answer. Image. or. Image. or. Image. This error code indicates a water supply problem. Are both the hot ...
whirlpool duet error code FH - Appliance Repair Forum
forum.appliancepartspros.com > Appliance Repair Help > Washer Repair
Jan 5, 2009 - 10 posts - ‎1 author
... Repair Help > Washer Repair » whirlpool duet error code FH .... FH No water detected entering machine or Pressure switch trip not detected. Whirlpool Duet diagnostic code C:03 error code FH
1 post
Dec 5, 2014
Whirlpool Duet Washer HF Error Code
Jun 10, 2013
FH Error Code on Whirlpool Duet Washer
Mar 11, 2013
FH error code
Sep 13, 2008
More results from forum.appliancepartspros.com
Stumped on error code FH for Whirlpool Duet front load washer .
Jan 08, 2016 | Washing Machines
Have Kenmore Elite Catalyst Washer showing F3.
I have a top load Kenmore Gold Catalyst Cleaning Action washer that is stuck on permanent press mode. The digital display reads 8 min. and will not turn off or clear.When it is turned on the, the timer goes to 37 minutes and beeps repeatedly through all cycles. It will not clear even when I unplug it. How do I fix this annoying thing!!? Thoughts please.
Bill
May 22, 2010 | Kenmore Washing Machines
What does error code F3 means?
error code f3 shows that there is a problem in the heating circuit of the dish washer. you may need to access the Heater or relay on the control board for any defect also check the wiring
Apr 05, 2010 | Whirlpool 24 in. ADP5962 Free-standing...
Whirlpool Gold washer throws F3 and F4 codes
Jan 17, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Kenmore Elite Catalyst washing machine getting error F4
See if this helps.
http://www.askmehelpdesk.com/appliances/washer-kenmore-elite-catalyst-110-20092993-f3-f4-error-codes-191730.html
Aug 01, 2009 | Kenmore Washing Machines
Error code F4
Jul 04, 2009 | Whirlpool 24 in. ADP5966 Free-standing...
I have a whirlpool catalyst washer and recently it started blinking an F4 error code..my ? is what should I be looking at when it shows that error code? I have a whirlpool Duet GHW9150P Front loader. When...
Jul 31, 2008 | Whirlpool Duet GHW9150P Front Load Washer
what is your model # i looked at the manual there is no F4 code they only go up to F3 if you post your email i will send you the service guide
May 20, 2008 | Whirlpool Washing Machines
Whirlpool GSW9800PW Washer Logo
170 people viewed this question
Dan Webster
Dan Webster
prem mathew
